09-16-2019, 04:39 PM | #1 |
Rep 1,286
Is HPFP upgrade required for PS2?
If one is targeting 500whp, what other components outside of the actual PS2 turbo are required?
And do I need any of the items suggested in the drop boxes here: https://x-ph.com/bmw-n55-pure-stage-2/ Anything else needed? What about HPFP? What’s the labor time to install this?
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
09-16-2019, 04:50 PM | #2 |
Gettin It Figured Out
1820
Rep 2,669
Definitely fuel upgrade required to achieve 500+...either PI or upgraded HPFP. PI is the least expensive option, although there will be other HPFP options available that will be relatively close in price to PI coming “soon”
McLaren720s1476.00 |
09-16-2019, 05:27 PM | #3 |
Rep 188
HPFP upgrade or PI is required for more than 500whp I'm pretty sure.
And I would say yes to the diverter valve upgrade, and go for a high flow inlet. |
09-16-2019, 05:54 PM | #4 |
Rep 282
i rather have my fuel controlled by one system , the cars own DME .
Pi requires a second controller and many extra wiring , tubing mods etc . A hpfp upgrade is more straight forward and requires only a decent tune . For your N55 , there are 3 options the known route with Xdi , you can always try a HDP6 or hdp5evo from a B58 , check the hpfp option topic . The third one is the yet to be announced spool performance pump .
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
09-17-2019, 07:38 PM | #5 | |
Dream crusher
984
Rep 2,421
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
09-20-2019, 10:10 AM | #6 |
Rep 1,286
How much power should I expect with a straight up PS2 upgrade and nothing else? Would I need a tune after install?
And then if I add the HPFP, would I need a tune as well?
09-20-2019, 10:36 AM | #7 | |
Rep 188
Mostly because of the higher flow, if you dont run the right map your AFR's can lean out too much. |
09-20-2019, 10:45 AM | #8 | |
Rep 1,286
But if I add a HPFP, then I would have to go custom tune to take advantage of the additional fueling capabilities for extra power? Or could I still run the Stage 2H map?
09-20-2019, 11:06 AM | #9 | |
Rep 188
I don't know if you need a custom to take advantage of the upgraded HPFP but I'd assume so or else it would just act like a "normal" HPFP. |
09-20-2019, 12:44 PM | #10 |
Rep 1,286
The shop is also asking if I’m upgrading the injectors. Would that be required to hit 500whp?
09-20-2019, 12:46 PM | #11 | |
1820
Rep 2,669
No, not needed .
09-20-2019, 01:08 PM | #12 |
Rep 340
09-20-2019, 01:21 PM | #13 |
Rep 1,286
I got quoted 15 hours of labor and $2200 for the install.
09-20-2019, 01:24 PM | #14 |
Rep 1,105
09-20-2019, 02:45 PM | #15 | |
Rep 1,286
Might have to call other places too, if I decide to do this. But seems hard to find shops that do this kind of custom work.
