01-31-2018, 07:15 PM | #23 |
Rep 123
Thank you guys for real fast responding, will dig into this tomorrow
Current: 2007 335i
Past: F30 M3 clone/ IS-F/ E46 M3/ Gen Coupe/ MS6 |
02-01-2018, 12:15 AM | #24 |
Rep 1,502
When you do get it sorted out, in the future don’t charge the battery directly. Use the charging post under the hood so the car knows the battery is being charged and adjusts accordingly.
02-01-2018, 09:00 AM | #25 |
Rep 1,329
That' strange, I did exactly this during winter storage one year on my E82 135i. Called BMW customer Service and their recommendation was to attach power to the jumper terminals under the hood. I though this wouldn't work with the battery circuit open, but it worked just as they said it would.
2002 325i sport - sold 2009 135i M sport - sold
2009 550i M sport - sold 2005 M3 6MT Jet Black w/Cinnamon 2016 F30 320i ZSP 2003 E46 325it ZSP 5MT |
02-01-2018, 09:08 AM | #26 |
Rep 16,079
02-01-2018, 09:41 AM | #27 | |
Cheapskate
4447
Rep 4,993
I've also clamped +power onto the starter to get power to another car with a similar issue but the battery was locked in the trunk. Not sure where our starters are though. Probably not nearly as accessible as a fwd car. |
02-01-2018, 10:44 AM | #28 |
Rep 16,079
The battery supplies power to the fuse boxes of course. The question is does the positive charging post also connect to the fuse boxes, in a parallel connection with the battery positive connection. Logically it should. Even if the OP had disconnected the battery completely voltage at the charging posts should power the fuse boxes. Since he only disconnected the ground (Why? 'tis puzzlement) lug it's really odd that power to the posts doesn't power the car.
The starter is in more or less the same place on all cars. Typically the battery connects directly to the starter solenoid, through a very large gauge cable because of the high current involved, so if the battery is hooked up there's always voltage at the starter. It's only when the solenoid is energized by the starter button circuitry that power goes to the starter motor windings. |
02-01-2018, 01:40 PM | #29 |
Rep 123
when all this happened, i was not able to get power through the under hood positive and negative terminals for some reason, i had everything plugged right and jumped from another car and nothing...
Anyways problem is solved, took the rear seat out (really not that hard), and crawled in the trunk to open it, and i realized my seats do not fold down at all
Current: 2007 335i
IK6SPEED4488.00 |
02-01-2018, 01:53 PM | #30 | |
Rep 10,473
Google is your friend. As multiple threads over 10 years all over bimmerpost and other bimmer forums report, this does NOT work. I DID Google it before telling him to take out seats last night. |
02-01-2018, 02:38 PM | #31 | |
Rep 1,329
I don't follow... I see it working here, and I did it myself on my E82. What am I missing?
Johnny Chuttz9.00 |
02-01-2018, 02:50 PM | #32 |
Rep 16,079
02-01-2018, 02:58 PM | #33 | |
Rep 10,473
As also noted, dozens of threads on bimmerpost and other bimmer forums where this did not work. Many about the E Series. In other words, it is not a solution that often works. Unless you dismiss all the other threads as well. Perhaps you really should read what’s posted as OP had stated he tried that prior to your post. What’s the definition of insanity? Doing the same thing over and over while expecting different results. Last edited by IK6SPEED; 02-01-2018 at 03:03 PM.. |
02-01-2018, 03:08 PM | #35 |
Rep 10,473
OK, I’ll take you at your word you can read. You just have a comprehension issue.
02-01-2018, 03:15 PM | #36 |
Rep 1,329
Yes, I understand OP tried this. I do read the thread before I post.
It's curious this is the intended method by BMW and it works sometimes and not others. It might be useful for others if we figured out why this is. OP already got it opened, so only useful for others who read this in the future. I am attempting to be constructive and avoid the typical smug internet forum responses. They are not helpful or entertaining.
02-01-2018, 03:17 PM | #37 | |
Rep 10,473
One might get lucky, but based on the threads over 10 years where this method was recommended and subsequently failed, the odds are not very good. |
02-01-2018, 03:24 PM | #38 |
Rep 5,776
Even though the issue is over I will add what I know: I did this on my e90 and what did work was hooking up a quick charger to the terminals under the hood. Powered right up and trunk was able to open.
02-01-2018, 03:27 PM | #39 |
Rep 5,995
Yeah a trickle charger won't work current too low. But jump starting should work if a quick charger works. could be the F30 terminal is different somehow and the electrical system uses some sort of power distributor over the positive terminal in the trunk to send power to various components using different cables attached to it. Though I thought the E90 was similar.
02-01-2018, 03:31 PM | #40 | |
Rep 123
Current: 2007 335i
02-01-2018, 03:33 PM | #41 |
Rep 16,079
I just went out to my garage and disconnected the ground lug from my battery. I've got a maintainer attached to the under hood charging posts due to the cold weather, and low and behold, with the battery disconnected there's still power to the car. Comprehend that.
08-02-2019, 07:33 PM | #42 |
Rep 14
I know this Is a late reply but this actually happened to me today while changing my battery. stupid that some cars don't have rear folding seats.
I used jumping cables from the new battery I had sitting out (or can use another car) to the connections under the hood just the get some power flowing. press the start/stop once (accessory mode) and then press the trunk button. popped open. *disconnect the jumping cables right after.* Built: 2013 320i F30 |
