01-01-2023, 07:11 AM | #1 |
Rep 68
Safe mode after replacing DME
Hi
f30 b48 320i 2016 , 90 k relaced the DME and FEM at the dealership https://f30.bimmerpost.com/forums/sh....php?t=1874550 ,, after a few months those codes pop up and the car goes into safe mode,, replaced the battery just in case (it was due time for a battery since it wasn't replaced from new) Date: 17/12/2022, 12:01 AM VIN: DAB8A350205B20562 10 Central gateway module 1 error 801C20: Central fault memory full 12 Motor electronics 1 error 103308: Accelerator pedal module, pedal encoder, plausibility: Synchronization error between pedal encoder 1 and pedal encoder 2 18 Transmission control 1 error CF2CE1: DME / DDE interface: (actual accelerator angle, 0xD9) signal invalid or the qualifier (qualifier actual accelerator angle, 0xD9) signals poor quality of the useful signal 1C Integrated chassis management 2 errors 480134: SBS function - direction of travel unsafe with vx greater than 2 m / s D02D01: Signal error (accelerator pedal angle, ID: ANG_ACPD) qualifier 29 Dynamic stability control MK60 E5 2 errors 1 4809AB: Global power supply - external undervoltage D36D01: Signal error (accelerator pedal angle, ID: ANG_ACPD) qualifier 4D Electric-motor reel, left 1 error DC5476: Signal (0xD9) invalid: Qualifier_Ist_Winkel_Fahrpedal 4E Electric-motor reel, right 1 error DC9476: Signal (0xD9) invalid: Qualifier_Ist_Winkel_Fahrpedal any idea ? |
01-16-2023, 05:12 PM | #3 |
Rep 1,155
bring it back to the dealership as they coded it, so they should fix this honestly.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
05-22-2024, 12:17 PM | #4 | |
Rep 68
a wire out of its track
so a very very long story short the dealership misplaced the throttle body wiring , they moved it Infront of the alternator , and the alternator damaged the wiring going to the throttle body , thus causing a SHORT (the conductive element in the wire was touching the metal of the alternator) causing all that mess Please follow the pictures and u will understand |
