05-12-2024, 07:23 PM | #1 |
Rep 136
Drives: Monaco Blue 335i
Edit: Resolved! Please see my post below if you have encountered a similar issue and need help
Hi, For about 3 weeks now the AC vents from my 2018 330i have smelled like wet dog, so I go to buy an HVAC foam cleaner which directs you to spray into the vents inside the car. As you may guess, it presumably dripped down into the head unit and it appears my head unit is now toast- there is a noticeable clicking noise coming from the dark every time the car is started, permanently stuck on navigation loading, CarPlay and Bluetooth not working. Is there anyone located in or around the San Francisco Bay Area who can code a new hard drive and/or head unit for me if I was to provide the parts? I am not familiar with Linux and I’m not especially savvy with F30 coding (I come from a long line of E46/E90 coding). I am also open to suggestions outside of taking it to the dealer. Thank you in advance! Edit: I am willing to pay for anyone who can help me!
Current: 2006 330i Mystic Blue 6MT, 2011 328i Coupe Titan Silver Ex: 2006 330i Barrique Red, 2008 335i Monaco Blue, 2011 335i Deep Sea Blue |
05-13-2024, 09:22 AM | #2 |
Rep 1,709
Drives: 2014 428i and 2018 X5
This isn't going to help you now, but that's not the proper way to remove the smell. This is how to do it:
05-13-2024, 10:26 PM | #3 | |
Rep 136
Does anyone know if it’s plug and play if I replaced the entire head unit with a head unit from a similarly optioned car? Thanks in advance
05-22-2024, 06:45 PM | #4 |
Rep 15
https://www.instagram.com/bmw_remote...JodjhzeGl3ZA==
Ask this guy on Instagram. He fixed my head unit stuck on bmw logo screen turning off every 3 minutes. He’ll be able to tell you if you need a new head unit or if he can just flash it |
autoAER101.50 |
05-22-2024, 07:58 PM | #5 |
Rep 346
Don't follow that video that was posted above.
This exact thing happened to me, but it was a shop that messed my car up when I was chasing how to clean that wet dog smell from the AC. Behind the head unit isn't a fully enclosed system, so when you fogged it, it caused condensation to build on your hard drive. I got lucky where it just affected the hard drive but the rest of the unit was good. sounds like you are in the same boat as I had the same symptoms. What happened is it messed up the Mechanical Hard drive - that's what you hear clicking, this is why you can't load navigation, store radio stations, Bluetooth, etc. Only radio. I found some guy on eBay who will replace the HD (you can supply your own, I put in an SSD) and code it to your VIN, flash it, etc. Not the most customer-service-friendly person - but knows his stuff - trust me. he saved me thousands and a dead head unit. Go to his website linked below, he knows what he is talking about, very in-depth and knowledgable. https://www.ebay.com/itm/253840706906 https://www.bavlogic.com/?page_id=4123 You can't just get another head unit and plug it in - it has to be coded to your VIN due to all the options, features, computer information, etc. You have to remove your head unit and send it to him, it's not that hard to take it out - YouTube/google is your friend. He flashed it with Carplay which I didn't have before and the latest BMW software so it was a bonus for me. The shop that damaged my car ended up paying the guy's fee, which was like $600 I think. BMW will quote you for an entire head unit replacement, which is thousands of dollars. Don't let them rob you. TRUST ME - this is what is wrong with it - I went through the SAME EXACT THING. Other people do this as well - google is your friend. - Save your "tip" for the repair brother - enjoy your head unit again Here is a link to what my head unit was doing https://photos.app.goo.gl/jXduWZdqKG4DRJvi7 Last edited by F30Mo16; 05-22-2024 at 08:41 PM.. |
autoAER101.50 |
05-23-2024, 11:13 PM | #6 |
Rep 136
Thank you so much for all of your replies, this is all excellent information!
Here’s what I ended up doing: I reached out to Steve@codemybimmer. For anyone needing to fix a failed head unit hard drive, I highly recommend Steve’s services. You will need to replace the actual drive first, which is extremely straight forward- you’ll need to remove the dash trim (pulls right out of the dash), pop off the lower plastic trim cover directly above the cupholders, and from there it is a matter of unscrewing the various torx screws and literally just lifting the hard drive out (I used a T20 screwdriver for the HVAC controls and head unit support, and a T8 for the hard drive bracket, DVD drive, and head unit screws). Check out the link below for detailed step by step instructions. Once you install the new drive and assemble everything back together, you’ll need an enet cable, a 64 gb flash drive, and a windows laptop (or bootcamp Mac). Steve quickly remotely initialized the new SSD for me once everything was connected, and now everything works as it should! Link to an excellent guide for hard drive removal: https://f30.bimmerpost.com/forums/sh....php?t=1935383 Breakdown of my cost (with links): $125 - codemybimmer level 2 support package - level 2 support $20 - 240gb SSD - amazon $13 - enet cable - amazon $9 - 64 GB flash drive - best buy Total cost: ~$167 (can be even cheaper depending on what you can find!) I hope this information is helpful! Thanks again to everyone who took the time to read this thread and help!
05-26-2024, 12:47 AM | #7 |
Rep 247
Identical thing happened to me. I used this guy
https://bimmer-remote.com/ Just giving another option for anyone this happens to. |
autoAER101.50 |
05-26-2024, 05:10 PM | #8 | |
Rep 136
May I ask what your total cost was? I’m trying to compile the cheapest fixes for anyone else who encounters this problem
