11-28-2018, 03:32 PM | #1 |
Rep 1,862
Drives: powered by bootmod3
*** bootmod3 *** XDI Fuel Pump (HPFP) Support - Now Available!
Hey guys, over the past year we've worked with a number of customers and shops that chose the XDI's high flow pump as their HPFP upgrade. They have two versions available, the XDI-35 and the XDI-60, both of which outflow the OEM HPFP pump on the N55.
As of now any bootmod3 user looking to go with an XDI HPFP upgrade can go into any of their maps (custom or OTS), use the map configuration screen and choose the appropriate pump from a dropdown of options, screenshot attached. Note that simply installing one of these pumps and not making the changes will end up setting the car into limp mode (Drivetrain Malfunction) as well as throw various codes for fuel pressure so a map change is required to run them. For all questions related to the pumps please direct them at TTFS (TuningTechFS) who have done a great deal of work with XDI to make this upgrade happen when it comes to fitment and R&D and they're best to answer any questions. We're simply adding software support for the pumps to make the solution as Plug'n'Play as possible. We have seen a considerable improvement over the stock N55 pump on an M2 while tuning with TTFS end of last year and more recently on an N55 PWG car (both come with the same OEM HPFP pump). Here's a log of the N55-PWG car running the XDI-35 pump. As you can see there's no pressure drop at the HPFP XDI-35 HPFP on OTS 2H map, Pure Stage 2 turbo PWG car (no HPFP drop outside of traction loss event at around 3900rpm): http://www.bootmod3.net/log?id=5bcf486cd10b435a2d3651ce OEM HPFP on OTS 2H map, Pure Stage 2 turbo PWG car (400-500psi HPFP drop): http://services.bootmod3.net/log?id=...0b4365a7303ff0
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com Last edited by proTUNING Freaks; 11-28-2018 at 04:29 PM.. |
11-28-2018, 06:02 PM | #3 |
Rep 716
Drives: F90 M5
That great! would anyone happen to have a link as to where i can buy one? The XDI website isn't too clear as to which hpfp is for the N55. The ones on their website are listed for GM, Audi and Fords. Thanks in advance guys haha
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
11-28-2018, 06:04 PM | #4 |
IG @bmwF9xG80
3813
Rep 7,593
Great times to be alive for the N55 guys !
60-130mph 6.5s X4M #HCP
F30_SixSpeed1170.50 |
11-28-2018, 06:05 PM | #5 | |
IG @bmwF9xG80
3813
Rep 7,593
ronanz1819.50 F30_SixSpeed1170.50 |
11-28-2018, 07:39 PM | #7 | |
Gettin It Figured Out
1820
Rep 2,669
F30_SixSpeed1170.50 FSociety3812.50 |
11-28-2018, 08:18 PM | #8 | |
Rep 832
Drives: 2019 G01 X3
http://tuningtechfs.com/shop/bmw/bmw-2-3-4-series/ |
11-28-2018, 08:41 PM | #9 | ||
Rep 10,473
No F3x links as shown below.. And search is barren for it as well. Then again, the link you provided has no info on the XDI-HPFP-60 |
FSociety3812.50 |
11-28-2018, 08:53 PM | #10 |
Rep 832
Drives: 2019 G01 X3
At what point does HPFP upgrade become necessary? Is this only needed for big turbos? Should LPFP be upgraded at same time?
11-28-2018, 08:57 PM | #11 | |
1820
Rep 2,669
FSociety3812.50 |
11-28-2018, 08:58 PM | #12 |
Rep 2,357
Is the featured PWG car work in progress? A pump upgrade with those relatively low boost levels make little sense.
Who is tuning the car?
(A Dane in China) |
hardparker299.00 |
11-28-2018, 09:03 PM | #13 | |
1820
Rep 2,669
Uhmmmmmm....the people who created this post... .
11-28-2018, 09:13 PM | #14 |
Rep 2,357
Depend primarily on whether your car is PWG or EWG. The early PWG HPFP seems stronger than the later EWG. I would say around 16psi.
(A Dane in China) |
11-28-2018, 09:18 PM | #15 | |
Rep 969
Just for your information - These upgraded pumps can handle 20+ psi of boost on a typical PS2 setup if the octane supports it
11-28-2018, 09:42 PM | #16 | ||
IG @bmwF9xG80
3813
Rep 7,593
The PWG HPFP is not stronger (more myth than truth) the thing is the PWG turbo is smaller than EWG haha. For ex. N63TU turbo is smaller so it shows HPFP handle more fueling than S63TU (same pump but bigger turbo) runs out of fuel faster. Quote:
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 11-28-2018 at 11:01 PM.. |
11-28-2018, 11:35 PM | #17 | |
Rep 2,357
(A Dane in China) |
11-29-2018, 03:34 AM | #18 |
Rep 504
please guys, before declaring fake statements just check bmw parts catalogue ok? EARLY N55s (until ~2011-2012 mainly E series and some first F10) had 1:1 pump like N54 (siemens type), so yes it's way stronger. All F30/F20/F22 pumps are "new" design bosch type, same part number for year 2012 pwg or year 2015 ewg. period. please stop speculating this topic.
FSociety3812.50 F30_SixSpeed1170.50 |
11-29-2018, 03:42 AM | #19 | |
Rep 2,357
And yes, a stock EWG at same boost would make more HP compared to a PWG hence demanding more fuel. Maybe that is the cause for this theory..?
(A Dane in China) |
11-29-2018, 06:36 AM | #20 | |
IG @bmwF9xG80
3813
Rep 7,593
Same HPFP hence why EWG runs out of fuel quicker!
11-29-2018, 07:34 AM | #22 | |
Rep 64
I'm happy that now people will see how much more they can get out of their cars. Hopefully, they don't break other parts in the process. |
bm3, bootmod3 |
