06-13-2015, 05:10 PM | #111 |
Rep 215
So the current N55 intercooler is air-to-air? At what HP is the current intercooler limited? Anyone foresee improvement or limits with the new air-to-coolant intercooler? I'm almost sure I'm buying a M240xi (and mod it) when the lease is over on my M235xi and this looks like the only point of concern I have.
Brandon
06-13-2015, 05:34 PM | #112 | |
OOOO another former Audi B5 S4 owner OOOO
196
Rep 625
and why the x-drive in Denver? snow? |
06-13-2015, 06:14 PM | #113 | |
Rep 215
Not gonna blow up this thread on why I bought an xdrive
Brandon
06-16-2015, 08:06 AM | #115 | |
Rep 10,185
335i was 5.5, 340i now 5.1 435i is 5.1, upcoming 440i will probably be listed at around 4.7 4 Series is shown as quicker as it is marketed as being slightly better than the 3 Series. Just like the 6 Series against the 5 Series. Marketing
06-16-2015, 10:04 AM | #116 | |
Rep 258
06-16-2015, 10:53 AM | #117 | |
Rep 10,185
4 is marketed as slightly faster and has better standard trim and commands a higher price. Engine, software and ECU exactly the same Done in all industries.
07-01-2015, 12:22 PM | #118 | |
Rep 1,026
07-01-2015, 12:34 PM | #119 | |
Rep 6,478
And especially agree with your note RE: cylinder pressure. With the move towards smaller displacement, small turbo (twin or TS singles) it necessitates a lot of boost pressure to move a modest amount of air. The N20 is at what, 19 pounds or so from the factory? Takes high compression, high boost to make decent power with such little displacement and such a small turbo. I'm guessing the same will be the case with this motor.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
07-01-2015, 12:45 PM | #120 | |
Rep 1,026
A lot of the turbo OEM's are looking at lighter weight/higher temperature materials for their spools, so this might change the dynamic some eventually. |
07-12-2015, 10:56 PM | #121 | |
Rep 215
Brandon
07-13-2015, 04:21 AM | #122 |
Fool
1857
Rep 3,542
I would imagine the limitation will be the gearbox rather than the charge cooler. The gearbox is still only rated for 500NM and a stock 340 is already doing 450 on paper and BMW do tend to underestimate. I wouldn't want to be putting any unwarranted power through the transmission without an upgrade. The MPPK is likely to be right on the limits of the 'box.
07-13-2015, 11:40 AM | #123 | ||
Rep 1,003
Drives: 16 340i, 15 X3d, 91 318i
If you check out the S55, anecdotally it sounds as though the liquid-to-air coolers work like a charm. |
07-13-2015, 11:44 AM | #124 |
Rep 900
If you are willing sometime, I'd love to talk with you about that car. My F10 lease is up next summer, and it would be a lot more useful to spend an hour with a guy who has owned the car than 15 minutes on a test drive with a CA. Beer's on me.
-Will
2013 535i xDrive M-Sport | 2005 545i Sport (Retired and missed) | 2001 X5 3.0 Sport (Retired) |
07-13-2015, 11:51 AM | #125 |
Rep 215
PM me, I'm on vacation July 20-Aug 3.
Brandon
07-14-2015, 12:25 PM | #126 | |
Rep 215
Plus there will be a "harder" lower limit on the intake temp since the coolant will always be warmer than the surrounding air. I suspect intake temps have caused me issue drag racing before. I don't know that the S55 is relevant since it is designed to handle track abuse, while the N55/B58 is optimized more for typical passenger car usage.
Brandon
07-15-2015, 11:02 AM | #127 | |
Rep 1,003
The coolant will be warmer than the ambient air, yes, but without knowing how much warmer I think it's just speculation to say that there will be a harder limit on minimum IAT. Part of the case for going liquid-to-air is that a liquid can do a better job of pulling heat from air in comparison, so even if the air is cooler (which is sometimes barely true during hot weather) the warmer liquid is still advantageous. The S55 is relevant because anecdotally M3/4 owners are turning up the boost and not feeling like they are limited by IAT and/or heatsoak. Yes, the 340 will be scaled down in all things, but I think it's fair to say that turning up the boost on it may likewise produce more power without a huge deficit due to the charge air cooling. My 2 cents anyway. |
08-19-2015, 03:50 PM | #129 |
196
Rep 625
08-19-2015, 08:40 PM | #131 | |
196
Rep 625
I was hoping BMW, in typical fashion, was UNDER-rating this new engine's output. 320bhp is what it's listed at. Many of were expecting dyno results to be closer to 340bhp. (I know HP numbers aren't everything, but gotta keep it close to the C450 AMG) |
08-19-2015, 10:05 PM | #132 | |
Rep 2,744
