06-25-2018, 04:49 PM | #1 |
Rep 116
Drives: Z4M
idrive knob sticking
Anybody had their Idrive knob stick? I only sticks when moving to the right. It will not come back to center. I hate to replace the whole idrive.
06-26-2018, 07:21 AM | #4 |
Rep 16,079
I've never had a problem with it. If you're concerned use the Contact Cleaner version.
https://www.wd40.com/videos/on-the-j...cal-components |
06-26-2018, 07:43 AM | #5 |
Rep 1,572
Try a can of compressed air like CRC's Duster around the base of the iDrive while rotating back and forth. May have some debris under there impeding the rotation. Then go the WD-40 Contact cleaner route.
08-26-2019, 07:32 PM | #6 |
Rep 2
08-26-2019, 07:49 PM | #7 |
Gettin It Figured Out
1820
Rep 2,669
if you've ever spilt a syrup based drink, try spraying alcohol based window cleaner on controller, in around anything that moves while rotating and pressing buttons to thoroughly clean and/or break up grime. Window cleaner will dissolve syrup
09-11-2019, 05:58 PM | #8 |
Great Teacher
1086
Rep 1,305
Drives: 06 e91 325ix
You can also safely use Simple Green on electrical.
I’ve done so to unstick window switches etc on various cars, usually due to the aforementioned sugar drinks. But I only use it when I can remove the part from the car, then rinse with alcohol to displace the water. |
10-20-2019, 03:08 PM | #9 | |
Rep 97
I'm in a fairly new 2019 X5. I really don't want to have the dealer tear into the console of a car with a couple thousand miles on it. Any info on solutions that actually work? Thank you. |
10-21-2019, 04:08 PM | #10 |
Rep 878
I wouldn’t use any alcohol based cleaners as you might end up discolouring or eating through the rubber feel plastic.
09-22-2020, 06:48 AM | #11 |
Rep 1
Any clue?
Hi everybody,
Any clue on this? Did you find out a solution for the sticking joystick? It suddenly happened to me in my car =( Thank you! Last edited by vdm318; 09-23-2020 at 06:55 AM.. |
09-22-2020, 09:05 AM | #12 | |
Rep 97
Mine was replaced under warranty. 2019 X5. Thankfully, no weird creaks, misaligned trim, or any other issues resulting from the replacement. |
05-24-2023, 11:12 AM | #16 |
Rep 539
I would just spray contact cleaner on it, or even try some isopropyl alcohol on it.
Failing that, you'll have to take it apart. Not difficult to take it out of the car. Worst case if you break it, they're not that expensive to replace with a used one anyway. |
