04-11-2021, 11:19 PM | #3235 |
Rep 25
Just wanted to give info on my install I completed early last week in my F10. I did get the 12.3" version from Kanor.
I completed what I call my phase 1 complete install. Unit works as advertised and expected. Having done a lot of research prior and thanks to all the information and answers shared here, I knew what to expect in terms of both install and functionality. I followed the video install on YouTube (007Serge's and NYST8FMIND's). One variation in my install was using an InStock GPS210 splitter to split the OEM GPS signal between the OEM and Android HUs. Works perfectly (see picture attached). Here are links to the Fakra to Coax connectors I used: 2x Female Fakra to Male Coax 1x Male Fakra to Male Coax The goal, in addition to sharing the GPS signal, is to prevent the Android HU from sending DC power which could damage the OEM GPS equipment. Basic functionality works, WiFi, maps, music, bluetooth, Android Auto and other apps. As I've read here in the forum, audio integration seems to be some peoples' main gripe. However, it works fine for me in terms of using the OEM mic and speakers. While there are a few options of playing music, I have settled to use the Amazon Prime app on the Android HU as the primary means to playing music. I did test playing music from my phone via bluetooth connection with the Android HU. Playing music using the Android music player is definitely going to be the least (and probably never) used option. Looks like I am also able to use the OEM mic with Google Maps. Right now, I only have my phone connected via bluetooth to the OEM unit for calls. As such when calls come in or go out, they still use the OEM mic and speakers. I also have my phone as a hotspot for the Android HU. I have heads-up display and OEM 360 camera in my car. The OEM 360 camera still works fine when I put the car into reverse. Wireless Android Auto was initially one of my most wanted features. However, I think I have settled to use apps natively on the Android HU instead. I still need to do more testing. At the very least, I know wired AA works as expected. The one caveat is that the USB connection to the Android HU doesn't seem to be powerful enough to charge my phone. As it stands, AA will only be useful for getting email and messaging from my phone. For anyone interested - here is my experience testing with wireless AA. It works as it should with my S9+. In addition to the dependency on the android phone supporting wireless AA, what I discovered from my testing is that the phone needs to be paired via bluetooth for calls with the Android HU, otherwise wireless AA won't work. I tried enabling the paired connection for audio only but wireless AA wouldn't work because my phone and the android HU wouldn't stay paired. As an FYI, the way AA auto works is that it starts a hotspot on the compatible HU, in the case the android HU, and then forces the phone to connect to the hotspot. As long as the phone stays connected to the hotspot, AA keeps working. In my tests, once my phone connects via bluetooth with the android HU (and enabled for calls) AA begins to look for new car connections and one just needs to start Zlink for the wireless AA connection to complete. In addition, my tests show that Head Unit Reloaded (HUR) also works as excepted when connected to my phone's hotspot. I just have to set AA on my phone to "Start head unit server" and then have HUR connect via WiFi. Phase 2 will be incorporating a USB DAC and installing OEM single USB and USB/AUX-IN sockets in the glove box. Right now, I have the USB cables run into the glove box via the cutout for the USB socket. Everything works as it should now, just want to improve sound quality and give the OEM look in the glove box. I have the wires with male and female 3.5mm ends as well as the 4-pin socket harness I got from ECS. Frankly30 Do you or anyone know the AUX socket 4-pin connection mapping to the 3-pin left, right and ground 3.5mm AUX connectors? Last edited by ooati; 04-13-2021 at 10:32 PM.. |
Mjam133.50 |
04-12-2021, 01:36 AM | #3236 | |
Rep 5
My phone is well connected now |
04-12-2021, 04:15 AM | #3238 | |
Rep 353
Video is below. Just wanted to share my first impressions. Frameless BIG display looks great! My 10.25 in comparison looks so small after 12.3) Works fast as expected. This is my first screen with the Blue Ray option as Chinese sellers call it. In reality it is violet anti-glare film on the screen that prevents reflections BUT makes an image a bit blurry and negatively affect on view angles. Definitely much better is anti-glare coating that goes on 10.25 HD GS screens. In general, 12.3 looks fresh and natural in F01, should be the same in F10 but in E70, E84 IMO for extreme users only)) Last edited by serge858; 04-12-2021 at 10:38 AM.. |
Mjam133.50 |
04-12-2021, 06:44 AM | #3240 |
Rep 1
Dab+
I'm trying to figure out if this player supports DAB+
KANOR https://www.alibaba.com/product-deta...103825615.html Or do they all support this? |
04-12-2021, 07:07 AM | #3241 | |
Rep 2,366
Drives: E63 645Ci
04-12-2021, 08:13 AM | #3242 | |
Rep 26
04-12-2021, 08:21 AM | #3243 |
Rep 353
This is boot logo animation made by RedErik, available here in the thread or here:
https://mega.nz/folder/m4F03TaS#k7jsBqvPW8_u_W15FeirKg |
RedErik1023.50 |
04-12-2021, 09:18 AM | #3244 |
Rep 2,366
Drives: E63 645Ci
More info here:
https://f30.bimmerpost.com/forums/sh....php?t=1719625 |
serge858149.50 |
04-12-2021, 11:58 PM | #3246 |
Rep 353
04-13-2021, 12:45 PM | #3247 |
Rep 1,048
I checked the update in comparison to 2.7.9, this version 2.8.3 is from 9th April 2021.
Update can be found here: https://mega.nz/folder/kIB3CSZD#wnqmCQnF8i7VW1yIEvz66g Code:
ro.build.display.id=Ksw-Q-Userdebug_OS_v2.8.3 ro.build.version.incremental=eng.zhanji.20210409.223546 ro.system.build.date=Fri Apr 9 22:35:22 CST 2021 ro.system.build.fingerprint=qti/msm8953_64/msm8953_64:10/QKQ1.191008.001/zhanjianquan04092235:userdebug/test-keys This Update has alot of changes due to the ZLINK-HICAR implementation, so maybe we missed some other changes at the code. The behavior of Memory Killer has been updated, apps will now be killed when there is only 20% of RAM free anymore, before it was at 40%.Now the changelog of this update:
I also made a new set of factory_config.xml files, as some things are new:
Factory_config_BMW_A10_283.zip A Noticeable change is that Factory Settings do now support changing GUI Names to whatever you want This is probably more useful for company use to Change GUI Names to reflect their BRAND, or to remove Car Manufacturer Names due to legal issues This is how the Line does look alike Code:
<Item id="5" name = "BMW_EVO_ID7" display = "FANCY NEW INTERFACE" /> Kri Last edited by Kri; 04-14-2021 at 12:15 AM.. |
04-13-2021, 02:30 PM | #3249 |
Rep 143
Hi Kri,
There are a couple of random ´ in the <SupportUIList> section in your Factory_config_BMW_A10_283.zip, and they are outside of the comment tags. I haven't tried this build yet so I don't know if this will have any negative impact on the functionality of the units as it pertains to those lines of code (Best case scenario, they will just be ignored, I don't know). I deleted them from my own file, but I figured I'd point this out in case they do end up causing issues for anyone. (You have PM turned off so I couldn't message you privately). Thanks for all your work! |
LittleSamurai4.50 |
04-13-2021, 03:01 PM | #3250 |
Rep 2
Aftermarket rear camera has not been working properly
My aftermarket rear camera has not been working properly. Sometimes the camera works and sometimes it doesn't. I will then see this message.
How can I fix this? |
04-13-2021, 03:18 PM | #3251 | |
Rep 5
С уважением, С.
EvntHrzn94.00 |
04-13-2021, 03:23 PM | #3252 |
Rep 143
04-13-2021, 05:55 PM | #3253 | |
Rep 26
04-13-2021, 06:01 PM | #3254 |
Rep 2,366
Drives: E63 645Ci
04-13-2021, 08:31 PM | #3255 |
Rep 181
04-13-2021, 08:53 PM | #3256 | |
Rep 181
It looks like you have 2x Female Fakra to Male Coax (link points to the splitter) and 1x Male Fakra to Male Coax (not pictured, but assuming it connects to the top of the splitter?) |
