04-07-2020, 02:13 PM | #89 | |
Rep 1,782
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
04-07-2020, 02:32 PM | #90 |
Rep 1,499
I found it. It's the slave cylinder from the E90 335i. It's a direct swap with no integrated CDV.
08-31-2020, 12:18 PM | #91 | |
Rep 49
Just to clarify: Spec stage 2+ clutch OEM style Dual mass flywheel (can you direct me to which one you bought? I'm assuming it's the 335is/550i) A slave cylinder (can you direct me to this as well?) you removed the CDV. I'm not even sure what to tell my mechanic about this part lol. If you can help me out I'd greatly appreciate it man. |
08-31-2020, 12:34 PM | #92 | |
Rep 7,607
08-31-2020, 12:51 PM | #93 | ||
Rep 252
Drives: 2017 Model S P100D
My parts were: - Spec st2+ for OEM flywheel: SB553H (NOT sb553h-2, that is for SMF only) - New BMW clutch slave cyl: 21526795713 - 6x torx bolts for clutch mount: 23001222894 - LuK OEM DMF: 21207640733 - 6x flywheel bolts: 11227520706 The shop had to buy a few more bolts during the install because they are "single use" as per BMW. I can't recall what they were because they just grabbed them from the dealership at the time of installation |
08-31-2020, 02:19 PM | #94 | ||
Rep 49
Meaning: - Spec 2+ SB553H (for DMF) - E90 slave (it does not have a CDV; Direct swap, no delete) - 6x torx bolts for clutch mount - LuK OEM DMF - 6x flywheel bolts Quote:
In terms of the bolts, I'll probably have to tell the mechanic ahead of time, I'm sure he's mentioned that he works directly with BMW so he should be able to order when need be. |
03-13-2022, 11:49 AM | #95 |
Rep 33
terryd5150507.00 |
03-15-2022, 08:16 AM | #96 |
Rep 1,065
The steel single mass flywheel makes a little more noise for those searching. It's not bad but definitely a small tick similar to a Diesel engine. The spec stage 3+ after break in feels close to stock but with a little more grab.
CDV delete makes the clutch actually grab and go from a stop and the 1-2 shift, but that won't make a difference once our fully in gear and go WOT to check for a slipping clutch
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
12-19-2022, 01:22 PM | #97 |
Rep 1
Hey guys I知 new to here so don稚 really know how to use this lol, but I知 replacing the clutch on my 2013 335i xdrive. I bought a 550i clutch kit and found out my flywheel was done for. I found a spec light weight aluminum flywheel that I want to get but I知 not sure if it値l work fine with the 550i kit?? Also while I知 in there I did the CDV delete, heard good things about deleting it.
12-23-2022, 03:31 PM | #98 |
Instagram: @bmwdriven_
51
Rep 119
Definitely the clutch, Chicken Joe. My clutch immediately started slipping when going Stage 2 E30.
Currently, running Spec Stage 2+ with OEM Flywheel. I daily my car and love this setup. |
