02-08-2018, 02:27 PM | #1 |
Rep 68
Steering wheel column rattle/buzz?
I have noticed for a few months now that my steering wheel column has a buzz/rattle on the rougher road surface, even when I touch or push the column, adjust the steering wheel it’s still there, again only on the rougher road surface.
Has anybody else has his, or has a cure? Thanks Luke |
02-08-2018, 04:00 PM | #2 | |
Gettin It Figured Out
1820
Rep 2,669
If you don’t find your answer in link below...search “steering column rattle fix” Has been covered many times... http://f30.bimmerpost.com/forums/sho...d.php?t=923182 .
eluded3038.00 |
02-08-2018, 11:25 PM | #3 |
Rep 125
Drives: 2013 328I Sportline
I used to have this and it was annoying. I fixed by removind the bottom steering column trim, stuffing 2 foam sponge on left and right column and reassembling. Hasnt made a noise since and it has been over a year.
zamboni1130.50 |
02-09-2018, 09:32 AM | #4 | |
Rep 55
How hard is it to remove the trim? Does it just pop off or do you need to remove the airbag and steering wheel to get to it?
Current...2014 328i xDrive M-Sport
Past.......2008 Saab 9-3 Turbo-X, 2004 Saab 9-5 Aero, 1994 Saab 900 Turbo Commemorative Edition, 2001 Saab 9-5 SE V6 |
02-09-2018, 10:47 AM | #5 |
Rep 55
I searched the part number on eBay in hopes of seeing what's inside the steering column before attempting to take it apart. It looks like there's Styrofoam sandwiched into the bottom of the cover that could easily make the buzzing sounds I've been experiencing if it's not secured in there. Counterproductive sound insulation I guess. No amount of pressure, prodding, poking, banging, on this area stops the sound for me.
Video (headphones recommended):
02-09-2018, 11:33 AM | #6 | |
Rep 125
And the video you posted is spot on as to how my car used to sound before i fixed it. |
02-09-2018, 11:40 AM | #7 | |
Rep 55
02-14-2018, 07:57 AM | #9 |
Rep 55
Alright, I think I'm onto something.
See here for column cover removal (go to 10:12): You don't need to have the steering wheel removed, but I would recommend having it turned 180-degrees upside down so you can work through the top of the steering wheel to unplug connectors in the trim piece. The lower column cover trim has a chunk of Styrofoam loosely sandwiched between two pieces of plastic. Mine was flopping around in there, squeaking against the plastic pieces. I would just remove it but I assume it's there because it has a purpose, like protecting your knees in a crash, I don't know... Anyway, I got it out, took it apart and loaded up every plastic surface the foam touches with adhesive-backed craft fabric. There were obvious contact points where the plastic and foam have been chaffing for the past four years, but I put it everywhere. Putting it back together the result is a nice solid feeling piece of trim before reinstalling it back into the car. The lighter colored felt is what my dealer probably put in there to try to solve the issue, but it doesn't touch any adjoining surfaces so it did nothing. Will test drive this weekend on a road trip to Vermont, but I'm 97% sure this is the source of that death buzz.
09-13-2018, 01:11 PM | #10 |
Rep 78
I had my brake fluid changes yesterday and thought I'd mention it to the sales associate and he noted it down, when I went to collect the car he mentioned they had changed the steering wheel trim (the actual steering wheel trim) not the casing at the back which is making the noise.
Anyways, I've been in the car for a bit now and made sure i went over rough roads and the noise has actually gone. Albeit mine was very intermittent anyways and I could sometimes go days without hearing it, so lets see if that has done anything, I don't have high hopes.. |
12-15-2018, 08:53 PM | #11 |
Rep 571
I have what sounds like a metal on insulation squeak around the steering column, but this was not it. Even drove around with this part off and still heard it.
Sounds further down the column. Any thoughts? |
12-17-2018, 07:38 AM | #12 | |
Rep 55
Finally found it and explained here: https://f30.bimmerpost.com/forums/sh...05&postcount=9 And here: https://f30.bimmerpost.com/forums/sh...8&postcount=15
12-17-2018, 07:55 AM | #13 | |
Rep 5,456
Drives: F30
01-06-2019, 11:03 PM | #14 | |
Rep 571
Thanks. |
05-16-2020, 07:37 PM | #15 | |
Rep 33
Drives: 2016 328ix
05-16-2020, 11:12 PM | #16 | ||
Rep 78
06-06-2020, 02:41 PM | #17 |
Rep 33
Drives: 2016 328ix
So, removed the kick panel and was able to stuff some rattle tape up between the module and it’s clip. A little awkward for me to access it. The rattle hasn't completely gone but is a lot less frequent and only really aggravated on rougher roads. Hoping it holds up. Any other ideas?
05-07-2021, 08:15 PM | #18 | |
Rep 3,218
Drives: 2018 BMW 440i GC
05-07-2021, 08:31 PM | #19 |
Rep 33
Drives: 2016 328ix
It’s the plastic cover on drivers side under your steering wheel where your knees would be. 2 screws if I remember right. Unscrew and you can pull it down to access the module.
antzcrashing1910.00 sshamim1.50 |
02-22-2023, 02:36 PM | #20 |
Rep 8
Hi Guys, last year I have bought F31 LCI 2019 and I am dealing with the same death buzzing sound from somewhere in steering wheel trims or the dash or gauges. I have a question: could You please confirm that You were succeeded in removing this horrible buzzing sound off and it has been produced by plastic clip which holded the electornic module placed on the drivers side above the rest pedal ?
02-23-2023, 01:39 AM | #22 |
Rep 8
Thank You for reply. This document says about noise when turning the steering wheel, but noise in my car is exactly the same as on the video above (IMG 8297 sent by raquettelaker2) and probably refers to the buzzing electonic module which is poor mounted.
Does anyone of You were trying to solve the problem and can firmly confirm that it works ? I just dont want to diassemble the trims if this will not take effect. |
