09-03-2021, 12:09 AM | #1 |
Rep 706
anyone running SHELL gas with N20?
just curious, i heard that B48 and S55 engine knocks when running with SHELL gas
i am curious to know if any N20 runs SHELL and if it knocks. thanks. Last edited by gameson; 09-03-2021 at 08:29 PM.. |
09-03-2021, 08:13 AM | #2 |
Rep 16,079
Gas is gas, there are no major differences between brands. Shell does not make 98 octane anyway. Perhaps you're looking at ratings from Europe or Australia, which aren't measured the same as in the US.
09-04-2021, 11:38 PM | #3 | |
Rep 74
I'm not sure why Shell 93 would knock more than any other type of 93 octane. |
09-06-2021, 01:54 PM | #4 |
Petrolhead
1942
Rep 3,521
Stock B46 and shell 93 here. Zero issues. I've run BP 93 too and no issues there as well.
Current:
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige |
09-09-2021, 05:00 PM | #5 |
Rep 326
Costco 91. Been awesome.
I used to buy Shell, but not many cars would buy from my local shell. So I'm guessing it had old gas and occasionally my car would have strange gas smells. Went away when I switched to Costco. As long as the fuel has the Top Tier designation and meets or exceeds the octane rating then it's fine. My local Costco gas station refills daily, so I'm always getting new fuel which is important IMO.
If you can imagine it, you can achieve it.
If you can dream it, you can become it. |
09-09-2021, 10:16 PM | #7 |
Petrolhead
1942
Rep 3,521
Shell is top tier. A lot of people swear by shell. I used to fill up with BP ultimate because they also had E85 (for when I was running my JB4). But since my car has been stock for a while now, I moved to shell because apparently it's the best?
Current:
09-12-2021, 12:59 PM | #8 |
G
129
Rep 162
Drives: 2013 BMW 328i F30 Luxury Line
'13 328i F30 N20, no issues with Shell at all, it actually loves Shell. The only way gas would cause a knock would be bad gas, someone's being cheap by putting the lowest octane gas in or someone put diesel in (which would cause more than a knock). But as long as the right gas octane rating is used, it's good to go.
09-12-2021, 09:55 PM | #9 |
Rep 1,060
No issues with shell or chevron. Would run chevron for Techron due to driving across the country, but shell was good too.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
09-26-2021, 09:41 AM | #10 |
Rep 361
As much praise as Sunoco gets, I consistently get CELs when using the station by my house. 93oct. Car is a 14 n20 completely stock. Shell and Costco FTW!
Present: 2014 f30 328xi MSport, 1992 VW GTi VR6 swapped
Past: 2010 335i 6 speed; 2008 VW GTi stage 2, 2004 Subie WRX FBO, 2003 20th Anny VW GTi FBO |
10-03-2021, 07:48 AM | #11 |
Rep 16
I agree. I think a bad tank of gas is certainly possible but picking one brand over the other is pointless. If there's any difference it's a regional one, not brand-based.
10-03-2021, 09:26 AM | #12 |
Rep 16,079
Picking one brand over another doesn't necessarily get you anything. For instance, for all the hype about Sunoco they haven't refined all of their own gas since 2011, none since 2019.
11-05-2021, 04:20 PM | #14 |
Rep 261
Drives: 2017 320i xdrive
this is a very interesting post. I recently went stg 1 93 oct in NJ and found the stations like exxon feel way way way worse than shell. I found shell 93oct to feel the best for the car. I feel more throttle response and more power too. With other brands of 93oct, the car seems to bog and generally runs weird. I probably should do a datalog at some point....
