02-22-2020, 10:21 AM | #2817 | |
1296
Rep 3,533
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
romemedrano117.50 |
02-22-2020, 02:07 PM | #2818 |
Rep 175
Also having connection Issues.
I'm trying to reflash but I'm being told my OBD agent isn't up to date. I have updated in the app multiple times but every time it "successfully" updates to the newest version my connection drops out and will not re-connect. Once I turn everything off and connect I have to do this same process over. I've reviewed the troubleshooting page, disconnected the battery, renamed the hotspot name, ect.. This is what happens every time I try and flash
13' 335xi PWG M-Sport 8spd - BM3, CTS Turbo FBO, H&R Sport Springs + Spacers, BMW MPE
02-22-2020, 02:13 PM | #2819 | |
Gettin It Figured Out
1820
Rep 2,669
If you're using your phone, try hard rebooting and log back in .
02-22-2020, 02:39 PM | #2820 | ||
Rep 175
02-22-2020, 04:10 PM | #2821 |
1296
Rep 3,533
02-23-2020, 02:23 PM | #2822 |
Rep 175
I tried this as well and no fix. I am manually reinstalling the update on my SD, hopefully this does the trick
02-23-2020, 02:27 PM | #2823 |
Rep 500
Drives: BMW 330e F30 M-sport
So, I have two peculiar logs:
http://www.bootmod3.net/log?id=5e5107a5d10b4377fa625dce (around timestamp 300) http://www.bootmod3.net/log?id=5e5107a5c090c6505e94e79b (around timestamp 90) I have overboost at both these points, and both events are me loosing traction and the traction control kicking in. So the throttle is at 100%, but my RPM is going down because the traction control is trying to regain control. Apparently this makes the turbo spin freely and overboost (?) What do we think about that? Assuming overboosts like this is a bad thing, loosing traction isn't good for the turbo.. ?
Thorbjorn
16 BMW F30 330e M-sport Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs |
02-23-2020, 04:54 PM | #2824 |
Rep 2,639
Yes, reflash the firmware into the agent and then update it, and that did the trick for me.
02-23-2020, 08:03 PM | #2825 | |
Rep 175
Here are 3 Pulls. I notice the knock early on when it drops to 2nd gear, but I am not sure why my boost is so under target. Timing looks decent but best in 4th gear. Would appreciate a trained eye to see if they notice anything. http://www.bootmod3.net/log?id=5e531942d10b43252d323edd http://www.bootmod3.net/log?id=5e531994d10b43252d323ee2 http://www.bootmod3.net/log?id=5e531bfbd10b43252d323ef3
02-23-2020, 08:11 PM | #2826 | |
Rep 1,105
If you aren't familar, you need to do the log in 3rd if 6MT or 4th if 8AT, start at about 2000 or 2500 RPM, floor it (dont roll into it) and log until about 6k or 6500 rpm and stop the log. Get maybe 2 logs like that. Remember to have DSC fully off and place shifter into manual mode. |
02-23-2020, 08:17 PM | #2827 | |
Rep 2,357
MAP[psi] is what is actually going into the engine (post-throttle) Boost[pre-throttle] is exactly that
(A Dane in China) |
hybris204.50 |
02-23-2020, 09:04 PM | #2828 | ||
Rep 474
J. D. Cordier
02-23-2020, 09:35 PM | #2829 | |
Rep 2,639
http://www.bootmod3.net/log?id=5e531...yRnNhBwDMPKGMs Boost is under target on purpose to raise timing, of course fuel might play a tiny part in it (In canada we got winter blend gas in the east so fuel becomes very shitty during winter)
02-23-2020, 09:38 PM | #2830 | |||
Rep 175
02-24-2020, 05:29 AM | #2831 |
Rep 500
Thank you, so nothing to worry about despite the pre-throttle boost being high then?
Thorbjorn
romemedrano117.50 |
02-25-2020, 02:30 AM | #2832 |
Rep 373
my obd agent is at the latest firmware but when i try flash v7.1 ewg map this keeps happening? i have deleted and downloaded the map 3 time, i have also tired to download now flash later nothing works
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
02-25-2020, 06:56 AM | #2833 |
1296
Rep 3,533
02-27-2020, 04:50 AM | #2834 |
Rep 373
thanks bud tried that also disconnected battery nothing worked. SD card was corrupted had to flash it manually all is good now. PTF's guide is great for this
n55david1295.50 |
02-28-2020, 07:06 PM | #2835 |
Rep 521
Got a pull today on 7.1. This is on 93 octane. I see some timing being pulled. Is it much? Could it be due to winter fuel blend?
http://www.bootmod3.net/log?id=5e596488d10b43776c7d9824
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
03-13-2020, 02:06 PM | #2836 |
Rep 1,862
Drives: powered by bootmod3
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
03-13-2020, 06:31 PM | #2837 | |
Rep 643
M235i rwd 6mt
03-13-2020, 06:33 PM | #2838 | ||
Rep 521
