01-10-2022, 07:46 PM | #1 |
Rep 312
Base 328i brakes to 335i / 340i Brembos
I've been eyeing used calipers on eBay for a possible brake upgrade in the spring/summer. A BBK is definitely overkill but I'm wondering when you add up all the additional parts required if you might as well have just bought a kit, which would be all shiny and new.
To be totally honest I'm happy with the brakes and maybe I'm fixing a problem that doesn't exist. But…I can't resist a good deal. |
01-10-2022, 10:38 PM | #2 |
Member
78
Rep 206
I did the upgrade in Canada last year. Sourced parts myself and got a great deal overall which is what convinced me to do this. Parts in the US should be priced similarly/ even better. Infact, a full BBK brand new is pretty reasonable priced in the States the last time I checked. Definitely worth it imo.
You can check my post here: (Canada) F30 328xi M Performance Brake Upgrade https://f30.bimmerpost.com/forums/sh....php?t=1836542
2014 328i xdrive | Black Dakota Leather w/ DIY Blue Stitching | EB Interior trim | M Sport | Lighting | Premium | Driver Assistance | Cold Weather | LCI Tail Lights | M Performance Brakes (Blue) | 340i Muffler
boyerizm243.00 |
01-10-2022, 10:56 PM | #3 | |
Rep 312
I found one from Bryan Kiefer but he's going from Brembo to Brembo. Which seems simple enough, mostly just bolt on. Im thinking going from the single piston floating type will require a bit more work but not sure what exactly. Man plan is to diy it, or at least attempt to. |
01-11-2022, 07:35 AM | #4 |
Rep 145
Aren't they bolt on if you upgrade to the 6 cylinder brakes? Just a rotor size change for the front and rotor and pad for back. Real M sport and the M performance brake package has the same caliper so a video or a post of a 4 cylinder upgrading to either of those should fit your case
https://www.bimmerworld.com/About-Us...t-Brakes/#328i But remember that if the caliper is blue to double check if it's 340 or 370mm rotor for wheel clearance |
01-11-2022, 10:58 AM | #5 | |
Rep 312
I'm wondering if the mounting holes for the caliper guide on those line up with the true M-Sport blue brake calipers. Or if I need to get some sort of adapter. I'm sure this is pretty common upgrade but for some reason I can't find much info on it. |
01-11-2022, 02:54 PM | #6 | ||
Member
78
Rep 206
Only difference in your case if you're going with the BBK is that the rear 345x24mm rotor part number is different for RWD vs AWD. Other than that, If you have all the parts listed in my post, it's a direct bolt on.
boyerizm243.00 |
01-11-2022, 06:05 PM | #7 |
Rep 145
Should be direct bolt. The only ones that wouldn't would be the f80 I believe...
Enter your last 7 Vin into realoem Load up car and go to brakes Select the front brake pad sensor that has an image of the brembos Looking through that, doesn't seem like it shows a bracket or anything so it should be direct bolt on BMW wouldn't provide options for upgrading brakes in a package then make it hard and inefficient for the workers to do it I.e. adding more parts like a bracket vs a direct bolt on |
01-15-2022, 07:55 AM | #8 |
Great Teacher
1086
Rep 1,305
Drives: 06 e91 325ix
Since you have a 2013 I would suggest you read the excellent thread about this
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
02-02-2022, 08:55 AM | #9 | ||
Rep 1,065
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
07-14-2022, 12:43 PM | #11 |
Rep 5,392
If you already have Brembos on the car, say Front 340x30mm, and you upgrade to Front Brembo 370x30 or Rear Brembo 345x24. Then no coding is necessary because those combinations all use the same brake bias setting.
But if you have no Brembos like front single piston 330x24 or 312x24, and you upgrade to a Brembo front, then you need to code brake bias. This is NOT at home coding with BimmerCode or Carly! Typically a shop does it, but it's simple. |
shikelicious4.50 |
