11-23-2019, 10:07 PM | #1 |
Rep 764
pure stage 1 and hpfp
so with the new HPFP option coming out and prices dropping, I've been spinning the idea of a PS1 and HPFP. was also wondering if pure would be willing to mate the PS1 with the better flowing turbofold they use for stage 2 (if even possible), or finding the better flowing M2 turbofold to mate up, but can forsee problems with me being PWG and compatability. sooo, would a PS1, HPFP, pure inlet, and possible turbofold see more than the average 30-40whp gains? or is the consensus still to skip stage 1 and go straight to stage 2. I'm not trying to break the 500whp mark, just looking for fun and reliable.
I was also looking at the new turbosmart BOV to help manage turbolag, being a 6mt I imagine it's worse than AT, but the pictures show a harness like it's for EWG. I e-mailed turbosmart and they said "all bmw's use electronic wastegates", was not very promising.. I'm currently FBO/catless DP running MHD 2+ thanks for any feedback!
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
11-23-2019, 10:14 PM | #2 | |
Rep 529
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
11-23-2019, 10:33 PM | #3 | ||
Rep 764
11-23-2019, 11:33 PM | #5 | |
Gettin It Figured Out
1820
Rep 2,669
Spool Performance Several Threads on the B58 2nd Gen evo6 HPFP (needs a little physical modification to PnP, no special tuning needed) .
11-24-2019, 12:52 AM | #6 | |
Rep 5,392
Oh and the cable that you see in the photos doesn't matter. It just happens to be a little longer than necessary but that's no big deal. Hope this helps! |
11-24-2019, 12:53 AM | #7 |
Rep 52
That b58tu/evo6 pump is like searching for a needle in a hay stack I looked but could not find any.. As for the spool pump been waiting also but doesn’t look like it’s going to come out anytime soon
11-24-2019, 02:57 AM | #9 | ||
Rep 764
so many threads say to skip ps1 over ps2, I'm just worried about the additional lag introduced, especially for the 6mt essentially releasing boost between each gear change. was wondering if the added benefit of a better flowing exhaust manifold and hpfp would actually benefit, alot of the ps1 results were FBO and tuned.
11-24-2019, 05:59 AM | #10 | |||
Rep 5,392
See attached photo. You can clearly see the electrical connection on the stock Diverter Valve. The Turbosmart puts the same electrical connector on the end of a small cable instead of embedding it on the unit itself. |
11-24-2019, 06:05 AM | #11 | ||||
Rep 5,392
11-24-2019, 06:52 AM | #12 | |||
Rep 5,392
Unless those fuel starvation symptoms are felt, upgrading the fuel pump on a stock turbo car would provide no improvement. You'd never hit the threshold where more fuel is needed. The stock turbo never supplies an over abundance of intake airflow that the stock fuel pump can't easily handle. Also I did not fully understand the turbo sizing until I spoke with Pure Turbos. I suspect that guys might be making incorrect comments based on incorrect assumptions. Here's what they said: 1) Early N55 PWG Engine- comes with the smallest capacity turbo along with the smallest 3.5" exhaust outlet to its downpipe. 2) Later N55 EWG Engine- comes with a higher capacity turbo along with a larger 4.0" exhaust outlet to its downpipe. (Provides less back pressure to the turbo so higher airflow meaning more horsepower.) Essentially Turbo#2 = Turbo#3 3) Pure Turbos N55 Stage1 Turbo- is about the same size as the N55 EWG stock turbo. So this is often a point of confusion. PureStage1 IS an upgrade to a N55 PWG. But would be a lateral move for a N55 EWG turbo. No real improvement. So if someone says that it is not worth it to upgrade to a PS1, that's only correct if they are saying it to a person with an N55 EWG engine. A Pure Turbos Stage1 upgrade would be a noticeable improvement to someone with an N55 PWG. 4) Pure Turbos N55 Stage2 Turbo upgrade- has a higher capacity airflow so more potential horsepower. But that level of airflow exceeds the maximum capacity of other components forcing them to also be upgraded to achieve higher horsepower. I've read that you can still drive a PS2 with most of the stock components and feel a power improvement, but really you gotta start upgrading things like Diverter Valve, turbo inlet pipe, intake sensors, (expensive) fuel pump, and begin entertaining expensive exotic fuel options other than 93 octane pump gas. Hope this helps! |
Jake From State Farm54.00 akgambino271.50 |
11-24-2019, 07:06 AM | #13 | |
Uhh... Khakis?
54
Rep 155
johnung4528.00 |
11-24-2019, 10:08 AM | #14 |
Rep 764
@johnung
most oem turbos do fine with the regular HPFP because the tunes are designed to taper boost to not crash the HPFP in the higher RPM range right? user BMWDIYGUY saw decent gains on just his XDI HPFP upgrade. now if I'm PWG going PS1, and HPFP, and if possible a better turbofold.. are the gains really going to be on par with other PWG to PS1 users still, or better? and on the topic of the turbofold, realistically, unless I can find one (and IF this would actually work) at a very low price, PS2 would likely be the better option. just trying to stay at a reasonable budget when I don't have crazy power goals.
11-24-2019, 11:01 AM | #15 | |
Uhh... Khakis?
54
Rep 155
As others have mentioned you can retrofit a B58 HPFP that flows much better and will save you a lot of $$ if you’re sold on the HPFP option. |
11-24-2019, 07:35 PM | #16 | |
Rep 529
You are chasing a dead end here with trying to justify needing to upgrade stock hpfp on stock turbo or ps1. Ps1 is essentially equivalent to stock ewg turbo, stock ewg turbos get maxed out without hitting fueling limits. Find a competent tuner, get the ps1, custom tune it for your fueling and ambients and you will be good to go. Also, I think somebody posted about upgrading lpfp... also a waste of money with your proposed setup.
11-25-2019, 01:51 AM | #17 | ||
Rep 764
11-25-2019, 10:14 AM | #18 |
Rep 1,348
Question , Pwg stg 2 and Ewg stg 2 are they different in any way other than the exhaust outlet?
2k15 335i Msport xdrive 6spd
11-25-2019, 11:55 PM | #19 |
Rep 764
from what I've read, yea, just the 3 1/2" vs 4" downpipe connection is the only difference
11-26-2019, 07:07 AM | #20 | |
1820
Rep 2,669
quite a bit of talk concerning design back when SpeedTech launched their design... Start HERE post #59 .
11-26-2019, 11:47 AM | #21 | ||
Rep 764
