03-17-2020, 10:40 PM | #2949 | |
Rep 80
The command below sent with root to the terminal should give you the foreground app package name. PHP Code:
F20_M135i100.50 |
03-18-2020, 12:32 AM | #2950 | |
Rep 551
Thank you for these useful details; I do not yet have a perfect command of TASKER but the variable should actually be the solution because until now I used:
I will resume my TASKER test but not before 3 weeks! because I have bricked my PX6 RK3399 unit, and it's screwed up ... So I switched to the S625 unit. I can talk here about the possible difference and improvements (I'm staying with Android 9.0 for now) See you later friends ! |
03-18-2020, 09:23 AM | #2951 | |
Rep 67
F20_M135i100.50 |
03-18-2020, 11:07 AM | #2952 |
Rep 551
HI
Ah sorry ... I played too much with my screen and I lost, I had to desolder and then solder the OTG resistance to solve my bootloop problem, but since I didn't know how to do it ... I had to give up the PX6 Rk3399 but I certainly will probably have to post tasker because the one I will receive seems to be with firmware 2.0.3 while we already have 3.8.7 on the S625 |
03-18-2020, 11:26 AM | #2953 |
Rep 1,048
Before you throw it away i`ll take it Kri |
F20_M135i100.50 |
03-18-2020, 11:47 AM | #2954 | |
Rep 80
03-18-2020, 12:04 PM | #2955 | ||
Rep 551
Do you want my profiles + tasks in .xml format? |
Kri1083.50 |
03-19-2020, 01:24 AM | #2957 |
Rep 551
For me here it will not help me anymore, but let's think about the community that might need it, so here are my TASKER backup on a PX6 RK3399 just before "the final crash":
https://www.cjoint.com/c/JCtgwtScS5N As it is the entirety of the saved data, it is necessary to make the sorting (with certain profile which activates / deactivates the music launcher at startup or the navigation button which is configured for Spotify) and it's in french |
Shrazy12.00 |
03-19-2020, 09:02 AM | #2958 |
Rep 114
03-19-2020, 10:57 AM | #2959 |
Astronaut
514
Rep 732
Hey guys,
I've been trying to work with Avin about updating my 9.0 unit but I've been running into issues. Every time I run the update, I only get 3 UI (NBT, EVO, and something else I can't remember) Do we HAVE to upload the OEM file after installing a software update? When I upload the OEM file, the only UI I have is ID6. According to their pictures, I'm doing the update correctly. I don't have issues with the unit accepting my USB drive. I keep getting the same copy and paste from AVIN which is starting to get irritating at this point. They said if the update was done successfully, I should have AV8 UI. Can someone post a picture of what this interface looks like? |
03-19-2020, 01:23 PM | #2960 | |
Rep 71
03-19-2020, 05:27 PM | #2961 | |
Astronaut
514
Rep 732
I ran the update, didn't load the OEM file, and just re-loaded Carplay. It'll hold me over lol. |
03-19-2020, 07:29 PM | #2962 | ||
Rep 71
Gabo
03-21-2020, 04:04 AM | #2965 |
Rep 551
03-21-2020, 04:31 AM | #2966 |
Rep 40
03-21-2020, 04:40 AM | #2967 |
Rep 86
03-21-2020, 11:17 AM | #2969 |
Rep 43
i buy for my F45 an android chinese px6 rk3399 unit
this is the link for the unit : https://a.aliexpress.com/_TJCTp i install it, it works, but i have the problem with NO SIGNAL message, but this message it appear only when i run : WAZE or GMAPS(gmaps sometimes it works for 30min and after it gives me NO SIGNAL) also i test with : tiktok(no signal), if i try youtube it works like a charm... this is the photo with no signal message: https://we.tl/t-1wvZNUT1F8 this is the photo for android version: https://we.tl/t-63pk1lEtZr this is the photo for MCU version: https://we.tl/t-QAScIqAzdX photo for factory settings menu https://we.tl/t-baNnMHPOyk photo for nbt screen option https://we.tl/t-h6IqZXtlZi Please tell me where to start, i buy this unit for the larger screen and navigation with WAZE i talk with the seller and he provided me a link with the firmware .. if it help someone http://w.mail.qq.com/cgi-bin/ftnExs_...1390d,0a90c310 i didn`t test it. please help !!! |
03-21-2020, 12:06 PM | #2970 | |
Rep 87
In build.prop I saw that timezone is set to Asia/Shanghai, and I thought that may be connected. But I wasn't able to change build.prop file |
