01-04-2022, 02:04 PM | #1 |
Rep 3,129
NEW RELEASE: Dinan Ignition Coils
Dinan Ignition Coils for Nearly all Modern BMW's Part Number(s):
Application(s) by Engine:
Product Page(s) / Pricing: dinan.info/coils Release Date: Available Now! Description: Dinan Ignition Coils are designed to be a direct plug-and-play replacement, or upgrade, to factory coils and provide greater energy output. With up to 10% more energy output then stock you are ensured a stronger and more consistent spark. Whether you are replacing dilapidated coils that are causing sluggish acceleration and/or misfires or simply upgrading for a more reliable and consistent spark your ignition system will be more efficient with a new set of Dinan coils. For those that like to showcase engine modifications they even come in a variety of unique housing colors to choose from for that personalized touch! Features/Benefits:
01-04-2022, 02:12 PM | #2 |
Rep 558
Higher performance than OE, they come in colors and they are competitively priced. What's not to like? They're on my list for my next spark plug change at 60K mi.
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
01-04-2022, 02:49 PM | #3 |
Rep 3,129
whoismorggan553.00 |
01-04-2022, 06:01 PM | #5 | |
Rep 176
01-05-2022, 03:44 PM | #6 |
Rep 54
Drives: 2017 M240i xDrive
Already have the red ones ordered! Will install with new NGK plugs as soon as they arrive.
01-06-2022, 04:49 PM | #7 |
Rep 1,065
Standard stock dwell tune for these ? Curious for some of us with n45/n55 and have retrofitted the b58 Eldor coils to our cars
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
Pussiwillow521.00 |
01-07-2022, 10:01 AM | #9 |
Rep 190,807
Nice
eluded3043.00 |
01-08-2022, 10:28 PM | #10 |
Rep 565
Drives: G20 M340i
Just ordered a set! Was about to pull the trigger on some Bavarian branded ones until I saw these. Can't wait to install along with some new NGKs.
01-12-2022, 01:35 PM | #12 |
Rep 3,129
Graph in the post above shows output/performance vs a stock B58 Eldor coil. As far as lasting longer— that really depends on usage but should be the same or better given the same running conditions. Dinan and sister company APR have been using these coils (or like ones in the case of the VAG platforms) on all of our vehicles for a year or more without issues though
01-12-2022, 03:57 PM | #13 |
Rep 10,352
The question you should be asking is exactly how any "perdormance coil" can increase the operational life or the quality of a spark coming off a plug.
"Drive more, worry less. "
01-27-2022, 06:26 AM | #15 | |
Rep 141
01-27-2022, 06:56 AM | #16 |
Rep 3,129
If you are having misfires or running rough in general then replacing the coils would assist in rectifying the issue. Same as with OEM coils. The Dinan coils offer more output energy which would assist in higher output builds where the OEM coils may have some issues but generally speaking the advantage is in price and customization (colors).
As far as compatibility... it depends on generation of X5M. E70/F85 - Technically compatible but may require modification (removal of a molding rib). Investigation into viability of a running change to remove this rib for future production is underway. F95 - Not compatible. Newest gen N63TU3/S63TU4 (X5M/X6M specifically) coils being investigated. |
BMWApp224.00 |
01-28-2022, 05:55 AM | #17 | |
Rep 296
Thank you! |
01-30-2022, 04:06 PM | #18 |
Rep 75
Have a coil/plug service that I will be doing shortly on my 340xi with 82k on it (plugs were replaced at 55k according to records). Figure that this is the time for new coils, question though, what plugs do you recommend with you coils?
B58 parts477.00 |
01-31-2022, 07:46 AM | #19 | |
Rep 3,129
Stock plugs is what all of our testing has been done with. |
luke1990132.50 |
02-28-2022, 12:02 PM | #20 |
Rep 237
Drives: 340i xDrive Stage 1
Got these into my 2016 340i xdrive when I was doing my coils and plugs at 60k. I drive my car pretty hard, plus I have Dinan stage 1 tune. So far 3000 miles on it, drives well, no complaint, 100 bucks cheaper than the oem coils I returned. Definitely recommend it, I bought the red ones, looks real good.
03-01-2022, 02:34 AM | #21 | |
Rep 141
-Ricky Bobby. |
03-04-2022, 09:43 AM | #22 |
Rep 1,909
LOL perhaps this was intentional in order to make the new red dinan coils look better?
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost. Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold) |
