BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > F30 N55 PURE stage 2 turbo dyno results
      03-22-2016, 10:38 AM   #111
Mike@N54Tuning.com
Drives: 2007 335i, 2015 M3
Originally Posted by ClevelandBeemer View Post
You need a flash tune to accomplish that.
+1
The JB4 does not remove the limiter unfortunately. Only an ECU flash can do that on the FX platform.
Mike
      03-22-2016, 12:28 PM   #112
Info@EnzoPerformance
Info@EnzoPerformance's Avatar
587
Drives: F10 M5 700R+
Originally Posted by oguz kuruca View Post
My car has the limiter, even with the JB4 I'm still stuck at 131MPH did any companies came with a fix to that?
We can take care of that. We also offer Pure Stage 2 tunes and have been for some time. Our tunes are also OBD emission friendly.
      03-22-2016, 03:35 PM   #113
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
I'm testing out my limiter at Lime Rock after Enzo tune this April, so will let you know.
PPK may have raised it to 155, which is what I had before, but if Enzo can confirm, it should be gone now...
SOLD: 2012 335i Mineral Gray
      03-22-2016, 08:09 PM   #114
arwin
Drives: 2017 AW M2
This might be a dumb question, but I currently have the Dinan stage 2 with Dinan CAI and MPE.
If I wanted to upgrade the turbo to the Pure Stage 2, which components would I need?
Can I run this Pure Stage 2 turbo with the Dinan stage 2? Or would I need to remove that and get a JB4?
      03-22-2016, 08:18 PM   #115
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
Depends how far you want to take it...
- ER Charge Pipe
- GFB DV+ (upgraded Diverter Valve)
- Maybe Intercooler
- Possibly upgraded plugs
- Possibly PDU's PI Kit
- Possibly Upgraded LPFP
You'll have to ditch Dinan and either go JB4, Flash Tune or Flash Tune with JB4 as a boost controller.
My Build Thread can be found HERE
      03-24-2016, 03:16 AM   #116
Bowser330
Drives: i3 REX
Originally Posted by shivaswrath
Originally Posted by Bowser330
Originally Posted by wakebord99
Do we know how much HP/Tq the X-Drive + AT setup can handle before we start breaking stuff?
I'ld imagine AWD + 500 Ft Lbs + No Tq limitation = 0-60 in the 3 second range, and 10 second 1/4 miles...
+1 pure turbo f30 335xi is a poor man's GTR. Weight is nearly the same, dynojet dynos from the same specialty-z dyno have very similar curve profiles.
It would be really cool if it could 0-60 in sub 3 like the gtr. 2014 335i's have launch control right? Do xi's?
F30 335xi
Pure stage 2
Downpipe
Chargepipe
Methanol or fuel pump upgrade
Upgraded axles
ZF8 TCU flash tune (availability?)
Upgraded rubber
500+whp/500wtq
$7-8k estimated parts cost.
You will not be getting GTR times with the xDrive 335i!!
Help me understand why, what's holding back the f30xi 0-60 from being gtr quick ?
I read that the zf8 is the same as the one in the rs7, sure it might need some beefing up but the rs7 parts are available, right?
      03-24-2016, 10:33 AM   #117
587
The GTR DCT transmission was co developed by BorgWarner, the same team who developed the Bugatti Veyron DCT Trans. It is an impressive piece of racing machinery. Purpose built for shifting fast and withstanding serious abuse.
The ZF8 transmission has a large range. 8HP45-50 in most N55 models is made to handle 400 ft lbs of torque and maintain great gas mileage. the 8HP75, most likely in the RS7 has beefed up valving, internals etc.
Upgrading the 8HP in the BMW lineup is something we are working on. Unfortunately it's not as simple as slapping some parts together and getting GTR like performance.
      03-24-2016, 11:09 AM   #118
TANG2864
Drives: 2015 F32 435i Coupe "4DIRTY5"
Do you offer just a speed delimiter, or does it only come with the flash tune?
2015 Jet Black F32 435i RWD Coupe - MPPK | MPE | JB4 | M4 437m Wheels | BMS Intake | Wagner Tuning Downpipe | Black Stepped FMIC | Evolution Raceworks Chargepipe | Machnt Schnell Air Scoops | BMS Sport Oil Cooler Thermostat delete | H&R Sport Springs | Best 1/4 et: 12.1s
      03-24-2016, 11:16 AM   #119
Luminous
Luminous's Avatar
743
Drives: 2019 M5 Competition
My car is xdrive and came with all seasons so was limited to 130mph, I can confirm that the the Enzo tune removes the speed limiter
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      03-24-2016, 02:43 PM   #120
shivaswrath
Drives: 2012 335i
You sort of answered your question - drivetrain, parts, etc.
      03-24-2016, 07:28 PM   #121
Bowser330
Drives: i3 REX
Ok so your primary concern is the transmission, seeing as the parts are readily available I can't imagine it would cost that much to beef up the trans or swap out stronger axles, they already sell upgraded axles for these cars.
      03-24-2016, 07:49 PM   #122
ChaiLatte
Drives: E90 Xi
Love seeing the newer models getting pushed making me want to get a newer 335.
      03-24-2016, 10:30 PM   #123
Bowser330
Drives: i3 REX
Thank you for the details.
Looking forward to seeing what you guys come out with.
      03-25-2016, 11:11 AM   #124
erko1905
Drives: Not a bmw
Maybe slightly off topic here but would anybody happen to know a reputable tuner who can bench flash/tune a FBO-ish pure stage 2 turbo car in the NYC/north NJ area (not Enzo, somebody who'd work on a 2013 pwg car) ?
I did a quick search around in the forums, seems like GSR+Mission are on the West Coast, Eurocharged is in Texas, ACF is in Illinois, and that seemed about it.
      03-25-2016, 11:17 AM   #125
ronanz
ronanz's Avatar
ACF is out of Brazil, they make "House Calls" here in the U.S...
      03-25-2016, 11:20 AM   #126
erko1905
Drives: Not a bmw
Yeah that makes more sense thank you
      05-03-2016, 10:46 AM   #127
Krash92
Krash92's Avatar
Drives: 2013 F30 M Sport
Question for the forum. I'm planning on doing the Pure Stage 2 turbo upgrade as well as the Port injection upgrade. Since I'm not doing them both at the same time 6-12months apart. What would you recommend doing first?
]2013 F30 M SportMods; DocRace Topmount Turbo, Stage 3 Fuel pump,Fuel it Port injection with 500 injectors, Jb4 stage 2, MHD tune, Challenge downpipe, KSport Air ride, Borla Atak. Evolution Racewerks FMIC & charge pipe, M Factory LSD, H&R front & rear swaybar, Turner Front Strut brace, 19" Avant Garde 359 , Carbon fiber hood, spoiler,diffuser & side mirrors, side skirts, white front splitter.
      05-03-2016, 01:37 PM   #128
Chicken_Joe
Chicken_Joe's Avatar
Drives: 2013 F30 335i M Sport. EB 6M
Probably PS2 turbo imo. That way you can dial in the turbos for optimal usage without the PI. To me port injection would be rather pointless unless you need it and the stock turbos will max out before you need PI.
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
      05-03-2016, 01:54 PM   #129
Luminous
Luminous's Avatar
743
+1
Upgrade the turbo first.
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      05-04-2016, 09:42 AM   #130
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
Indeed turbo first!
      12-27-2016, 04:00 AM   #131
jasonwang115
Taiwan
Drives: 2012/09 M135i 6MT
2012 F20 M135i N55 pneumatic wastegate, pressure value of more than 1.3bar will automatically pressure relief , I am not using pure stage 2, if I use pure stage 2 can solve the problem? or loaded JB4 can be resolved?
Thank you all
      12-27-2016, 11:23 AM   #132
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
Thank you all
You need to get the N20 T map 3.5 bar, and go into your jb4 user settings you will see N20 T map (0/1).
Type 1 in the box and hit save after installing your t map and you will now be able to exceed 21psi without dme freaking out.
FBO-PS1 and stuff
