12-14-2014, 08:20 PM | #1 |
Rep 864
x328x's Work In Progress
Hi everyone
Mods I have done so far - M Performance front splitter - M Performance rear diffuser - M Performance side skirt decal - M Performance gloss black grill - M grill decals - JL Audio Amp and Sub upgrade - BMS JB4 + bluetooth kit - LCI AC Surround Trim (with ambient lighting) - Running Torque Pro App - F80 lip spoiler - Now replaced with Carbon Fiber Spoiler - M performance side skirt extensions - Remus 335i exhaust with 3.5 inch carbon fiber tips - Wagner catless downpipe - M performance illuminated door sills - Luxury line B pillar ambient lights - Rear skirt extensions to suit M performance diffuser - Carbon fiber mirrors - Carbon fiber Eye Lids - Door projector puddle lights WIP -carbon fibre interior trim Mods to do - intercooler - charge pipe I will be adding to this thread as I do my mods Last edited by x328x; 07-11-2019 at 09:04 PM.. |
12-15-2014, 02:19 AM | #2 |
Rep 806
Drives: 2016 lci m3 mw
Looking good, here's a exhaust I will be getting next year
http://www.eisenmann-sportauspuff.de...W_F30_328i.php
f80 m3 lci mw
12-15-2014, 05:02 PM | #3 |
Rep 170
Drives: 2014 328i Estoril Blue
Very nice! and close to where I want to get to as well!
Could you do me a favour and take another shot of the side decals that shows the bottom edge clearly? I'm in two minds as to whether I can/should apply decals with /without the side skirts. TBH I'm not sure I want to pay for the side skirts and would be great to see how she looks just with the decals. I also noticed you're not going to put on the "Mperformance" lettering on the sides? Is everything OEM, or did you get any aftermarket parts? |
12-15-2014, 08:48 PM | #4 | |
Rep 864
thanks. Yeah I think I have seen a couple of reviews. heard good things. Ill probably get the DP and a axle back system i.e. M Performance exhaust and see how it goes. |
12-15-2014, 08:56 PM | #5 | |
Rep 864
In terms of installation, I did it myself. The biggest tip, wet both surfaces car and decal with water (drop of detergent). It slides around and falls in place. Then start from the middle with a squeegee and work your way out. I would say its easy to install. Yeah I left out the M Performance lettering on purpose. The rear diffuser and grills are OEM. Front splitter is not. The decals I got from a seller from the UK, not sure if it was OEM but it was cheaper than BMW. Last edited by x328x; 12-15-2014 at 09:01 PM.. |
01-09-2015, 05:18 PM | #10 |
Rep 864
It's a bit hard to say because I traded in my car. I would say 72 k drive away 4 years free servicing. My advice, go towards the end of the month because the dealers may have quotas i.e. if they hit a certain number bmw Australia give rebates to the dealer. So they are desperate during those times and willing to deal. These incentives might not be there every month, but it was when I was looking and it helped
01-09-2015, 05:39 PM | #11 | |
Rep 806
f80 m3 lci mw
09-15-2015, 06:17 AM | #14 |
Rep 864
just installed the trim. Connectors can be a little tricky to pull out. But overall quite an easy install
Havent connected the ambient lighting yet. Still need to source the connectors from the dealer |
09-15-2015, 07:26 AM | #15 |
Rep 1,977
Drives: 2020 M2C HS & Ferrari Roma
Very nice the gloss black ac trim definitely looks a lot better than the dull plastic one.
I bought the gloss a/c trim for my car as well, how do you separate the A/C and CD controls from the old trim? I've taken mine apart but struggled to transfer the controls over to the new trim so I just put the dull plastic one back on |
09-15-2015, 08:13 AM | #16 | |
Rep 864
So start with the CD controls. U will see about four or five tabs. Use a small flat screw driver and lift the tab and push. It should pop out a mm or two. Start from one side and work your way down. Now take a look down the bottom of the CD control unit and you will see some clips. Use a flat head to pop them open and push the unit and the bottom should start popping out. Once u get the CD control unit out, the AC unit comes out the same way. Hope that helps |
09-16-2015, 08:14 AM | #19 |
Rep 4,021
Drives: F32 Coupé
Are you IRONMAN???!!!
09-16-2015, 10:09 PM | #20 |
Rep 864
09-16-2015, 10:33 PM | #21 | |
Rep 4,021
Drives: F32 Coupé
09-17-2015, 08:22 PM | #22 |
Rep 3,288
Drives: anything given a chance
