06-30-2019, 03:39 AM | #2 |
Rep 3,679
It would blow up if you sprayed any amount that would be worth the bump in power.
jovanf301.50 Silverlining_m21734.50 |
07-01-2019, 08:16 AM | #4 |
Rep 420
09-27-2020, 05:31 PM | #6 |
Rep 1,060
It'll work but your limited to a shot that would put you under 350whp and not spray below 3k or so due to tq on the rods and bolts which is the leading cause of this motor failing (rod bolts with high amounts of low end tq).
Bm3 stage 2 and NO2 (should be nothing more than about a 50 shot) would be safe in theory but a 100 shot should be able to work if you changed rod bolts minimum).
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
09-30-2020, 03:49 PM | #7 | ||
Not stock
474
Rep 614
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
