08-13-2021, 03:27 PM | #1 |
Rep 45
Do not go to the dealer!!!
Hey guys,
So, I went to the dealer to get the M-Performance BBK installed on my 2016 340i that I bought and have the brakes coded, bled etc.. I only asked them to install all the brakes, bleed them, code them in and then the bedding process, cool. I get the car back 3 days later and i notice the turn on screen is different. Apparently they loaded the new software on my car without me telling them too. So when I stopped the car half a mile a way from the dealer to flash BM3, the flash failed. When trying to flash stg.2 stg.1 and stock map, it would make it to 3% and then say flashed failed. The car screen had multiple malfunctions on it and the car wouldn't turn on. I then have it towed back to BMW thinking they would be able reflash the DME at least but they said nothing could be done and they wanted to quote me for a new DME. After that i get my Car towed back again from BMW to my place so i can find someone to unbrick and bench unlock my DME. I take my DME today to a BM3 authorized dealer in Houston, 3 Hrs away from where i live, this morning to see if they can help. They worked on it for hours and hours and weren't able to even unbrick the DME. So now my DME is locked completely and i have no running car lol. The turner was telling me that BMW came out with a stricter software to block access of any kind and lock it down. He's trying to help me by reaching out to his contacts around the country. Long story short, do not go to the dealer, especially if you are tuned, they will load the software without telling you and you will not be able to flash. And if that does happen to you, then DO NOT attempt to flash the DME until you bench unlock it. If anyone on here knows of anyone who could help me out, that would be much appreciated as well, thanks! |
08-13-2021, 03:32 PM | #2 |
Rep 4,456
Yeah I read about them starting to do this.
They probably did not do it intentionally. Its probably part of the software package they used to update the car for the brakes. |
08-13-2021, 03:36 PM | #3 |
Rep 45
08-13-2021, 06:35 PM | #4 |
Rep 4,889
I'd have to say if I couldn't load BM3 back into my car, I'd have to burn it. It's just so underwhelming in stock form now!
imperfectluck426.50 |
08-13-2021, 07:09 PM | #5 |
Rep 45
08-13-2021, 10:01 PM | #7 |
Rep 421
Drives: 2017 F31 328dx
When you install the M Performance Brakes you have to VO code them in. Probably updated it then.
08-13-2021, 10:08 PM | #8 |
Rep 45
yeah i wish they would've told me they updated it beforehand because i've taken it before tuned and they knew not to mess with the DME but i also wish i would've thought through it before i tried to flash but here i am stuck lmao
08-13-2021, 10:10 PM | #9 |
Rep 45
yeah i've been in contact with them back and forth but it's hard because i have work as well but they are trying to help me at least get it unbricked so i can at least drive my car.
08-14-2021, 12:39 PM | #11 |
Rep 198
Something similar happened to my 2016 340i, but i was trying to reflash some changes myself. I dont recall exactly what happened but I did something that caused the flash to fail and then after multiple tries of recoding they would all pause at 3% and fail. I must have tried flashing over a dozen times. And tried everything, leaving my car battery unplugged for an hour. force flashing. Downloading the flash. I eventually let the car sit overnight and tried once again in the morning and like a damn miracle it actually went through.
2016 340i / M-Sport / Track Handling Package / MPPSK / AA DP / CTS Intake / Bootmod3 e30
Uni-Rapide71.00 |
08-23-2021, 05:52 PM | #12 | |
Rep 10,269
- ISTA told the technician that the vehicle programming has to be upgraded before M Performance brake coding procedure - Vehicle programming was done (all ECUs) - Then brake coding procedure was performed Fairly standard process. As with any modification, it's "pay to play". |
08-25-2021, 12:37 PM | #13 |
Rep 2,485
Drives: 340Xi MG 2017
If you go to the dealer and dont know precisely what they're gonna do (i.e. anything but an oil change), flash stock first.
But the software update on the dealer end usually fails when the stock map is not detected. So I'm having a hard time understanding what really happenned. But sorry about your luck.
08-26-2021, 06:34 PM | #14 | |
Rep 45
08-28-2021, 02:50 AM | #15 |
2JZ-GTE
3057
Rep 4,009
Ask them not to flush it with the latest version of software. If they refuse, remove the DME before service.
09-01-2021, 01:32 PM | #17 |
Rep 39
I had the same thing happen to me about 3 or 4 months ago. Had to remove the DME and sent it to Kies Motorsports for them to unlock. Cost $250. Sounds like BMW may have a more strict lock down now maybe.
09-01-2021, 06:40 PM | #18 |
Rep 45
Yeah i had to ship it out to Mission Performance out of Cali to unbrick and unlock it lmao, now trying to see if BM3 is possible to flash again cause im trying to go through this again smh
09-03-2021, 07:06 AM | #19 | |
Rep 2,485
They should make an OBD port lock; where one could physically block access to the OBD port. That would be quite the insurance policy ;p
09-03-2021, 10:31 AM | #20 |
Rep 205
So is it possible (yet) to bench unlock a dme with this new software update? Same scenario for me where service led to a new update (I noticed it on the iDrive screen immediately turning it on).
I'm currently stock but was about to send it to Kies Motorsport to unlock for BM3. I'll reach out to Kies to ask but curious if anyone knows if an unlocked DME is always unlocked or how that works.. |
09-03-2021, 10:35 AM | #21 | ||
Rep 45
side note: when i tried to contact Kies, they never responded to me lmao |
09-03-2021, 11:26 AM | #22 | |||
Rep 205
I thought if your dme is unlocked, you could flash it with whatever hence it being unlocked ? |
