11-20-2015, 03:17 PM | #1 |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
ECU Explorer Review (Modifying VMax and other locked DME parameters) [In Progress]
Hi, as many coders are already aware, the F series BMWs have time locks built into the DME, prohibiting reading and writing of certain parameters such as ISN (secret key), VMax (electronically limited top speed) and KAT (delete the painfully annoying CEL and fault due to sport or catless downpipes). ECU Explorer is a tool designed specifically to read and write the internal eeprom of the DMEs used in many current BMW models. The eeprom is where the hour counter is located, using this tool should allow you to reset your hour counter therefore unlocking time locked parameters such as VMax.
So far I have successfully removed my DME from my car (with some awesome help from dd1981 , opened the case, shorted the required pin and connected to my computer, unfortunately by the time I got there I ran into software problems and decided to hold off until I had more time. Since, I have gotten my car back together and running perfectly with no faults, and also figured out the next step in the software. The hard part is out of the way, I've successfully done the required physical hacking of the board, all that's left is for me to find time to remove my DME again and finish the process with ECU Explorer. Will post back with an update. If any other users have experience with this tool please post or PM me. I have yet to find anyone to has also used this tool.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
11-20-2015, 03:26 PM | #2 |
Rep 3,089
subscribed!!!! I've hacked lots of things but never my car because frankly I am too scared. Very interested to learn what hacking a DIY'er can do.
11-20-2015, 03:56 PM | #3 |
Rep 902
Hacking your car is always a scary prospect but I've spent a few months researching this, priced the risks and feel confident I can do it successfully on my car. I've already done the hard part, shorting the pin on the board and reinstall it into my car working without faults. Last step is just a few clicks through ECU Explorer.
11-20-2015, 04:28 PM | #4 |
Rep 190,805
Good luck
11-21-2015, 07:57 AM | #7 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
Taking out the DME I think I got this down to 1/2 hour now...
FBO-PS1 and stuff
11-23-2015, 02:37 AM | #9 |
Rep 931
for me, Another way is decrypt the CAFD files in order to edit and upload new DME config via ESYS.....
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
11-23-2015, 11:01 AM | #10 | |
Rep 902
11-23-2015, 11:13 AM | #11 |
Rep 3,947
It's just 'ones' and 'zeroes' man. No big deal. I actually have a two button keyboard just for programming in binary.
In all seriousness, this is good work. Last edited by Polo08816; 11-23-2015 at 11:26 AM.. |
11-25-2015, 10:26 AM | #12 |
Dejan
1753
Rep 4,197
Do share, so we don't have to take out the ECU again
FBO-PS1 and stuff
11-27-2015, 09:09 PM | #13 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
this is interesting!
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
11-29-2015, 08:36 PM | #14 |
UnderminE
17
Rep 63
Time to chime in, first off I don't mind pulling out my DME or even buying another one to test on.
I was looking up BootMode on Flashtec, and a method for direct connection. http://flashtec.ch/boot-tricore#tricorecarlist E-Sys sounds great but no one has been able to reset the time lock with E-Sys like you could with Tool32, either way we have work to do. Does any one have a working copy of ECU Explorer that they could share, please PM me! |
11-30-2015, 02:11 AM | #15 | |
Rep 902
11-30-2015, 05:38 PM | #16 |
UnderminE
17
Rep 63
Got it, I don't know of any other alternative and if it really is the best and only option then I will look into the details. I am sure there are a few of you far more familiar with ECU Explorer, feel free to chime in with some feedback, I would like to invest some time into this.
Piggy back hasn't been too bad but I would rather have the ability to flash. |
11-30-2015, 07:40 PM | #17 | |
Rep 902
12-01-2015, 05:24 PM | #18 |
UnderminE
17
Rep 63
12-01-2015, 05:45 PM | #19 | |
Rep 902
Also that's a very different DME than mine. Mine has the circuits on the bottom the the board and the connections on the top. This is the best photo I have right now of what one of the N55 F series DME looks like.
12-02-2015, 09:02 PM | #20 |
Rep 902
Here's a photo of the harness.
12-02-2015, 10:17 PM | #22 |
Rep 902
Sorry, my previous post with the DME image, didn't have the image attached, app was bugging out on me that day.
As I stated earlier, the board looks pretty burned up and melty for this type of high quality electronics.
xxxjecxxx2153.00 |
