10-31-2018, 02:38 PM | #48 |
Rep 494
Quick update:
Received a new map from MHD earlier today, but won't have time to test until this weekend. Will provide results once I compile them.
2016 F80 M3 (Mineral/Full SO)
2014 X5 M Sport (Mineral/Mocha) |
11-01-2018, 03:28 AM | #49 |
587
Rep 898
TheBreeze You're in good hands. The guys over there at MHD will get you set in no time.
The stage 1 logs look pretty close to where I would expect MHD stage1 to behave, the stage2 log however does not. Are you running the 91 or 93 maps? MHD maps are generally more conservative as most of the customers they have are in germany with access to the bahn, so cars get driven harder there.
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
11-01-2018, 02:19 PM | #50 |
Rep 1,048
03-24-2019, 10:24 AM | #53 |
Rep 127
03-24-2019, 10:51 AM | #54 | |
Gettin It Figured Out
1820
Rep 2,669
MHD Tuning , what was your determination? Could you kindly provide some insight on your outcome? .
03-24-2019, 05:15 PM | #55 |
Rep 716
Drives: F90 M5
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct Hmu on Ig: @n55_shayan |
03-24-2019, 05:28 PM | #56 |
Rep 9,004
While I firmly believe that BM3 has better off the shelf maps for EWG, I think this is a lesson that off the shelf is just a starting point, and a custom tune is the way to go.
03-24-2019, 06:20 PM | #57 |
Rep 716
Drives: F90 M5
yea for sure all OTS's are designed to be pretty much just that, a starting point (even though most OTS maps, whether MHD, BM3 are damn near perfect already lol)
03-24-2019, 09:00 PM | #58 |
Rep 439
Drives: 2016 M235i Xdrive 8A
I too actually thought the MHD power quotes were at the wheels.
Does anyone know if JB4 is crank or wheels?
SOLD 23K Black 2013 F30 335XI 8A Msport | BMS Intake | BMS Front Mount | VRSF Charge Pipe | BM3 Tune
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
03-24-2019, 09:59 PM | #59 |
Rep 1,369
Burger Tuning doesn't make any solid claims on horsepower.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
03-25-2019, 12:00 PM | #60 |
Rep 439
I know but the dyno charts on their webpage are those perceived as crank or wheel? Cus the numbers are kinda ambiguous and could be believed in either context potentially.
03-25-2019, 12:24 PM | #61 | |
Rep 9,004
Nothing personal to MHD, but these numbers are hilariously bad though. |
03-25-2019, 12:35 PM | #62 |
Rep 9,004
in terms of peak power, I don't think there is much to be gained - but overall I think there is still some power there.
OTS BM3 M2 Flash (version 5.7) 377whp (converted to SAE and Mechanical HP vs Metric HP) Dyno tune: |
TheJungatron352.00 |
03-25-2019, 02:30 PM | #63 | |
Rep 5,372
All EWG N55s make peak at around 6,000-6,200 rpms. The RWD 6MT non-MPPK N55s show around 285-290whp at 6000-6200rpm, the MPPKs around 305-310whp, and the M2 around 330-335whp. If you draw a line from 5,300rpms to 6,000-6,200rpms and then tailing off like normal, this particular N55 should have probably been making around 335-340whp which is commendable for a conservative Stage 1 OTS tune.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
03-25-2019, 02:48 PM | #65 | |
Rep 9,004
03-25-2019, 04:41 PM | #66 |
Rep 5,372
I think there were something going on with the car or it was heat soaked. I can see MHD perhaps being conservative, but it doesn't make sense to me as to why the curve looks the way it does. It's screwed up. Why would they yank out so much timing to crush the topend power in the N55?
As you saw on the 2 series forum, there's a M235x with a MHD Stage 2 plus E20 making 400whp/450wtq and that N55 is showing peak power in the 6000-6200rpm range with a nice and smooth powerband just like the M2 dyno you posted above.
