BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > OEM Swivel bearing installed - uneven front camber
      04-03-2015, 09:45 AM   #23
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
Originally Posted by Car54 View Post
Wait...I think I found them. $242x2??? No way.
02 Pivot bearing, camber correction, left -30MIN 1 31216856535
02 Pivot bearing, camber correction, left +30MIN 1 31216856537
02 Carrier, right 1 31216853820 +core
02 Swivel bearing, camber correction, right -30MIN 1 31216856536
02 Swivel bearing, camber correction, right +30MIN 1 31216856538
Those are the xDrive parts... the RWD parts are different (and cheaper : ) I think I paid $168 x2
31 21 6 854 199
31 21 6 854 200
      06-07-2018, 08:42 PM   #24
Musashi
Drives: BMW 335i XDrive Laguna Seca
Attachment 1838850
Originally Posted by DVC View Post
I just got my OEM -30Min swivel bearings installed, which are intended to add -0.5 degrees of front camber. After install, my shop naturally did an alignment. The results are perfect, with one exception - but the exception is a little troubling...
Front:
Camber-
left: -1.1 deg
right: -0.6 deg
Toe (in)-
left: 0.12 deg
right: 0.10 deg
Rear:
Camber-
left: -1.9 deg
right: -1.9 deg
Toe (in)-
left: 0.14 deg
right: 0.16 deg
The troubling part is of course the fact that there is 0.5 deg less negative camber at the front/right. It's almost as if the right -30Min swivel bearing was never installed. (I wish I had an alignment report before adding the parts to compare against, but this is the first alignment the car has received being that it's only a few weeks old.)
On the road, I feel that the front end has more grip when cornering to the right than to the left - but of course it's very hard to objectively tell how much when factoring in my subjective perception knowing that the numbers are off.
My question is, has anyone else seen alignments where the disparity between left and right front camber was a half degree? Being that the car is brand new, is it possible that it came from the factory with approx. -0.6 degrees on the left, and -0.1 degrees on the right?
Same here, but it changed, used to be -0.6 / -0.6 and became -0.9/-0/6 and -1.1/-0.6. Yes it pulls right- enough for me to notice. Took 3 alignments to id this issue.
