BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Pushing around 500-540 whp with custom tune.
      10-21-2021, 06:00 PM   #1
Bmweth24
Drives: BMW F32
After long consideration I have decided to upgrade the hpfp and get a custom tune. I'm going for the Full E85 by Cary Jordan and they said I should be looking around 500whp-540whp. Any tips on running this much power on N55?
2014 m sport 435i rwd fbo upgraded turbo
VRSF Chargepipe, vrsf race fmic, and hi flow downpipe
BMS aluminum elite intake
Stage 2H 93 bootmod3
ngk 97506 Cold spark plugs 0.020
PR Ignition Kit
Vargas stage 1 upgraded turbo
93500 miles
xHP stage 3 transmission tune
3.5 Bar Tmap Sensor
MST Inlet
FTP Outlet
Dorch Stage 2 HPFP
      10-21-2021, 08:32 PM   #2
n55david
n55david's Avatar
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
PR Ignition Kit
93500 miles
3.5 Bar Tmap Sensor
MST Inlet
FTP Outlet
Dorch Stage 2 HPFP
let me know how that goes. they have had nothing but trouble trying to get my car to run on full e85
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      10-22-2021, 12:55 AM   #3
-Eidos
@lbb_kev
491
Drives: 2018 BMW M2 (LBB)
I'm not familiar with the Vargas, but 500-540whp seems high for a stage 1 turbo. Assuming the turbo is good for that power goal at full E85, keep in mind that you might encounter LPFP issues at 500+ whp if you're still on the stock LPFP depending on the tuning strategy.
I'm doing about 600-620whp on full E85 on a Walbro 525 lpfp and it's about at the limit.
Speedtech Stage 3 (8474) | Remus Exhaust | Wagner EVO 3 | XClutch | DS2 + Lift Kit | Nostrum S2 Injectors | TI E5LM | Torqbyte EKP | Intrax 1K2 | SPL | Drexler GT Race Light LSD by limitedslip.de | Schirmer Diff Lift Kit
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
      10-22-2021, 01:16 AM   #4
harkes
harkes's Avatar
China
1078
Drives: M135i, E39 M5, NSX and AE86
Good luck with that. Vargas write 45-70whp over stock on their own website. Cary is quite the sales man
(A Dane in China)
      10-22-2021, 06:34 AM   #5
lens
lens's Avatar
2070
Drives: 2018 340i xDrive
PR Ignition Kit
93500 miles
3.5 Bar Tmap Sensor
MST Inlet
FTP Outlet
Dorch Stage 2 HPFP
Won't happen on a stage 1 turbo, you'll need a bigger turbine, I believe the VTT stage 1 is only slightly bigger compressor.
      10-22-2021, 07:37 AM   #6
Daleb
Drives: M2
You’ll need a stage 2 turbo to make that sort of numbers.
Peter at pure turbos eu makes 530-550whp with ps2, upgraded hpfp and a hcp map on most of the 35i engines they do. Solid recipe to make that kind of numbers.
      10-22-2021, 11:04 AM   #7
5w20
@_sunbish
5w20's Avatar
282
Drives: Bmw 435i & 340i
PR Ignition Kit
93500 miles
3.5 Bar Tmap Sensor
MST Inlet
FTP Outlet
Dorch Stage 2 HPFP
must be using the same dyno as this guy
https://www.2addicts.com/forums/show....php?t=1859639
  • Drive to your nearest e85 fueling station (with a low level of fuel in the vehicle - preferably almost empty)
  • pump 2 gallons of e85
  • pump 2 gallons of 93
  • flash over to bm3 stage 2+ e30 map
  • drive tamely ~5 miles
  • the next 1-2 miles get a little aggressive so that you are hitting some boost
  • get ready to record a log
  • go full throttle and record log
  • come back and post the log
If the log comes back good and you aren't happy, go get your custom e85 tune from CJ for a little more oomph.
      10-22-2021, 01:19 PM   #8
thejeremyman9
thejeremyman9's Avatar
4364
Drives: 2015 BMW 335i
I'll just add +1 to basically everything above:
1. Reaching 500whp with stage 1 turbo will be very difficult/impossible
2. Full E85 will require LPFP upgrade, which potentially requires EKP upgrade as well. Stock LPFP runs out of steam around E70 on stock turbo, maybe a little earlier for you. Plus, lots of diminishing returns after about E50-60.
3. Try the BM3 stage 2+ OTS map before you spend money on a custom tune. (With HPFP and around E50)
n55david1295.50
ronanz1819.50
johnung4528.00
      10-22-2021, 01:29 PM   #9
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
this is all accurate and I've verified this personally
      10-22-2021, 10:13 PM   #10
ZM2
Drives: 2017 LBB M2
And it’ll only get you 440-450whp. What’s another 100?
johnung4528.00
      10-23-2021, 12:17 PM   #11
motivman
Drives: 2022 G80 M3 6MT
I concur. DO NOT waste your money on a custom tune for N55 (especially on stock or stage 1 turbo) ... run stage 2+ E30 octane tune with E50 fuel. I will summarize my experience...
Paul Johnson E50 Custom tune (stock turbo) --- 408 whp
PTF Stage 2+ E30 tune (with E50 fuel) --- 415 whp
I also wouldn't trust any tuner that tells you they can make 500whp on stage 1 or stock turbo, even with fuel e85. Max HP on stock or stage 1 turbo is probably 430whp (stock turbo) and 460-475whp (vargas stage 1).
      10-23-2021, 01:51 PM   #12
lens
lens's Avatar
2070
Yeap, unless you have PS2 or more (GTX800/1000, Speed tech kits, BigBoost kits, Pure800 when they release) custom tunes are fairly à waste of money, the OTS maps are built fairly good, and if it runs like crap with the correct supporting mods and fuel, send a ticket in and the PTF guys will revise the map for you for free.
      10-24-2021, 04:32 PM   #13
ronanz
Gettin It Figured Out
ronanz's Avatar
Drives: 435i FBO PS2 bm3 w/ options
PR Ignition Kit
93500 miles
3.5 Bar Tmap Sensor
MST Inlet
FTP Outlet
Dorch Stage 2 HPFP
+2 on EKP
My Build Thread can be found HERE
      10-24-2021, 09:01 PM   #14
terryd5150
Head Fry Cook at McBurgertown
Drives: 2015 435i M-Sport 6MT
The manifold itself will flow enough to reach those numbers, but I'm not sure the compressor and exhaust wheels on a S1 will flow that much.
Probably hit reversion (exhaust gas backed up into the cyclinders) and sky-high exhaust gas temps before you get that much airflow through an S1.
      10-28-2021, 12:35 PM   #15
Shadysu
Shadysu's Avatar
23
Drives: 2017 M240i
Im on PS2 LPFP HPFP + Meth, 93 made 500 flat on my dyno, I think the stage 1 turbo will blow if you tryn to run it past 450WHP,
If my tuner suggested me to run something like that knowingly it wouldn't/Not meet my goals and have me pay, I'd have major trust issues.
      10-31-2021, 10:26 AM   #16
mike@x-ph.com
mike@x-ph.com's Avatar
Send Cary your mod list and he'll let you know how much power his map can safely make
https://x-ph.com/sale/
Phone number 702-494-9435
      11-01-2021, 10:08 AM   #17
5w20
@_sunbish
5w20's Avatar
282
He already did and was quoted some inflated numbers.
      11-01-2021, 11:49 AM   #18
mike@x-ph.com
Ah, I did not realize, "they" referred to Cary. My bad
      11-25-2021, 12:18 AM   #19
RVA_N55_Fan
Drives: 2016 BMW 435i
I have a similar setup but w PS2. See below. Question is do you guys think I need the turbosmart diverter instead of the BMS bov adapter and is the ekp needed with my fp upgrades? Also should I run eXX mix or 110oct for Dyno max pulls?
Dyno on 12/3/21.
Custom Jb4 map6 currently e30
2016 435i M-Sport EWG MPPK Manual 6, BMS Map 6 BEF-PS2-Race, Pure Stage 2 turbo, Spool-FX150 HPFP, Walbro 535 LPFP, BMS Intake, BMS FMIC, BMS BOV, 3.5 TMAP, ER DP, AA CP, FTP Turbo Inlet, H&R Sport Springs, BMW 335is clutch kit, BMS Clutch Stop, BMS Diff Bracket, BMS Wheel Spacers, BMW SSK, BMW Track Package
      11-28-2021, 09:19 PM   #20
thejeremyman9
4364
Dyno on 12/3/21.
Race gas will work fine for dyno pulls but E85 mix is more sustainable long term.
You need to check with Walbro on the demands of that LPFP to see if it requires a EKP or not.
      11-28-2021, 10:00 PM   #21
johnung
Dyno on 12/3/21.
I'm not clear on when an aftermarket EKP would actually be needed. My Precision Raceworks Stage 2.5 v2 LPFP uses a Walbro 535. Precision Raceworks specifically says that no aftermarket EKP is required.
      11-29-2021, 07:09 AM   #22
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
Dyno on 12/3/21.
when you run a fuel-it setup it's 100% needed. nobody is sure when it's needed with other setups because everyone else seems to do it correctly.
johnung4528.00
