05-25-2016, 04:49 PM | #23 | |
Rep 2,639
To be honest, if you're getting JB4 stage 2, I would just fork over the money and get the ER CP, less problems in the future when it does go, and you won't be cursing as you're stranded, there's a reason why I did my tune last, I bought ER CP and TIC CP to get rid of any worry about plastic things breaking. The very first rule for tuning a car is safety the parts that break first, but I've noticed people are either too cheap or stubborn to, and that common part that breaks, actually breaks on them and they complain about it. If money is tight, wait for a used one to pop up @ half price. |
05-25-2016, 05:02 PM | #24 | |
Gettin It Figured Out
1820
Rep 2,669
This ^^ . All solid advise.... .
05-25-2016, 07:50 PM | #25 |
Rep 923
Been running JB4 + DP on stock charge pipe with no issues after 2.5 years. As others have reported, it can happen on a totally stock car.
GONE: '13 335i X-drive ///M-Sport | GONE: '16 340i X-Drive ///M-Sport | GONE: '18 540iX-Drive ///M-Sport | NOW: '20 X3///M
05-26-2016, 07:37 AM | #26 |
Rep 166
So here is my ghetto prevention method, a strip of rubber and two hose clamps. The leftmost hose clamp is directly around where the clip is, where most failures occur, while the other is around the plastic weld, where others have indicated failures occur. While I realize this is not a permanent fix, it gives me a little more confidence that, IF the CP were to fail, it would not be as catastrophic as if there were nothing there at all. I will also carry an emergency fix kit with me (i.e. duct tape, zip ties, hose clamps), just in case. If this doesn't work I will humbly admit defeat.
05-26-2016, 10:26 AM | #27 | |
Rep 2,639
You're basically only reinforcing the outside of the chargepipe, where you're supposed to reinforce the inside+outside (hence metal as it won't compress or expand unless it's superheated) and you can run as much boost as your turbo can handle. I mean, it's your car, do what you want, but do you REALLY want to be cheap on a safety part for a 50,000$+ car? |
05-26-2016, 10:35 AM | #28 | |
Rep 115,980
Mike |
05-26-2016, 10:59 AM | #29 |
Rep 166
It is my understanding that what causes the failure of the charge pipe is its inability to withstand the additional pressure. By reinforcing the weak point, how can it fail at that particular point? Unless it is being blown off away from the throttle body versus expanding outward away from it. I guess time will tell.
05-26-2016, 11:43 AM | #30 | |
Rep 2,639
05-26-2016, 11:54 AM | #31 | |
Rep 166
We could explore all hypothetical situations, the vendors will continue to tell you to buy an aftermarket pipe to drum up more business, those who have drank the kool-aid will justify their purchase by supporting the purchase of an aftermarket piece, and then there are those who have been running stock pipes for a while now without any issue. Many perspectives to be viewed, but it is unlikely that we will all agree. I get it, buying an aftermarket pipe is insurance, but when my only option is nearly twice as much as everyone else's, it forces me to re-evaluate the need and seek out alternative solutions, that's all. Came here for support, not to be cross-examined. I got what I needed, thank you everyone who contributed. Last edited by DCTepper; 05-26-2016 at 12:00 PM.. |
05-26-2016, 02:23 PM | #32 | ||
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
Just friendly advice from someone who didn't "drink the kool-aid" and actually had a charge pipe failure before buying my ER pipes.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
05-26-2016, 02:23 PM | #33 | |
1820
Rep 2,669
This ^^ Like chaungo has stated, your rubber sleeve solution could possibly allow for shards to enter the throttle body .
05-28-2016, 11:56 AM | #34 |
Rep 88
Mine blew on stock boost. The only mod I had was a cat-less down-pipe. Luckily it blew less than a mile from the house. If I were you, I'd go ahead and upgrade the charge pipe now...
'22 M240i Portimao/Cognac
(Sold) '14 335i Estoril/BK • M Sport • Prem/Tech Pkg • M Perf INTR • VMR V710FF • Shifteck DP (Sold) '95 M3 Avus/Dove • PSS9 • Vorschlag Camber Plates • 3.46 Torsen Diff • etc. |
05-28-2016, 03:18 PM | #36 |
Rep 115,980
05-30-2016, 12:29 PM | #37 |
Dream crusher
984
Rep 2,421
I've ran tunes and piggy backs with psi ranging 13 - 21 driven aggressively, long road trips and stop and go all on stock CP. never blown a stock CP, but that doesn't mean it can't happen. I've ran stage 1 and 2 tunes so far so good. Carry duct tape in the trunk just in case
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
05-30-2016, 03:09 PM | #38 | |
Dejan
1753
Rep 4,197
Drives: 2018 Audi S3
It breaks at the plastic weld and once it seperates there is no going back as the lip is too small and unrepearable. We have his and his retainer clip even broke. I guess figuratively speaking you can get some black duct tape and do like 8 loops around the CP and the throttle body and it wont pop off after it breaks. This brings me to my next comments and point. Modding these cars or "any" cars comes with risk and reward. This is a known weak point for us that are pushing well over 16psi and I am not going to chance getting stranded on the side of road due to the CP blowing. Stage 1 you should be ok with your tune but its a hit or miss. Is the ER piece pricey? Yes...but its more then just a hollow metal tube... -piece of mind -2 weld bungs for meth -no flexing (throttle response imminent) -price is subject to what it is as its the cost and development of it. you think the price is expensive for the piece, unless you are handy in tight spaces and have a place to work and access to tools, this is hands down a PITA to install. Get ready to dish out another $200 bucks or more. Honestly if you are under warranty, and just have JB stage 1, I would not bother. Take off the JB if it fails and have it towed to BMW. Good Luck and hope this helps
FBO-PS1 and stuff
05-30-2016, 03:19 PM | #39 | |
Dejan
1753
Rep 4,197
The THROTTLE response improvement alone is worth the upgrade! A $375 part....I am not going to lose any sleep over it. Lag is a BITCH...period. TO me anything that minimizes it, eliminates it is a win in my book. If anyone wants to "out of warranty" they can help them selves to the nearest BMW dealer and kindly fork over $700+labor or so dollars for the same shit OEM one...end of story.
FBO-PS1 and stuff
05-30-2016, 03:33 PM | #40 | |
Dejan
1753
Rep 4,197
Most of us here are to help each other..take what you can and make it work how you need it for you. I dont think anyone here is trying to criticize your enthusiasm for wanting to figure out a way to reinforce the part. We all wish there was something cheaper...but as YOU and ME and the rest of this community have jobs. I dont have time to dick around my garage and figure out a solution, waste my time and loose family quality time..barely have time to install this on cars. I need 18psi...I spent the money and its there. This game has always been called ''you gotta pay to play"
FBO-PS1 and stuff
05-30-2016, 06:07 PM | #41 | |
1820
Rep 2,669
This ^^ .
05-31-2016, 07:16 AM | #42 |
Rep 1,503
If you message mike from xph, I'm pretty sure you won't pay the $375 retail price.
Also a few hundo for piece of mind might be worth it. It can't be healthy always being scared that you'll blow your cp every time you go into boost
FBO M235i r
F80 M3 |
05-31-2016, 09:06 AM | #43 | |
Rep 115,980
Its not that expensive of a mod in the long run and its in the low 300s from many vendors as most have them for 10% off. I always tell my customers that a charge pipe should be on the list of mods once you start modding. We probably ship (overnight) 1-2 a week to people who have blow theirs and are stranded. Mike |
05-31-2016, 02:47 PM | #44 | ||
Dejan
1753
Rep 4,197
In either case it's not that expensive IMO...prob the cheapest mod besides some little cosmetic bits..
FBO-PS1 and stuff
