01-26-2019, 12:37 PM | #45 |
Rep 340
What did you gapped them at?
2016 435i GC - FBO - PS2 - XDI-35 hpfp - Stage 2 lpfp - M performance LSD -Custom tune BM3 w/ MHD monitor - xHP Flash stage 3 - Valvetronic Design Exhaust
01-26-2019, 12:39 PM | #46 |
Gettin It Figured Out
1820
Rep 2,669
01-26-2019, 12:50 PM | #47 |
Rep 340
Mine at 0.020 and still misfire..
01-26-2019, 01:02 PM | #48 |
1820
Rep 2,669
Hmmmm....I’ve been gapped the same for years with no issues. Plenty of runs up and through Los Alamos into Jemez Springs back to Santa Fe. Not sure if it’s fuel quality related, but...for whatever it’s worth 90% of my fillups are with Shell highest octane available (91oct to E30). Where you filling up? .
01-26-2019, 02:01 PM | #49 | |
Rep 340
I used shell 91.. My tuner suggest I try gapping them 018.. I'll try it later and see how it goes..
01-26-2019, 02:05 PM | #50 | |
1820
Rep 2,669
Are you running E85 at all? If not, gap closer to .24 Sorry OP...thread Jack over... .
01-26-2019, 02:23 PM | #51 |
Rep 931
05-21-2020, 08:24 AM | #53 |
Respect My Authoritah
368
Rep 873
Is there someone that can comment on the tune quality of each? I'm currently running BM3 and am somewhat dissatisfied. The new map revisions are fast, but I'm stuck running an older revision in order to avoid the HPFP dip seen in the newer revisions. I've always had issues with cold start RPM fluctuating while driving away form my garage... like a novice manual driver that jerks the car when taking off (only happens once per cold start). Data logging is dangerous with having to click the mouse while you're driving, so having it done automatically sounds awesome. New map revisions introduced a drone in comfort that is not present in sport and wasn't present in older maps.
The tune itself works great and I don't have any issues once the car is warm. I'm tired of all my minor issues being blamed on octane. Anyone made the switch? Anyone run both? iPhone user, so now MHD is even more appealing.
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
05-21-2020, 11:01 AM | #54 | |
Rep 7,606
MHD on the other hand is a bit more conservative, doesnt update the tunes as much, probably makes a little less power, but the benefit of all that is that is just works. If you just look at the MHD threads vs. BM3 threads you will see exactly what i mean; the MHD threads are usually people who messed up the flash (user error), while the BM3 threads are tons of datalogs of people trying to figure out why their car didnt seem to run right after the update (which may not necessarily be only due to the tune, however). As a MHD user myself, i primarily chose it becuase of (1) android platform and app-based tuning and logging, (2) slightly more conservative approach, and (3) way less frequent issues based on threads. If i wanted to push my hardware to the absolute limit i would just get a custom tune. Please note, i am not bashing one or the other or saying one is "better" than the other. "Better" is highly subjective depending on what you want to get out of your tune. |
05-21-2020, 11:40 AM | #55 | |
368
Rep 873
It sounds to me like I might have made the wrong choice. I'm running a 91 map with 93 octane because my gas sucks and I'm trying to keep it reliable. I'm FBO, but am not on a quest to make this a 600hp machine. Based on those wants/needs, MHD sounds like the better fit for me. On the bright side, BM3 can be resold. One of the reasons I initially went with it. Pros and cons, people! Thanks for the reply!
12-04-2020, 02:19 AM | #56 |
Rep 43
I've had MHD stage 1 on my BMW X3 N55 for year now. I never had issues, 5k miles before i tuned it i replaced the spark plugs, i'm at 100k miles now with original coils, i never had check engine light or anything on that car. I wanted to switch to bm3 just because you can get little more hp, but after reading on forums i guess i will be staying with mhd. At the end of the day, i would sacrifice little hp for reliability.
12-04-2020, 02:56 PM | #57 |
Rep 1,288
MHD came out with a OTS E30 map for upgraded fuel pump for the B58 and getting 500+whp dyno runs ... so I'm hoping it's not to far away for the N55
12-04-2020, 03:12 PM | #58 |
Rep 7,606
Whaaaaaat. This makes me optimistic. If they do release such a map for the N55, I will almost certainly get a HPFP. I am in no rush though, especially given how little i am driving the car right now, so i can be patient . I almost want to email them and ask.
12-04-2020, 03:50 PM | #59 | |
Rep 1,288
I wrote: Love your product... I have 2015 335i xdrive Fbo... running stage2+E20map but E85 is hard to get for me... want to run methanol... what would you suggest for a setup including failsafes etc... Thank you in advance.. Reply: you can simply run the ST2+ 102 ron and add like 3-4L meth to a full tank of 93 to bump up your octanes I replied back and waiting for an answer: Actually wanted to run 50/50 boostjuice that I can get from Amazon... So I'm figuring I gotta spray it separate or no?... problem is stock fuel can only run E20 max... was looking for more plus cooling effects.. Last edited by FastF30; 12-04-2020 at 03:57 PM.. |
12-04-2020, 03:58 PM | #60 | |
Rep 7,606
You would need to more specifically phrase your question around running methanol injection via the CP. |
12-04-2020, 04:05 PM | #61 |
Rep 1,288
12-04-2020, 04:06 PM | #62 |
Rep 1,288
12-04-2020, 04:09 PM | #63 |
Rep 7,606
You can run any 'fuel' in the tank lol. Ive seen videos of people running everything from avgas to everclear (the alcohol) with varying degrees of success (not F30). I actually saw a miata dyno tuned on E85 then on everclear and it made a few more HP on the everclear lol. I'm sure the sugar and additives were not great for the fuel system though, nor is the $/gal. That's youtube for ya.
10-14-2021, 12:30 PM | #64 |
Rep 1
I'll leave my thoughts that I made on MHD vs BM3 on another thread here:
https://www.2addicts.com/forums/show...9&postcount=13 |
10-14-2021, 12:52 PM | #65 | |
Rep 7,606
First, stage 2+ MHD is supposed to be compared to stage 2 BM3 as those are the "equivalent" tunes. Stage 2 MHD is inbetween stage 1 and 2 BM3; its just a different rating of the "stages". Second, you talked about the timing corrections in your MHD log vs BM3 log and claimed the car "adapted better" to the BM3 tune. However, the IATs in the MHD log are nearly 30 degrees higher which is a huge factor in timing correction. It also raises the question as to whether or not you logged on the same tank of gas or not. There's also natural variability from log to log so unless you collected 3 of each, and all 6 on the same tank of gas, and under similar IATs/ambient conditions, it's not really a fair comparison. The timing in the MHD log recovered quite a bit by the upper RPM as well even though IATs dropped only a few degrees below 100F. (BM3 is also potentially less sensitive to timing corrections but i wont get into that). The reason MHD said the log is too aggressive for your ambient pressure is because they dont recommend running the turbo in the upper 90% WGDC. If you compare boost in the two logs, the MHD log is actually targeting higher boost then BM3, which is typically not the case, but because it is load-based it is adjusting for your lower ambient pressure. You revved out the BM3 log further, but the MHD log was making basically exactly the same or slightly more boost than the BM3 one. In the upper RPM the MHD falls off less because its trying to meet load target, but you can see why they dont recommend it due to high WGDC. BM3 of course has not problem with WGDC near 100% because their OTS maps push the stock turbo that hard anyways. If they had the same more conservative approach as MHD they would have also recommended you not run the stage 2 map. So what evidence do you actually have that the BM3 map adapted better to your engine - "From the beginning, the stage 2 93 octane map adapted much better to the engine...". Aside from the timing corrections, because that is a moot point given the IAT differences and questions about fuel. The bottom line is that MHD support just recommended not to run a map that is maxing the turbo due to your altitude, whereas BM3 said it was just fine. |
johnung4528.00 redbullfan356.00 |
10-14-2021, 08:34 PM | #66 | |
Rep 2,639
