01-08-2023, 03:25 AM | #1 |
Rep 183
B48 Misfiring, Bucking and Shaking...
Hey guys,
I'm having a ton of issues with my B48 320i. A short timeline - 2020 - Tuned Car with bm3 August 2022 - Start having extreme misfires on my car. Tested compression (all good), plugs and coils. Two coils were bad and all 4 plugs were fouled. Plugs and coils were replaced with brand new OEM parts brought from the dealer. Issue resolved and sticking to stock tune. (KMS - 64xxx) Jan 2022 - I tune the car again. After a couple of hundred kms, same misfiring and all 4 plugs are black and wet (pics below). I clean the plugs, check the coils and switch back to the stock tune (just to test) it no longer misfires. (KMS - 65xxx) Now, (1/8/23) my car is still misfiring 1.5k-2k rpms under low loads and it feels like it's bucking. It also occassionally shakes on startup. There are absolutely no codes which is making diagnosis impossible. Any help would be appreciated. Here are some logs that I have collected - WOT Logs: Stock (Dec) - https://www.bootmod3.net/log?id=63ac...729b5993cc32fa Stage 2 (August) - https://www.bootmod3.net/log?id=62e4...729b2d5d51d863 Part Throttle Logs: Stock (Jan) - https://www.bootmod3.net/log?id=63b5...0b43b9c3cb1c8b Stage 2 (Dec) - https://www.bootmod3.net/log?id=63ab...0b43b638c3fdd4 |
01-08-2023, 08:29 PM | #3 |
Rep 183
If there is pressure, what does it mean? If there's no pressure, what can be the issue? My compression test is good btw just tested yesterday. I also have zero oil consumption between changes (5k miles) and no other mechanical issues other than the misfires and shaking.
01-09-2023, 09:50 AM | #4 | |
Rep 13
01-09-2023, 09:00 PM | #5 |
Rep 183
UPDATE: I ran a misfire test on ista and this was the result -
I'm gonna inspect the plug in cylinder 4 and replace the coil. I'll run the test again and if the result stays the same, I'll switch the cylinder 4 injector. Car is running fine for now. |
01-10-2023, 09:21 PM | #6 |
Rep 183
I Moved coils and cleaned plugs before running the test again. The test passed with no problems. Cylinder 4 plug had a bit of fuel on the tip. There was a bit of oil on the threads too. A mixture of oil and fuel seems to be fouling plugs without reason. Any ideas?
01-12-2023, 04:48 AM | #7 | |
Rep 183
02-04-2023, 06:19 AM | #8 |
Rep 183
I had the valve cover changed but still there's oil fouling on plugs. Cylinder 4 is most affected. Compression was tested by the dealer and it's still good at 220psi (15 bar). The dealer neither has a borescope nor does he have leak down testing equipment. Is there any other way of testing if it's the rings/valves or maybe scored cylinders?
02-11-2023, 08:51 AM | #9 |
Rep 183
UPDATE: I did a leakdown test and all cylinders had less than 5-6% leakage. Injectors were taken out and also tested for leaks, no issues found. What else could it be?
02-11-2023, 05:45 PM | #10 |
Rep 812
One message says fuel on the plugs and your latest days oil fouling. Can you confirm which it is, as fuel would clean off oil.
If it's oil fouling, I would be looking at the pcv as a possible culprit. With oil vapor being relatively heavy, it may have an easier path into Cyl4 dependant on the inlet manifold and throttle body position. Did you check the crank case pressure with the oil cap off? |
02-11-2023, 09:14 PM | #11 | |
Rep 183
04-17-2023, 02:18 AM | #12 |
Rep 183
Hey guys,
I've had the valve cover, piston rings and valve seals replaced but the car started to misfire again after 200-300kms. I'm now looking at fueling components since oil shouldn't be a possibility post so many repairs. Except for injectors and o2 sensors, is there anything else that I should check? |
08-18-2023, 07:44 AM | #13 |
Rep 3
tpoddar any updates?
Im having a very simiplar problem with my 320i 2016. Changed sparkplugs ,coils, vanos solenoids, tank breather valv, cleaned MAF and MAP. Sometimes having code P0301 , p0304 and p0300 then they dissipears. But always small misfireing and a bit strutter on idle, weak under 2000rpm. |
08-18-2023, 12:40 PM | #14 | |
Rep 183
08-21-2023, 03:54 AM | #15 |
Rep 3
I changed plugs for the second time this weekend, I suspected that I did overtorque last time - had no torquewrench. So now - new oem Ngk plugs at 23nm. Still same problem.
Plugs look rater good I think!? Or? |
08-22-2023, 12:41 AM | #16 |
Rep 3
I did a live capture by a friends budget obd scanner and got some values both when no errorcodes are present and when i got P0300, P0301, P0304.
Did a summery of the values that does differ. Does this tell you guys something? Could it be a 02 sensor that is bad? |
08-23-2023, 07:43 PM | #17 |
Rep 1,066
A 2016 320i should be an n26.
If you did plugs and coils, the only thing left is fuel injectors. If you replaced those and didn’t code them to the car, that’s a high chance where your issue is. first I'd clean the MAF sensor and ensure the upper oxygen sensor isnt giving false readings. Very rare for the high pressure fuel pump or low pressure fuel pump to be the issue here. As always, check for boost leaks as well
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 Last edited by sqwinny; 08-23-2023 at 09:44 PM.. |
08-28-2023, 04:07 PM | #18 | |
Rep 51
LCI F30 320i only came with the N20/N26 in the US, in all other countries the LCI has the B48. I have no idea why BMW decided to keep the N20/N26 in the F30 LCI only the US market. |
08-29-2023, 10:59 AM | #19 | |
Rep 1,066
Either way all the issues TPodder had was clogged/leaking fuel injectors. Unfortunately they didn’t want to change/check the fuel injectors and took their entire motor apart. After all the $$$ and time and effort, it was the fuel injectors.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
