06-25-2018, 09:45 AM | #265 |
Rep 66
Hello again... I have a general question about DSPs and the PP86DSP in particular:
Is it possible to make the bass / subwoofers sound louder only at lower level so that when the music volume is at 30% (for example), the bass/subwoofers gain to be somewhere higher? The point would be to have more bass at lower volumes and normal 0db undistorted bass at max volume. |
06-25-2018, 09:53 AM | #266 | |
Rep 8,942
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
06-26-2018, 07:29 AM | #268 |
Rep 8,942
I'm 99% sure no but could be wrong - which is why I suggested a workaround.
2022 Macan S
09-04-2018, 11:03 AM | #270 | |
Rep 63
Follow-up: Figured it out. Loaded the 82DSP file into demo mode. The routing looks like the routing from the post I originally referenced. All speakers are routed through the subs. Which is how I now setup the 86DSP, works great. Last edited by m_michael; 09-07-2018 at 07:04 PM.. |
10-22-2018, 07:16 PM | #271 |
Rep 11
Deleting PDF Extension
For the life of me i cant figure out how to get rid of the pdf extension when trying to download these files. how do i do that?
10-23-2018, 11:54 PM | #273 |
Rep 33
I saw a few mentions in the thread about adjusting tunes to work with ASD. I happen to be in the minority that likes the ASD in my F31. How would I go about adjusting a tune to work better with ASD? Just lower the overall gain of all channels? Is ASD present just on certain channels?
Thanks |
10-26-2018, 07:56 PM | #275 |
Rep 11
Match UP7 BMW Review
Just an update. The Match Up7 BMW is pretty awesome with stock speakers. I’m incredibly surprised the stock speakers are this capable. Its much louder, and it retains the same sound quality at much higher volumes with a proper tune. Bass response is much better surprisingly. I really think the stock base system was pretty great, compared to any base system in any car I’ve driven (I deal with a lot of rentals), it was just way too quiet for me.
I do have to say that I’m running all the gains pretty much maxed out, and had to boost my whole EQ several DBs to get the volume I wanted. If ads are correct, that means the stock speakers are taking around 65w and the woofers 100+rms. I was getting way more distortion at max volume stock than I am at max volume now. Even with the amp pushing as much as it can it still could be a hair louder, my last car with a full pro audio spl setup and a top of the line pioneer touchscreen with 16 band eq was louder (duh!! But Sound quality was nowhere near this good), But I’m pretty happy with it, it’s more than loud enough. I needed to get out of my ear bursting phase anyways. Knowing that, and knowing the the speaker specs that have been posted by billfitz and others on this forum, I question what the purpose of replacing the stock speakers is. People complain about the tweeters, and the woofers, but they keep up no problem. Its very clear that the issues that the stock system had were an underpowered amp that was being overdriven, causing speakers to distort, And crossovers that were a little Off. I don’t see how replacing the speakers could ever do much at all for anybody, unless you got a way more powerful amp than either bimmertech or the up7. Even then, I’d question how much more capable they would be. I’m really glad I went with my gut and replaced the amp instead of speakers. Last edited by JJFox; 10-26-2018 at 08:27 PM.. |
10-26-2018, 08:06 PM | #276 |
Rep 11
Robthebob, I just used bimmertechs file to start with on my UP7. It looks to me like they all cross over okay, eqs and crossovers all were the same. I didn’t see any real changes when i loaded it up to the other in demo, so I rolled with it and it worked great. Might have to tweak the Eq a bit though.
10-27-2018, 01:21 AM | #277 | |
Rep 793
How does the 7up comoare with the bimmertech |
10-27-2018, 03:15 PM | #278 | |
Rep 33
11-01-2018, 07:23 AM | #280 | |
Rep 32
11-11-2018, 10:04 PM | #281 |
Rep 100
Hey everyone, I just got my amp installed tonight and made sure the stock hifi tune was loaded(from the first link in this thread). It had the tune for ghost subs and bav speakers already on it, got it from my buddy.
For some reason it just sounds weird. Im not sure where the factory bass and treble settings should be, they were right in the center and the bass was way to much. I fooled around with these settings a bit and it sounds eh now with bass at 4 and the treble halfway with the fader two to the rear. It sounded better with the bav speaker tune in it but the speakers were just to overpowering to the bass. the 2 and 4 switches are up. Is there something I'm missing here or a better factory tune? I listen to everything but country, alternative music sounds way better than hiphop where the bass just seems artificial. The stereo almost sounded better with the factory amp but didnt get near as loud. I do have a trunk sub and amp from my old mini, is there a tune i can use that with to kinda supplement the stock subs? Thanks in advance! |
11-11-2018, 10:17 PM | #282 |
Rep 1,906
You might want to contact support at BimmerTech and get their tune based on your car model- give that a go.
I recently installed a used PP82DSP in my F25 X3 SUV- amp came out of F31 3-Series wagon. B-Tech sent me tune for my SUV and it sounds quite good. DIP sw's 2 and 4 ON are the highest gain settings- if bass is too much, might turn #4 to OFF. You can download software from Audiotech-Fischer and load into laptop, connect to amp and do some tweaking yourself - will take some trial and error but might be way to go after you get car-specific basic tune installed. Good luck/Bill |
Davchs0.00 allwheelsdriven112.00 |
11-12-2018, 05:23 PM | #283 | |
Rep 20
12-01-2018, 12:43 AM | #284 | |
Rep 500
12-04-2018, 10:13 AM | #285 | |
Rep 1,397
Thanks guys! |
12-04-2018, 10:54 AM | #286 |
Rep 1,906
Have you adjusted the input sensitivity (gain) on the amp?
fiveohwblow3633.00 |
