06-03-2020, 08:41 PM | #1 |
Rep 60
Ohlins Road and Track Coilovers Spring Rates
I'm looking into Ohlins Road and Track (BMS MP00) coilovers for my 340i.
I noticed the front spring rate of the kit is 60N/mm which seems kind of low especially considering the application is the same for the 328i/335i/340i etc.. Does anyone have experience replacing the front springs in the kit with 80N/mm? I had one vendor tell me I could do the swap through Ohlins but Ohlins would also insist on revalving the shock (due to higher spring rate) for an additional fee. Ultimately this car is my daily driver so I'm not looking to go super stiff but at I want the car to handle "sporty" and also not dip/wallow terrible on driveway entrances. I do quite a bit of high performance driving events as well so I need a spring rate well suited to that as well. |
06-03-2020, 11:39 PM | #2 |
Rep 3,540
You think 60N/mm is soft? Lol
06-04-2020, 10:02 AM | #3 |
Rep 142
I have Ohlins R&T. Don’t worry about them not being firm enough.
leadfoot1293.50 |
06-04-2020, 10:10 AM | #4 |
Rep 60
Haha all I've got to go off is some other folk talking about them on this forum. I'm honestly a noob when it comes to coilovers, this will be the first set I've ever bought.
So I take it 60N/mm is pretty stiff and the fact that Ohlins specs the same rate for the 4cyl/6cyl applications isn't a big deal? |
06-04-2020, 10:23 AM | #6 | |
Rep 3,540
leadfoot1293.50 1bad14-F3030.50 |
06-04-2020, 02:56 PM | #7 |
Rep 142
I love them. I had B16 comforts before and Ohlins are miles better in terms of a buttoned down sporty ride. It's definitely firm, but they have a big range of adjustability and the adjustments are very noticeable. I settled on 15 clicks in the front, 22 in the rear (clicks from full stiff).
My only complaint is that the rears are pretty much impossible to adjust with the wheels on. |
leadfoot1293.50 |
06-04-2020, 03:01 PM | #8 |
Rep 8,500
The Ohlins R&T kit for my car (330d Touring) came with 70N/mm front springs. I prefer a firm suspension setup, and I do track my car a few times each year, and I felt that the front was under-sprung.
I had the front springs swapped for 90N/mm units and the front-rear spring rates feel far better matched as a result. I have the front and rear dampers at 9 clicks from full stiff - the dual-flow valves allow for a softer secondary ride and deal with the larger primary undulations very well. There are several threads which include useful information regarding R&T.
leadfoot1293.50 |
06-05-2020, 06:51 PM | #9 | |
Rep 60
Time to do some reading on bounce frequency! |
06-05-2020, 07:41 PM | #10 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
I run the Ohlins R&T kit on my F30 335i, and yes, the front spring rates are too soft. After getting the kit installed, I noticed on the drive home from the shop that the car was prone to oversteer. After discussing it with the Ohlins rep, and running corner weights and spring rates analysis numbers with the Swift springs rep, I settled on leaving the rear 16k springs alone, and swapping out the front 6k springs for 8k Swift springs (and going with 7" rather than 8" length to allow for raising the lower spring perch to free up some space for wide tires). This made all the difference in the world; on track, the car is perfectly balanced and neutral.
06-05-2020, 11:59 PM | #11 | |
Rep 60
EDIT: actually with a shorter spring you'd just screw the perch up as if you were lowering right? You don't actually need a new perch? Last edited by leadfoot12; 06-06-2020 at 12:23 AM.. |
06-06-2020, 01:27 PM | #12 |
Rep 785
Somebody said that ohlins used a 320d to develop the coilovers for the f30, so if that's true then the front springs might be a little soft with the bigger engine of the 335i sitting on them? Or maybe because the rears are 3 times as stiff as the front in the standard road&track kit?
Anyway, can anyone tell me if there is any truth to the rumor that the coding for adaptive suspension can't be turned back on if one codes it out? It would be cheaper than using an EDC delete kit, but I am thinking that if circumstances change and I have to sell the car one day, it would be nice to return it to stock suspension.
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
06-08-2020, 08:34 PM | #13 | |
558
Rep 1,477
Drives: 335i
Correct
leadfoot1293.50 |
06-08-2020, 08:42 PM | #14 | |
558
Rep 1,477
Drives: 335i
I have not heard that EDC dampers can't be coded back in, and I doubt that's true.
06-08-2020, 11:46 PM | #15 | ||
Rep 785
06-11-2020, 01:14 PM | #16 | ||
Rep 785
06-11-2020, 02:23 PM | #17 | |
Rep 3,540
06-11-2020, 05:38 PM | #18 |
558
Rep 1,477
Drives: 335i
All of my suspension mods were one at a time, so I have a pretty good sense of how each affected handing individually. I had H&R front and rear sway bars with OE EDC dampers and Dinan springs for a while before getting Ohlins coilovers... And the Megan Racing rear arms were well after Ohlins. It was purely the Ohlins spring rates that shifted the handing toward strong overseer.
06-11-2020, 07:06 PM | #19 | |
Rep 3,540
That's the method I used on my vehicle when I had oversteer issues. When you get to as high rear spring rates as we have (I'm running 900lbs/in, 16kg/mm too), you really don't need much rear bar.
06-12-2020, 07:04 AM | #20 | |
Rep 8,500
My F31 330d MSport suspension history has gone like this : Fully OEM springs, dampers (EDC) and bars. EDC dampers + AC Schnitzer springs + H&R front & rear bars (28mm / 20mm). Ohlins R&T (70N/mm F / 160N/mm R) + H&R front & rear bars (28mm / 20mm). Ohlins R&T (90N/mm F / 160N/mm R) + H&R front & rear bars (28mm / 20mm). Ohlins R&T (90N/mm F / 160N/mm R) + H&R 28mm front bar + Eibach 16mm rear bar. This is my current setup. With the 20mm H&R rear bar I could really load the outside rear tyre in cornering to generate great grip and traction. The car felt very stable. The limits of grip were higher BUT the car was prone to snap oversteer if the grip on the outside tyre was overwhelmed. Even thought the car has a Quaife LSD the transition from grip to slip was sudden and often uncontrollable (DTC required). Switching to the 16mm rear bar has made a significant difference :
Suspension is always a compromise and TBH I'm on the fence whether I prefer the handling of the car with the 20mm rear bar or the 16mm. I still have some options to experiment with in terms of equal or unequal front/rear damper settings to see what changes they make.
06-12-2020, 08:54 AM | #21 |
Rep 785
Big thanks to FaRKle dvc & watsey as always! You guys are awesome and have saved the rest of us countless hours of experimenting and money by contributing to these threads.
06-12-2020, 10:48 AM | #22 | |
Rep 8,500
Suspension is hugely subjective, but hopefully some of the insights are useful. Happy to share my experiences, good and not so good.
leadfoot1293.50 |
340i, bms mp00, coil overs, coilovers, ohlins, road and track, spring rate |
