12-12-2021, 10:22 AM | #1 |
Rep 176
B58 Injectors Upgrade (Can S58 Injectors work?)
Hi all,
Has anyone upgraded the B58 injectors? I was looking at the S58 injectors. Reason for not going port injection is that there are none available for B48 platform. I am thinking if HPFP upgraded to B58TU, pressure sensor upgraded and injectors, it may work with some tuning changes. Thank you. Regards, Shane |
12-12-2021, 06:12 PM | #2 | |
Rep 420
M140IX. Turbo Pure 800 Cast.
12-12-2021, 06:26 PM | #3 |
Rep 1,449
There's B58 upgraded injectors in the works.
2022 CT4-V Blackwing 6-speed
SRHosein197.00 |
12-12-2021, 06:30 PM | #4 | |
Rep 10,322
Echoing an earlier comment: not possible. DME monitors and controls a myriad of metrics: timing, fuel mixture - to name a few. Injectors are designed to serve a specific design envelope and are not easily substituted. PS. There are many other options to increase horsepower. |
12-12-2021, 07:07 PM | #5 | |
Rep 1,449
SRHosein197.00 |
12-13-2021, 02:22 AM | #6 |
Novice
316
Rep 697
Wouldnt Port Injection (as a supporting mod) be more beneficial than DI alone? I thought our cars build up carbon in the intake manifold part due to no fuel being dumped there.
12-13-2021, 02:47 AM | #7 | |
Rep 2,651
Port injection is fairly dangerous as if it fails, or leaks, you're going to flood your engine. A friend of mine with a bigboost 3.3 kit and PI had his fail on his M235i, and flooded the engine with fuel. The oil smelled like fuel and he had to flush it 3 times before he sold it to the next poor soul.
12-13-2021, 08:42 AM | #8 | |
Rep 176
There are not many options available (no port injection). Hence the reason to look at upgrading injectors. Also if S58 injectors can physically fit, it can be programmed via the tune and would be a great option. Having one set of injectors controlled by ECU would be a great option. No additional pumps, injectors, lines, ect. Hence less components to fail. |
12-13-2021, 09:50 AM | #9 | |
Rep 3,191
12-13-2021, 01:23 PM | #10 | ||
Rep 1,073
Link to his build thread: Shane's BMW B48 Engine Build https://f30.bimmerpost.com/forums/sh....php?t=1864478
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
12-14-2021, 09:02 AM | #11 |
Cheapskate
4464
Rep 4,995
Again, a few points to remind everyone
- The S58 injectors are the same as B58TU injectors - The B58TU/S58 injectors will not fit the Gen 1 B58 - There is an assumptions that they flow more or are an "upgrade" but that is not the case |
G.Newt810.00 |
12-14-2021, 09:27 PM | #12 | |
Novice
316
Rep 697
12-15-2021, 04:53 PM | #13 | |
Rep 176
The B48/B58 part numbers for injectors - 13538625396 (HPFP about 2800psi stock). The B48TU/B58TU part numbers for injectors - 13538656548 (HPFP about 5000psi stock). The S58 part numbers for injectors - 13538671991. I know a few people checking on these as potential upgrades or other injectors as well, if I get a solution, will update you all. Some people stated the reliability of the B48/B58 1st gen injectors drop when running above 3000psi or so; I have not tested. |
12-30-2021, 08:35 PM | #14 |
Rep 176
Update on injectors:
The b48/b58 1st gen injectors are different from the b48tu/b58tu injectors. The tu injectors have a smaller tip and will fit loose on the b48/b58 1st gens head. The S58 injectors should be similar size as b58tu injectors. I am not sure if the M5 injectors will fit but if it does, the rail will need modifications as it's a screw type injector. |
WeDclOwN27.00 |
04-26-2023, 12:47 AM | #15 |
Rep 577
Is there an update on this? Will there ever be an actual injector upgrade on this platform?
current
'18 F22 240i xDrive - FBO '16 F82 M4 ZCP - FBO previous '08 E90 335i Montego Blue |
04-26-2023, 09:33 PM | #17 |
Rep 577
I was curious if there was anything being developed, but it looks like development for HPFP has slowed down. It would have been awesome if this platform had dual HPFP like the S55/S58.
current
04-27-2023, 02:32 AM | #18 |
Novice
316
Rep 697
Why not go port injection with a DS2? 750cc injectors are enough for 700whp+ and it is relatively safe now with REFLEX+ (paired with MHD) and the aluminum intake manifold.
04-27-2023, 03:44 AM | #19 |
Rep 577
I really like the simplicity of direct injection and it’s knock resistance. Yes, you are right about Re|Flex I wouldn’t go with any other controller. With the introduction of Re|Flex and sequential injector control it is much more safe and reliable compared to previous systems. I’ll go port injection eventually, but I want to really utilize what is possible with the direct injection system before I go port.
current
blacksapphire440i316.00 kern4174464.00 |
05-03-2023, 06:30 PM | #21 |
Rep 577
For Gen 1 or Gen 2?
current
05-04-2023, 07:50 AM | #22 |
Cheapskate
4464
Rep 4,995
apparently both. we'll see
