BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Wheel spacers for F30s
      04-01-2014, 12:59 PM   #1
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
I've been taking measurements, and doing some research on hub-centric spacers, and I thought I'd share what I found in case anyone else is considering options and is looking for fitment info...
Wheel spacers - including hub-centric spacers (with the centering lip extension protruding outward for the wheel to sit on) need to sit flush against the hub to avoid wheel wobble. The F30 chassis has a hub centering lip that protrudes a bit further than previous 3 series cars, so I took some measurements to ensure that what I am ordering will fit:
F30 hub centering lip - length of protrusion:
Rear is 13mm
Front is ~ 11.75mm
(Measurements are from my 335i, which is fitted with M Performance/M Sport-upgrade brake rotors; measurements may be slightly different with standard brakes.)
H&R tells me that the recessed area on their 10/12mm spacers can accommodate up to 12mm, so these are good to go for the front. (Their 13mm and 15mm versions have a larger recess, and should be fine for front and rear.)
Kevin from Apex calipered the recess area on one of their 12mm spacers at 13.22mm, so these should be good to go for the front.
I will be fitting the 10mm H&R spacers in front, and 12mm Apex spacers in back prior to my 2-day HPDE next week. At present, I have 5mm non-hub-centric spacers in front, which I think may be responsible for some occasional, mild vibration at certain highway speeds. If that's the case, I thought it would be best to go with full hub-centric spacers before getting the car back on the track.
The clearance should be close with my 9" Apex ARC-8 wheels (ET 42), so fingers crossed...
      04-04-2014, 01:57 PM   #2
utenigma
DVC did you have a stud-kit installed when you used your spacers or just extended lug bolts?
I've got the 5mm spacers on the front and don't have any vibration issues (using a stud kit). I do make sure everything is clean, it's square and torqued down evenly every time.
      04-04-2014, 04:14 PM   #3
DVC
DVC's Avatar
Drives: 335i
No, I just used extended bolts. The vibration was verrry mild - almost undetectable. And it didn't start right away.
I wouldn't think the bolts vs stud kit would make a difference; the fact that you used great care in tightening your nuts (I did the same with my bolts) will likely keep things smooth for a while - but the vibration may crop up eventually.
I just fit the hub-centric spacers today (10mm front and 12mm rear) and everything seems to fit perfectly. This evening I'll try to take some corners hard in comfort mode to get some good compression to make sure everything still clears without any rubbing... but the real test will be at the track this Monday and Tuesday.
By the way, with the Dinan springs and the aggressive offsets, the look is amazing...
      04-04-2014, 06:37 PM   #4
utenigma
Weekday track days-I need that
I can skip work easy, skipping daddy duty requires something akin to a deal with the devil
      04-04-2014, 06:53 PM   #5
Tditty
Drives: Bmw 335x with m package
So 12mm hub centric spacers are fine for the rear? Why does bms say that 15mm is the minimum. Hmmm
      04-04-2014, 09:32 PM   #6
DVC
DVC's Avatar
Drives: 335i
Dude.... I know EXACTLY what you mean! I have 3 little ones, so skipping work is much easier than taking a weekend day away.
      04-04-2014, 09:34 PM   #7
DVC
DVC's Avatar
Drives: 335i
It all depends on the depth of the spacer's inset that the hub's centering lip fits into. H&R 13mm spacers only have a 12mm inset, so they're no good
**Edit - 13mm spacers are OK - it's the 10mm and 12mm spacers that have the 12mm inset**
...but the 12mm ones that Apex sells have a ~13.25mm inset, so they're good to go.
      04-04-2014, 10:47 PM   #8
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
Drives: M Sport 335i
2014 335i  [9.74]
I assume you had to remove the same dust covers I did DVC?
      04-05-2014, 05:53 AM   #9
TPA335
Drives: 2014 335i M-Sport 6MT
Originally Posted by DVC View Post
It all depends on the depth of the spacer's inset that the hub's centering lip fits into. H&R 13mm spacers only have a 12mm inset, so they're no good... but the 12mm ones that Apex sells have a ~13.25mm inset, so they're good to go.
So you can't use the H&R 13mm on the rear? I wanted to go 10mm front and 13mm rear but I guess I need to rethink now. What size extended lug bolts are you using?
      04-05-2014, 08:16 PM   #10
M3AWD
M3AWD's Avatar
Drives: 2022 G80 M3 AWD
Not true. I am running 13mm H&R Rear Spacers with no issues. They are actually recommended for the F30.
2022 G80 M3 Comp M xDrive
      04-05-2014, 08:49 PM   #11
DVC
DVC's Avatar
Drives: 335i
Sorry, you're right - 13mm should be fine on the rear - it's just the 10mm and 12mm that have the 12mm inset. The H&R website lists the 10mm/12mm spacers as "front only" for F30s.
I had no such dust covers... (?)
      04-05-2014, 09:00 PM   #12
M3AWD
M3AWD's Avatar
The H&R engineer with whom I spoke on the phone quoted the inset size at 12mm. I specifically asked about the 10mm spacers; I don't recall for sure if he indicated that the 12mm inset measurement pertained to the 13mm spacers too... but the H&R website clearly lists the 10mm/12mm spacers as "front only" for F30s.
I agree that the 10mm and 12mm are Front Only. But the 13mm (P/N 2675726) works Front & Rear according to H&R Website. That's what I'm currently running (Rear) and I know that a few other forum members do as well.
      04-05-2014, 09:06 PM   #13
DVC
DVC's Avatar
Drives: 335i
Yes, you're right - posts corrected above.
      04-05-2014, 09:26 PM   #14
M3AWD
M3AWD's Avatar
glad we can share our experiences and help one another on these forums
      04-07-2014, 12:51 PM   #15
ronin951
ronin951's Avatar
44
Drives: 2013 328i M-Sport
lol, +1k. There is a lot of money to be made with daycare service @ the track.
2013 EBII 328i M-Sport 6MT, M-Performance Brakes, M-Performance Suspension, APEX Arc-8 18 x 8.5 square, Pilot SS
1999 EB1 M3 - Bilstein PSS9, Vorshlag Camber Plates, Kosei K1, ZII Star Spec, PFC, gallon of distilled water.
      04-08-2014, 06:53 AM   #16
2014 335i  [9.74]
10mm & 15mm BMS spacer weight.
      05-13-2014, 01:46 PM   #17
izzyM2
izzyM2's Avatar
713
Drives: 24’M2/21ID.4/21’MacanGTS
Anyone track there car with spacers - any issues?
      05-13-2014, 02:07 PM   #18
DVC
DVC's Avatar
Drives: 335i
Yes - no issues.
      05-13-2014, 04:50 PM   #19
verheizer
Drives: 435i
The Apex 12mm Spacers for the back axle of the F30 work for normal BMW Wheels and not only for Apex ones?
(I'm asking because AC Schnitzer is able to produce hub centric 4,5mm Spacers,but they only work for their own wheels which have a larger centric bore.)
      05-13-2014, 05:04 PM   #20
DVC
DVC's Avatar
Drives: 335i
Typical bore for wheels/spacers is 72.56mm. Anything 5x120 of this bore should be fine for all F30 wheels... not sure about the wheels you mention with a larger bore (were they originally wheels for another vehicle?)
      06-03-2014, 12:17 PM   #21
andrew 330i
it can never be too clean...
andrew 330i's Avatar
163
Drives: 2014 F31 M Sport Wagon
~ i'm looking for spacer in a 10mm front and 13mm rear but in a 'silver or aluminum' in color.
i believe a black spacer will look tacky placed between a silver wheel and silver hub. thoughts?
'14 328xi wagon / m sport / white / red leather
kw v1 coilover kit / 19" staggered 351 M double spoke wheels / upper strut bar /
sport line grille & exhaust tips / 50% tint / painted reflectors / debadged / complete clear bra
      06-03-2014, 12:31 PM   #22
DVC
DVC's Avatar
Drives: 335i
H&Rs are silver.... but you can't see them anyway when the wheel/tire is mounted.
