BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Best wheel options for track use
      09-14-2016, 06:42 PM   #23
rwalker
Drives: the wheels off
Originally Posted by SLOWER View Post
I have 19x9 ET29 on my fronts right now and there are no issues with internal clearance.
et29 is 7mm more inner clearance than et36
rwalker@rwalker.com (I really dislike Private Messaging)
      09-14-2016, 08:26 PM   #24
AustinTrkJunkie
AustinTrkJunkie's Avatar
336
Drives: '22 M340i
I've been running my track set up - ARC8 18x8.5/255/40/18 MPSS - for 2 weeks on the street now since missing COTA due to pads that didn't fit and have loved the feel.
So much less understeer and tons more front grip, car used to really push badly in corners. Still does a little, but square is so much better than staggered.
Also zero rubbing, even on high speed corners on SH45 with a lot of bumps and road undulations. My only gripe is the TPMS light being on all the time, but have gotten used to it
      09-14-2016, 08:34 PM   #25
SLOWER
SLOWER's Avatar
Drives: 2003 M3
Right so 18x9 ET 31 shouldn't need a 5mm spacer, correct?
      09-14-2016, 10:16 PM   #26
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
Definitely not...you should have a good 10mm+ of clearance to the strut. You'll be very close to the fender though.
      10-08-2016, 10:46 AM   #27
dsaylors
Drives: 2015 328i MSport + Track
I am looking at the ARC-8 ET42 square setup. For those of you running these wheels, did it clear up the understeer issues on track or are you also running camber plates? I am looking at the Vorschlag plates but am concerned about the noise for daily driving.
      10-12-2016, 06:18 AM   #28
Polo08816
Drives: 2014 335i M Sport
I use the 18x8.5 ET38 with 255/40/18 MPSS square setup. No camber plates. Stock Sport suspension (RWD).
It reduces understeer a bit by providing a bit more front end grip but I would not say it clears understeer up.
      11-04-2019, 08:26 PM   #29
enlimalima
Drives: 335i F30 PWG
Originally Posted by Expert@ApexRaceParts View Post
Your car looks amazing!
Our recommended square fitment the F30 is:
F&R: 18x8.5 et35/et38 - 235/40/18
F&R: 18x9 et42 - 245/40/18
-Matt
Hi, can you give recommendation for staggered set up on 19" wheels, 8.5F-9.5R? I'd like to get my car lowered that the fender lip is level with the upper side of the tyre, and I'd like to ensure there's no rubbing. I got KW DDC coilovers on a 335 sdrive f30 now.
I was thinking either of the following:
- 235/35 front and 265/30 rear
- 245/35 front and 275/30 rear
I use it on street 80% and 20% for trackdays. I'm also ok with up to -1 camber setting.
Thanks in advance!
      11-07-2019, 04:23 PM   #30
Expert@ApexWheels
Expert@ApexWheels's Avatar
3525
Drives: M3
Thanks in advance!
Absolutely! I'd recommend the 19" EC-7 since it has the best offsets available for the F3x:
Front: 19x8.5" ET35 with 235/35-19 tires
Rear: 19x9.5" ET43 with 265/30-19 tires
- Direct fit with no modifications required.
We also have a 19" ARC-8 setup available:
Rear: 19x9.5" ET33 with 265/30-19 tires
- May need rolled rear fenders depending on tire brand to prevent rubbing during hard cornering.
Hope this helps!
--Dylan
      11-11-2019, 11:16 AM   #31
MacklinUSOB
Drives: f30 328i 6MT Sport
Apex Apex Apex. Strong. Lightweight. Stylish. Economical.
Running 18x8.5 et38 SM-10 wheels with 245/40 RS4s. On 245/40 PS4s I had no rub and it was VERY flush. As soon as the RS4s were on I had some gnarly rubbing on the fender tab. I removed the tab and rolled the fenders slightly but still had rub (mostly on bumper cover), it wasn't until I had camber plates that I was able to eliminate it. Always plenty of strut clearance.
Past: E36 328is & E38 740i
Polo088161610.00
      11-14-2019, 09:04 PM   #32
enlimalima
Hope this helps!
--Dylan
Thanks Dylan, really helpful...
I'm planning to slightly lower the suspension, ie the fender lip levels with the upper part of the tires (so you cant stick your finger in anymore). Do I need another modification to ensure no rubbing? I plan to purchase Advan Neova 08 tires.
Thanks again, super helpful!
      11-15-2019, 01:42 PM   #33
Expert@ApexWheels
3525
Drives: M3
You're very welcome! With the EC-7 setup using the 19x9.5" ET43 rear, you'll be good on to go on stock fenders even with lowered suspension. Only with the 19x9.5" ET33 ARC-8 would you have potential rubbing issues and need to roll the fenders. A light roll like what you've described should be enough, but we recommend always being prepared for a little trial and error when going with an offset this low on a 9.5" wide wheel.
--Dylan
      11-20-2019, 05:39 AM   #34
enlimalima
--Dylan
What's the biggest rotor size plus 6 pot rotors (Brembo/AP R) can a SM10 18" rims clear?
      11-22-2019, 10:09 AM   #35
ibazooka
Drives: '14 335Xi, '89 S50 E30,'95 E36
Originally Posted by cgarner40 View Post
+1
Also running 18x9" ET42 APEX ARC-8 Wheel square on Dunlop ZII 245/40R/18 with Burger Tuning 10mm spacers front and 15mm spacers rear.
Absolutely love your setup, mind asking if your car is xDrive?
Would love to see more pics!
      11-18-2020, 04:10 PM   #36
ssanders307
Drives: 2015 435i xdrive coupe
Apex
I'm in a 2015 435i xdrive coupe and running square 18x9.5 et 35 Apex EC-7s wrapped in 265/35 pilot sport 4s. I'm lowered on Dinan lowering springs and there is zero rubbing and the fitment has slight poke. I track frequently and this setup is amazing. [IMG][/IMG]
      12-03-2020, 08:42 AM   #37
Pinkykillaz
Pinkykillaz's Avatar
23
Drives: 320i,custom Ohlins R&T
265 squared, but stock camber?? what for??
