BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Ground control camber plates
proTUNING Freaks
      10-29-2014, 12:35 AM   #89
rwalker
Drives: the wheels off
http://sdbmwcca.com/calendar shows 11/15...
Yeah, I was impressed with how a 228i looked last time out (Brats in the Lot 10/4).
      11-13-2014, 08:24 PM   #90
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
Just came back from LA CCA last weekend..I probably won't go to SD this weekend.
How is it going with your GC?
G05 - M Performance roof spoiler
      11-13-2014, 09:21 PM   #91
rwalker
I have a new set of bearing retainers with a couple of small tweaks that should put my issues to bed.
I was out of town for a couple of weeks and am scheduled to have another go with the new parts next Wednesday. Hope to update then.
The travel derailed my plans to make this weekend's autox.
      11-17-2014, 07:11 PM   #92
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
Nice good to hear!
I am done auto x this year! I will be attending SD BMW CCA autox/HPDE next year!
      11-27-2014, 02:31 PM   #93
rwalker
New bearing retainers are finally in and have fixed the binding issues. The retainers required some extra chamfering to clear the spring perches.
My front end is now solid, fluid, and mostly quiet. Small bumps still make a little noise, but I think this to be expected given the construction of the plates.
      11-28-2014, 06:58 AM   #94
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
That's very good news...
So starting from the kit that they initially sent you, can you recap the parts replaced and any tweaking work you did that helped get them to where they are now?
      11-28-2014, 11:50 AM   #95
rwalker
The crux of the issue was insufficient clearance between the bearing retainer and the spring perch. There was both vertical and lateral interference causing those pieces to grind against each other, binding the steering and filling the bearing races with aluminum filings.
Suspecting an installation issue, GC initally shipped me new spring perches, bearings, and bearing retainers (of the same design). My shop test fit the new parts, but found they also interfered (off the car!).
GC re-clearanced the bearing retainers to eliminate vertical interference with the perches. My shop then re-re-clearanced the bearing retainers to eliminate lateral interference with spring perches: all fixed.
      12-22-2014, 01:40 PM   #96
M-terkait
M-terkait's Avatar
Kuwait
209
Drives: F30 335i 3/13
hey guys, i have been using 245/40/18 on apex 18x9 ET42 on toyo r888 and it was fine until i swapped msport rotors to mperf rotors and then the tires begun to rub with the shock(suspension), anyways it was time to replace the rear tires and i took the front r888 to rear and put on 245/40/18 Mich Pilot supersport which has balloon-like design on the edges and rubbed even more, so i ordered 3mm and 5mm from Macht Schnell, placed 3mm front and it still rubs if i place 5mm in front it will stick out of the fender as its overflush with 3mm already..
can you guys help me with any ideas?
Is it fixable with wheel allignment?
should i save these MPSS set for another season and buy smaller width tires?
would buying GC camberplate solve the rubbing?
Docrace 6266
      12-22-2014, 07:21 PM   #97
rwalker
A wheel alignment can't fix over-flush, camber is fixed on these cars.
My GC plates allow me to fit 255/35r18 et36 r888s on my M235i (which have less fender than an F30).
      12-22-2014, 09:24 PM   #98
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
My f30 running 275/40+17x9.5 35et+8mm spacers on front. It does not stick or rub at all.
The car is equipped with GC plate and bmw oem swivel bearing.
      12-23-2014, 02:04 AM   #99
M-terkait
M-terkait's Avatar
Kuwait
209
Unhappy
im thinking of getting GC plate instead of buying 2 new tires for front and save michelin while toyor888 on rear is going away after few months.
Docrace 6266
      01-09-2015, 01:38 PM   #100
rwalker
Something additional to note on GC: they were very helpful and ultimately made everything right by me. A great bunch of guys to work with.
      01-09-2015, 03:28 PM   #101
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
Yeah Trevor and Jay are great guys to work with!
      01-09-2015, 09:23 PM   #102
rwalker
ready for the track (Fontana Speed Ventures Roval and autocross) tomorrow
18x9 et41 rear
18x9 et36 front (et41 with 5mm spacers)
255/35r18 Toyo Proxes R888 all 'round
AmuroRay2275.00
      01-09-2015, 10:04 PM   #103
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
Nice! Looking great Rob, I'll see you on Feb at San Diego..
Lol I'm so jealous!
      03-08-2015, 01:34 PM   #104
M-terkait
M-terkait's Avatar
Kuwait
209
They are too long ? Or there is something wrong in installation ?
Docrace 6266
      03-08-2015, 07:44 PM   #105
Forgiven
Forgiven's Avatar
Drives: 22, X5 45e
WOW!! that is one dusty f30 you have! hahaha
check your washer where it sits at! I don't think you got the washer plate installed there!
      03-09-2015, 09:57 AM   #106
M-terkait
M-terkait's Avatar
Kuwait
209
ofcourse when you live in Desert storms, atleast not like UAE
exactly i went back to him at the early morning before any traffic and he took it, as you said washer plate
the problem is he couldn't compress the springs in his shop so he went to a nearby shop ( 100m away) and that Dguy basically removed and installed new camber in the wrong way.
am pretty happy to drive my car with stock-comfort and more negative camber
After alignment at Michelin shop ( using Hunter device)
Docrace 6266
      08-06-2015, 02:01 AM   #107
berk
berk's Avatar
Turkey
Drives: 2014 F32 428i
Originally Posted by utenigma View Post
No more tire munching front end - just called in my order
I'll take pics and post a review here when they come in and I put them on
Does it fit m-adaptive dampers?
      08-10-2015, 11:14 AM   #108
utenigma
Drives: 2013 F30 335i 8SA M-Adaptive
The ask which one you have when you order
      08-11-2015, 09:05 AM   #109
berk
berk's Avatar
Turkey
I have f32 428i with m- adaptive dampers
      06-13-2016, 09:19 AM   #110
duckJAI
Drives: 2012 335i Sport Line
Bumping this up to see how the GC camber plates have held up over the years
Going on their site, it looks like the design has changed somewhat, any feedback?
