11-26-2018, 10:44 AM | #89 |
Rep 11
PDC won't display on 6.5 screen, just beep. I dunno, I think I've gone off it. Seems a lot of money to mostly cripple the options my car -does- come with.
Going to explore different options, I think. |
11-26-2018, 11:06 AM | #90 |
Rep 4,456
I have this and if you have Navi, can use your phone to play music and talk then I wouldn’t get this. It makes everything much more confusing to try and use.
11-26-2018, 02:43 PM | #91 | |
Rep 74
Write if you find any other solution which you will go for.. |
11-26-2018, 02:46 PM | #92 |
Rep 74
Of course if you have everything you don’t need this, but if anyone want reverse camera and CarPlay that’s what we want.. (that’s why i ordered it)
11-27-2018, 09:52 AM | #93 |
Rep 82
any issues with audio from carplay MMI to the car? i had unichip but got rid of it because the audio output was trash, a lot of static. I love listening to music especially with my aftermarket sub, so this is critical for me.
11-27-2018, 10:57 AM | #94 |
Rep 64
Crystal clear for me. It’s direct into the aux input on the head unit so I found the quality was better than Bluetooth streaming to the idrive system.
11-27-2018, 03:34 PM | #96 |
Rep 212
12-02-2018, 12:32 PM | #98 | |
Rep 439
Installed the unichip and great audio quality and no issues out of the box. Of course communication with unichip is difficult and very frustrating. The time difference and language barrier is no joke. But in the end, I have a Product that does what it’s supposed to. Also the third party microphone sounds really good and was way easier to install than the giant cable bimmertech used to splice into the stock microphone. That was why I originally chose bimmertech but now switching to unichip, I’m very happy with the results. Also the unichip firmware is much more advanced than bimmertech |
12-10-2018, 03:45 AM | #99 |
Rep 212
Hey grahamrb do you mind to give your feedback about Bimmertech Carplay so far?
Does using OEM microphone is almost the same when making phone calls via Bluetooth (like you making non-HD calls despite the current support on the phone and network)? If you your screen is 8.8", is it convenient to use with the split screen? About the steering wheel controls, were you able to use them all? I am just placing these items above as my decision factors to buy either systems, bimmertech or unichip |
12-10-2018, 04:30 AM | #100 | |
Rep 64
- audio quality with the OEM mic is good, haven’t had issues with that. Only issue is the audio is a little quieter coming out of the speakers so you need to turn the volume up about 3 notches when you take a call - yes, i’ve got the 8.8” screen. I’m looking forward to the widescreen software update - you can’t use split screen, you just get the CarPlay logo on the right as per the photos - volume and Siri controls work from the steering wheel without any issues. The scroll and press thing on the steering wheel doesn’t work at the moment - again, looking forward to a software update to support this Hope that helps. |
theblues86.50 |
12-10-2018, 05:43 AM | #101 | |
Rep 212
With regards to making calls, when I use my Idrive 5 Bluetooth to make calls, it is noticeable the call quality is just a typical GSM audio. If I switch the call to the earpiece on my iPhone 10, I get that crystal clear audio. I once had a loan from BMW (2018 330) without Carplay. But the call audio was identical to what I get on my phone. I'm certain this has to do with bluetooth chipset used in the new BMW. Since calls in Bimmertech uses the USB, I wonder if the audio is the same to what you hear on your phone. Cheers |
12-10-2018, 06:44 AM | #102 | |
Rep 64
theblues86.50 |
12-10-2018, 02:34 PM | #103 |
Rep 8
Hi all.
Can I ask how large is the add-in box and where exactly is it mounted? I'm absolutely fixated with any rattling sounds and wondered if there's a specific area that it lives? Just trying to weigh up the pros and cons. The Bimmertech unit does 2/3 of the screen but uses the inbuilt mics and is capable of screen splitting. The other options that are full screen typically require an OEM mic and don't support split screen options within iDrive? In terms of the steering wheel and iDrive controller, does these work as before? |
12-10-2018, 05:25 PM | #104 | |
Rep 1,697
Drives: 2014 428i and 2018 X5
12-10-2018, 06:05 PM | #105 | |
Rep 74
12-10-2018, 10:56 PM | #106 | |
Rep 64
12-11-2018, 12:45 PM | #108 |
Rep 64
12-11-2018, 01:04 PM | #109 |
Rep 74
I didn’t use it and I made a call and it was fine... I am waiting the answer from BimmerTech too.. I sent them email..
The only problem for me is that my aftermarket camera displays black screen although i connected the yellow plug and the brown BimmerTech wire with the red one from my camera for extra power as a trigger.. I think that I have to use a red cable that exists on the back of the car near the camera and conect it with the cable of car’s rear light in order to take power from it and make my camera work... |
12-11-2018, 01:13 PM | #110 | |
Rep 64
