02-27-2016, 02:00 PM | #23 | |
Rep 184
You should always have winter tires if you have a RWD or have a beater car. Try some Blizzak WS80(more for blizzard type locations), Michelin Xice 3 or Pirelli Sottozero 3 in the winter and we would be having a completely different conversation. But to each his own, good luck! |
02-27-2016, 05:11 PM | #24 |
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
Really? So far I'd rather have your car over an M2 xDrive after seeing it in person, and reading the initial track reviews vs the M3 + M4, but then again I still haven't driven an M235xi, I just base my assumption on a combination loaner 228i's and my 335xi.
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
02-27-2016, 05:33 PM | #25 | |
Rep 893
2019 SG M5C
2015 SO M3 6MT 2015 BSM M235xi |
02-28-2016, 01:10 AM | #26 |
Rep 3,470
Can't believe no one has said:
1. M3 Seriously, as a tuner of a WRX, I have somewhat of an idea of required supporting mods. 500whp isn't as simple as some people make it out to be. Getting that much fuel in there requires more than just an ample HP fuel pump, the proper turbo induction is a big deal as well, and all of these require a plethora of supporting mods. Can it be done from a 3.0L engine? Sure, but it's not a flash and an exhaust, 500whp is a big bump up from stock and going to put a bunch of stress on a lot of parts, requiring mods and upgrades in many places. Think about what an M5 is running for engine, turbos, brakes, transmission, exhaust, etc... |
02-28-2016, 01:37 AM | #27 |
Rep 170
I would think the axles would be an issue for launching 500 hp
2022 - X5 45e M-Sport, MGM over tartufo
2009 - 335i 6mt, Monaco over saddle (past) 2015 - 335i M-Sport, Estoril over black (past) 2005 - 330i ZHP, Mystic Blue over black (past) |
02-28-2016, 11:48 AM | #28 | |
Rep 902
There are already several N55s pushing up against the 600whp mark and with stage 3 development turbos numbers have been as high as 647whp already. It won't be long till you start too see lots of big moves in the industry PI kits becoming widespread, integration with piggyback tunes is underway, 3 stage 3 turbos coming to market, for those who like to really push the limits I know NOS is also in development for the N55, and most exciting of all a Cobb-AP style OBD flash tune manager is in the works. No 500whp is not an easy goal it requires a lot of supporting mods. But you wouldn't be the first to attempt this, and you don't need to be custom fabbing parts etc, with a large assortment of bolt-on mods and a proper tune you can easily break 500whp with an N55. So far the M3s and M4s that are pushing higher numbers have been blowing lots of parts on their cars, crank hubs, TPG's keyed crank hubs, rear drive axles, DCT components etc. So far the N55 has dealt with mods very well the only weak points that have arisen already are blowing the factory CP, ripping your stock DV, and in some cases busting your strut top hat. The F30 chassis, drivetrain, and N55 engine have proven to be very rigid and hasn't yet led to issues like the tuned F80/2s even though, The N55 and F3X chassis has been out on the market for several more years than the S55. Those of us with HP N55s are on the edge of our seat waiting to see what'll be the next point of failure for our cars but we've yet to find it despite cars already reaching the 650whp level.
02-28-2016, 01:28 PM | #29 |
Rep 512
I'd do an Xdrive M3 in a heartbeat! I love my F80 but i don't go powersliding around the streets and don't do burnouts either. No real advantage for me to have RWD over AWD. I'd rather get monster grip off the line and take off harder.
02-28-2016, 05:20 PM | #30 | |
Gettin It Figured Out
1820
Rep 2,669
This...^^^ .
02-29-2016, 02:31 PM | #31 |
Pace Car Driver
1548
Rep 3,164
03-21-2016, 08:12 PM | #33 |
Rep 9
After further research I have decided that doing port injection will achieve what I need for this.
I would appreciate a rep getting in contact with me to discuss options. |
03-21-2016, 09:42 PM | #35 | |
1820
Rep 2,669
Contact Daniel (PDU) . His PI Kits are on the record breakers. HERE .
03-22-2016, 09:06 AM | #36 | ||
Rep 902
OP, I'd recommend the PI kit, just remember you need new fuel lines and LPFP to accompany it. Also since you and I are on xDrive the raised manifold from the PI spacer makes the Drivers side charge pipe much harder to fit. I'm probably going to have to modify my ER pipe with a new silicone hose with an angle in it to keep it from rubbing the steering column. If it works I have some extra silicone couplers with angles that were all pretty cheap but still 4ply like the ER coupler PM me if you find yourself in need.
