10-31-2017, 01:46 PM | #1 |
Rep 332
Obnoxiously Loud Brakes: Need Advice
Hey Guys,
I have a 2013 certified m5 with the maintenance program and appx. 53k miles. After 10 minutes of driving, the brakes begin squeaking very loudly - specifically when brake pedal is about 60-75% engaged. My tech said that the brakes aren't worn enough to be replaced under maintenance program, so he took them apart, cleaned and lubricated them. This did slightly reduced how loud they squeaked but the noise is still there. I am wondering what options do I have, if any. The noise is obnoxious and embarassing enough that I would consider paying out of pocket for new pads. However, I wonder if there are other remedies that you guys may know of. If there are no remedies, what pads do you guys recommend? Thanks in advance, Eugene |
10-31-2017, 02:12 PM | #2 |
Rep 881
2014 "AW/SO"me M5
Mission Performance/3.5 Bar RK Autowerks/ CSF ICs SSP Spec-R KW V3/ Corsa Axle back |
11-23-2017, 10:55 AM | #7 |
Rep 294
I fixed the oem and carbotech noise squeal and dust issue by swapping to these pads....excellent and cheap pads "Power Stop 17-1648 Z17 Evolution Plus Clean Ride Ceramic Brake Pad with Premium Hardware Kit Included"
11-23-2017, 08:34 PM | #9 | |
Rep 5,237
What year’s your car? I only found these for 13’s. Not sure if LCI brake pads are different than 13’ models.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
11-25-2017, 10:28 AM | #11 |
Rep 294
11-25-2017, 11:59 AM | #12 |
Rep 5,237
My Cool Carbons are on the way out due to wear; I’m going to inquire in regards to the Powerstops and see if there’s any difference between 13’ and 15’ applications.
11-25-2017, 06:02 PM | #13 |
Rep 188
OEM pads nearly killed me, cool carbon better but over heat easily, and not great stopping, carbotech xp12 are incredible, double the stopping power of cool carbon - imo of course
11-26-2017, 11:12 PM | #15 |
Rep 161
