12-13-2017, 12:21 PM | #1 |
Rep 553
Somehow the mechanic who last worked on my car lost the wheel lock. Of course he is denying responsibility.
Does anyone know where I can buy just the wheel lock key? The dealer was trying to charge couple hours of labor to try every key they have. I have also heard these wheel locks cannot be broken off and no fire shop wants to touch them. Do all m5 have the same wheel lock? |
12-13-2017, 05:47 PM | #2 |
Rep 603
If you know of a welding shop nearby, have them weld (or tack) a bolt onto the lug with the lock and then remove it. You will need to buy a new lock set afterwards.
12-13-2017, 06:18 PM | #3 |
Rep 325
If it’s original locks provided by BMW they should be able to provide replacement.
Colleague bought a car recently and on inspection was missing the locking wheel lock key ..contacted BMW parts and after providing required details for security ordered a replacement |
Flying Ace4990.00 |
12-13-2017, 06:19 PM | #4 |
Rep 1,107
Grab a 12 point thin walled socket, maybe a 15mm or 16mm. Put it over the wheel bolt, it has to fit tight where you have to bang it on with a small sledge. The idea is to get the socket to press over the head of the lug. Get it on pretty good and slowly try loosening it. Then when you get all 4 off, never put them back on the car, replace with regular lugs.
12-13-2017, 08:05 PM | #5 |
Rep 149
I just bought a set of OEM locks and they came with two lug lock sockets. There was also a little card with a letter and number...( for example G5) try looking in your owners manual wallet and see if you have the little card...size of a business card. Then just ask BMW and they can get you a replacement. Given the torque on the studs not sure you will get a socket to wedge and not slip.....also don't want to get it expanded and wedged into the rim.....
Other toys
'07-997 Turbo....EVOMS 580..AWE exhaust...champion intercoolers..champion springs. '91-964 Turbo K27 Hf turbo...Techart Exhaust...etc, etc |
BMWM5NYC502.00 |
12-14-2017, 04:25 PM | #6 | |
Rep 1,107
OP here are a couple of videos I found for you to show you: |
12-14-2017, 06:14 PM | #7 | |
Rep 11,891
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
12-15-2017, 10:16 AM | #8 |
Rep 553
Dealer is no help they want to charge me multiple hours labor to use every key.
After some research on realoem there is 6 lock adaptors (keys) thst come with F10 m5. I am going to buy all 6 and hope one works. |
12-15-2017, 05:42 PM | #9 |
Rep 814
Tell them, you will buy a new set of locks from them, if they forgo the labor charge to try all the keys. That should work.
Formally known as BMWM3NYC
08-16-2020, 12:04 PM | #10 | ||||
Rep 29
08-16-2020, 06:44 PM | #11 |
Rep 195
On eBay you can buy a bmw master wheel lock key set. My buddy with an E90 M3 had the same problem went on eBay and bought the set for about $80 and worked flawlessly. Would post a link but can't figured it out. :
08-16-2020, 09:42 PM | #12 |
Rep 342
Drives: M5 Competition Package
This happened to me also my key got broken and I went to my BMW Dealership and the parts manager tried every lock key seemed like more than 6 keys mine was key number 41 but it only took 5 min not hours they don't even have to put the car on a lift just Insert lug key to lug lock and see if it fits. Have them do it in front of you and they shouldn't charge you anything bc it's so quick and easy to do and just buy the new key from them.
