10-16-2018, 03:39 PM | #1 |
Rep 67
RobbDubbs 2019 F31 OEM+ Build
Been a long time BMW enthusiast and finally ordered a full tilt wagon that I have been wanting for the past few years
Took delivery just over a week ago and am loving it more and more as I dial it in. On to the car.. 2019 330i xDrive Wagon Alpine White Black Dakota Leather w/ Oyster Highlight Ash Grain Wood Inlay Trim M Sport Package Premium Package Executive Package Track & Handling Package Heated Rear Seats Active Blind Spot Detection Wireless Charging Harmon Kardon While I waited for the wagon to arrive I couldn't help but start ordering parts.. so begin the mods Current Mods: H&R Sport Springs IND painted keyhole cover IND painted front reflectors IND red start/stop button and gloss black trim IND double slat gloss black kidney grilles With 26 miles on the car I had the H&R sport springs installed along with an alignment Made use of the wagon's abilities since its feeling like fall lately After parking with my sister's Tanzanite F80 I had to do something about the factory reflectors as well as the start/stop button install Last edited by RobbDubbs; 10-17-2019 at 07:56 PM.. |
10-16-2018, 08:47 PM | #3 | |
Rep 67
Thanks! Im actually going to go with a quad exhaust tip setup; Found a aftermarket "m performance style" quad tip diffuser on ebay awhile ago. |
10-27-2018, 10:18 PM | #6 |
Rep 423
Great loaded wagon and all but how do you even park in the same driveway as your sisters tanzanite f80 and not feel slightly crazy for spending 60k on a 4 cylinder wagon?
10-27-2018, 11:24 PM | #7 |
Photographer
243
Rep 142
Welcome to the F31 Club, which reminds me I need to start my own build thread. What quad exhaust are you going to go with? And do you have any pictures of the wireless charger I am curious about it's location or if I can retrofit that into my car.
BMW F87 M2 BSM LCI l BMWMTW0 l Group IG: BMWPlusOnes l Build Thread: Coming Soon....
10-31-2018, 08:33 PM | #8 | ||
Rep 67
Thanks guys! I have a few more mods to do, just need more time in the day.
It seems the wireless charger can be retrofitted as long as your vehicle has 6NSA the snap in adapter option. The wireless charging base has the same connector as the snap in adapter base. Your local dealer will be able to source the base for you, the base lists for $240. Part Number: 84-10-6-840-126 |
01-18-2019, 12:05 PM | #9 |
Rep 67
Few recent shots of the wagon, serving to be an awesome drive in the rain us Californians rarely see
01-19-2019, 05:52 PM | #11 |
Rep 1,523
What size spacers are you running? looks great!
01-22-2019, 12:04 PM | #12 | |
Rep 67
Grabbed a set of four 15mm spacers from a buddy and it was the perfect amount with these factory wheels; For reference they're 18x8 et34 all around |
01-22-2019, 07:58 PM | #13 |
Rep 191,471
Looks great!!
01-23-2019, 12:03 AM | #14 | |
Rep 1,523
https://www.etkbmw.com/bmw/EN/search...dX/USA/36_1979 Last edited by M4_GTS; 01-23-2019 at 12:15 AM.. |
01-23-2019, 07:21 PM | #15 | |
Rep 67
Well since its xDrive the US only receives a square set up when the track handling package is selected, I believe a 340i rwd with THP will receive the stagger |
01-23-2019, 07:33 PM | #16 |
Rep 1,523
I am pretty sure all the M-Sport and Track package F30 or F31, xdrive or rwd all comes with staggered wheels and tires. Your front tires in the pics is clearly marked as 225 and rear 255.
RobbDubbs100.50 |
01-23-2019, 07:43 PM | #17 |
Rep 67
08-01-2019, 07:47 PM | #18 |
Rep 67
Been awhile since I last updated this thread, not much has been done besides enjoying every aspect of this wagon
Went for a cruise up to Palomar Mountain here in San Diego Coworker ponied up on a new wheel setup so I had to see what they look like RAYS VOLK RACING TE37SL 18x9.5 et22 275/35R18 Toyo Proxes R88R 18x10.5 et22 295/30R18 Toyo Proxes R888R In the pictures I only mounted the front two wheels as 10.5 et22 was an insane amount of poke in the rear. If these were about a 32 offset they would fit much nicer |
_das_bae_374.50 |
08-01-2019, 07:57 PM | #19 |
Rep 67
Recently acquired an iDrive controller with ceramic controls out of a G12 and took it apart just for the faceplate of the buttons. Technically all plug and play but it did get a little technical with removing and installing the ribbon cable (did not take any pictures of that but you just have to be careful when pulling up on the cable.) One T20 screw in the dead center under the white sticker was holding the controller knob in place and after that there are a few clips on either side of the button faceplate
Also had to file my wood trim just slightly on the top left corner as now there is a moving part against the wood trim; The factory iDrive controller trim has a fixed plastic surround so no moving parts would interfere with the trim. Possibly not everyone would have this issue but I did just slightly. Part Number: 65-82-9-459-630 Looks to fit only G11/G12 but I have seen some G01 X3 vehicles with the same style faceplate. The non-ceramic control iDrive controller would work as well, just the center "MENU" button will be black plastic instead. I will note, I choose not to use the ceramic control knob because I liked the rubber on the factory knob as well as the aesthetics would not flow with the ceramic control knob; Unless of course I choose to swap out the radio button knobs I have seen on another thread. The knob does have a different style mounting so you will have to reuse the entire portion of the ceramic control knob when swapping it over if you desire that over factory. Last edited by RobbDubbs; 08-01-2019 at 08:33 PM.. |
10-17-2019, 09:10 PM | #21 |
Rep 67
Little update.. Acquired a set of Style 666M wheels awhile ago and finally mounted tires.
Can assure everyone on here 295/30R20 Michelin PSS do not fit on a stock body After the test fit fun I mounted the real tire setup on the 666Ms Michelin Pilot Super Sport 255/35R20 (20x9 et29) 285/30R20 (20x10 et40) Also got around to installing a set of mudflaps that I had paint matched to go along with the paint matched side skirt extensions. Brought the wagon down to Socal Euro last month here in San Diego Also ordered a M3/M4 steering wheel trim front and rear to clean up the factory steering wheel |
f31, h&r, ind, oem+, wagon |
