11-09-2018, 04:26 PM | #1 |
Rep 948
Oil consumption
A few months ago mine came up with add 1 litre of oil. My car had covered about 3k since the oil change. Tonight it came up again with add 1 litre. It can't have covered more than 1.5k since the last message i wouldn't have thought. My car has 41k on the clock.
How often do you guys top yours up and what is considered normal? |
11-09-2018, 11:02 PM | #3 |
Rep 191
Same here.
I'm not really worried about it. Seems normal if we're all experiencing it. But I really want to know where it's all going. That rate of oil consumption... Just burning it in the cylinders? I've got no leaks.. pretty sure of it. |
11-11-2018, 12:49 AM | #5 |
Rep 43
Ive had mine for about 6000kms now and had to fill up a litre of oil a couple of times, so yeah 1L per 3000kms so far. Ive also had to fill up the coolant once. The wrong coolant pic came up on the warning too.
I have heard that incorrectly breaking in a brand new m5 could lead to higher oil consumption. However it is normal for this car to consume(not burn) oil. Someone correct me if I am wrong. |
11-15-2018, 01:16 AM | #6 |
Rep 142
Bmw M5 F10 Oil Consumption
One the great fallacies is that “oil consumption” is ok on any engine or any Bmw Motorsport Engine .
Have a read of this blog which alludes to some of the possible causes : https://blog.bavauto.com/16943/bmw-h...-si-b11-03-13/ My St63tu engine burns zero oil ( I use Mobil1 0-40W) ; and it has 33km on the engine . It has never been thrashed when the engine was new and engine was “broken in” properly . Oil and filter are changed every year regardless of km/miles driven . And this the way to look after engines and always respect engine temperatures before using performance. This is my third Bmw and my first M vehicle with a Motorsport engine . I also have a 30 year old E21 320i and it burns zero oil as well . Cheers Bruce |
11-17-2018, 05:49 AM | #7 |
Rep 19,941
Around 1500 mi is about right depending on how you drive it and it's in your own interest to carry a 4 or 5 litre container of your chosen engine oil in the trunk hold cut out.
11-17-2018, 07:22 AM | #9 |
Rep 142
Oil Consumption
G’day Patty
What brand of oil and viscosity are you using ? Also see here re crankcase ventilation faults and oil burn/consumption : https://blog.bavauto.com/16947/bmw-c...b11-03-08-pcv/ Cheers Bruce |
11-17-2018, 12:13 PM | #10 |
Rep 101
My car has 46k mi. and I have had to add 3 qts in the past 4k miles. I'm switching the oil to Liqui-Moly Molygen 5w-40. I'll update on progress because I drive quite a bit. It probably won't do much.
2013 Black Sapphire Metallic, Sakhir Orange Interior, DCT
11-17-2018, 09:47 PM | #11 | |
Rep 43
11-18-2018, 05:40 AM | #12 | |
Rep 1,857
I have been in the forum long enough to see one can break in the car easy or hard, but the car may still consume oil regardless, it seems more like luck of the draw than how one broken in the car. But so far the F90 series looks good, haven't seen oil consumption issues yet... |
11-24-2018, 04:32 PM | #13 | |
Rep 222
11-27-2018, 07:45 AM | #14 |
Rep 142
Zero Oil Burn or How to Break-In an Engine Correctly
I’ve been working around Bmw Engines for over 42 years (and Oil burn is a problem I don’t have because every engine I’ve owned has been broken-in correctly ).
This is the most critical technique for the longevity your engine : https://www.roadandtrack.com/car-cul...ak-in-new-car/ https://www.maperformance.com/pages/...k-in-procedure Cheers Bruce |
11-27-2018, 10:42 AM | #15 |
Rep 20
Right, I had that worry shortly after I bought mine. It is normal. Mine takes a litre about every 1100-1300 miles. According to BMW:
"For BMW spark-ignition and diesel engines, the maximum permissible engine oil consumption is 0.7 l/1000 km. Because of their increased power output and torque, M engines have a maximum permissible oil consumption of 1.5 l/1000 km." Hope that helps |
11-29-2018, 07:52 AM | #16 |
Rep 606
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
I'm now over 2,000 miles into my first oil change since buying the car. The engine has 52k miles on it. I've used 1/2 quart of oil so far in those 2,000 miles. Thank god I finally have an ///M engine that isn't as thirsty as a drunken sailor. I run Mobil 1 0w-40.
My S62 drinks 1 liter per 1,000 miles on average. The good news is on that engine, the consumption rate hasn't increased in the last 165,000 miles. :-) |
12-04-2018, 01:06 PM | #17 |
Rep 257
Looks like there's a new lawsuit regarding the N63 & S63 oil consumption issues
https://bimmerlife.com/2018/12/01/new-n63-lawsuit-filed
Current:
2019 911 targa 4 | GT Silver Metallic 2019 X3 M40i | Glacier Silver Past: 2013 911 C4S | 2019 X2 M35i | 2015 M5 Comp | 2013 M5 | 2013 640i | 2010 535xi | 2007 525xi |
12-05-2018, 10:58 AM | #18 | |
Rep 606
12-06-2018, 09:53 AM | #19 |
Rep 1
Drives: 2013 F10 M5
up date
12-14-2018, 09:35 AM | #21 |
Rep 101
12-31-2018, 09:06 AM | #22 |
Rep 1,073
Drives: i5 M60, M5's, 535.335, M550i
I just got my 2013 M5 with 39k from BMW dealer so it was serviced and oil was at 100%. Lol 10 days and 800 miles, spirited miles mind you and oil level is just above the min mark when I measured it this morn. My last 535i used a quart per month with my driving habits.
2013 535i M, Carbon black 20' 6 M wheels, totaled.
2018 750M , 2013 M5 , Individual Silver, Bolt ons-Straight piped 2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete 2024 i5 M60 Cape York Green |
