12-19-2018, 06:30 PM | #1 |
Rep 60
Water temp at track?
Hi guys
Just wondering what kind of water temp everyone else are seeing when they do a few hot laps at a race track. I was checking out obd logs and found that my water temp was shooting up to 115 degC at a long straight and around 105~110 degC on average. This was only with 3 hot laps on a 3.4km long track. Oil temp was still below 120deg I believe. Air temp was around 20deg I think, so it wasnt a hot day either. |
12-20-2018, 02:35 PM | #3 |
Rep 60
Yes sport plus the entire time.
https://www.ecstuning.com/b-assemble...11537586885kt/ Just saw this one, seems like stock themostat is opening at 105deg opposed to the 90deg aftermarket one? |
12-20-2018, 03:14 PM | #4 | |
Rep 19,942
12-22-2018, 01:24 AM | #6 |
Rep 60
Checked a few things today, during idle once the car is warmed up, the water temp stays at 105c in economy mode.
When I change the mode to sport plus, the fan kicks in and temperature drops to below 95c. Did not stay long enough to see how low it would get but it was obvious that the temperature is dropping so the car has some sort of water temp control. I read from several posts saying that the ecu controls the thermostat electronically, but the stock thermostat do not seem to have any electronics in them except a temperature probe - according to what I can see from ECS Tunings website. I wonder how the car controls the thermostat - surely the stock thermostat is not a 105c one if the car can drop the temperature to below 95c. Yet I am seeing 110c+ after a very short drive which is worrying. I wonder if it is considered safe in BMW"s books. |
12-22-2018, 03:32 AM | #7 | |
Rep 19,942
12-22-2018, 05:26 AM | #8 |
Rep 1,107
It controls it electronically with a probe that heats up to melt the wax inside the thermostat housing which causes the thermostat to open and allow coolant to flow back to the radiator. Under normal / economy mode the wax melts on its own around 105* and the oil temps are kept hotter for better fuel economy - all controlled by the ECU. In sport plus mode the ECU tells the heating element in the thermostat housing to melt the wax to open the thermostat sooner and to open the oil cooler at a lower temp. It does this believing since the car is in sport or sport plus the car is getting pushed harder than economy mode and prepares for this.
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
12-22-2018, 06:45 AM | #9 | |
Rep 843
They should NEVER surpass boiling point, 100deg Celsius-212 deg Fahrenheit |
12-22-2018, 07:03 AM | #10 | ||
Rep 1,107
12-22-2018, 07:17 AM | #11 | |
Rep 1,107
12-22-2018, 12:03 PM | #13 |
Rep 2,352
This seems to indicate BMW are ok with up to 120c water temp.
https://f10.m5post.com/forums/attach...8&d=1360771557 |
12-22-2018, 12:13 PM | #14 |
Rep 1,107
Stole this from the F30 Forum credit to Highland Pete who originally posted this. Our engines uses the same parameters as the N55 for cooling oil and coolant temps. Just too lazy to type it out:
BMW Data for typical N55 Engine Cooling The engine control unit regulates the following temperature ranges: • 108°C/226°F = Economy mode • 104°C/219°F = Normal mode • 95°C/203°F = High mode • 90°C/194°F = High mode and control with characteristic map thermostat System Protection If the coolant or the engine oil overheat during operation, certain vehicle functions are influenced to the effect that more energy is available to the engine cooling system. These measures are divided over two operating modes: • Component protection - Coolant temperature between 117°C/242°F and 124°C/255°F - Engine oil temperature between 150°C/300°F and 157°C/314°F - Result: The output of the air conditioning system (up to 100%) and of the engine is reduced • Emergency - Coolant temperature between 125°C/257°F and 129°C/264°F - Engine oil temperature between 158°C/316°F and 163°C/325°F - Result: The power output of the engine is reduced (up to 90%) As you can see, 234F for engine coolant is still below any protection thresholds. HighlandPete
12-24-2018, 03:58 AM | #16 |
Rep 60
Interesting information, thanks guys. Who would've thought 115deg coolant was considered 'normal'.
I wonder if that other link i posted earlier about the thermostat is true though - suggesting the reason why bmw's are more prone to leak so much from all the gaskets compared to other cars is to do with the thermostat and allowing car to stay hot for fuel efficiency? |
12-25-2018, 02:07 AM | #18 |
Rep 2,352
12-26-2018, 12:44 PM | #19 |
Rep 843
Most runs I've done in about an hour is 10 40-150mph in 90 deg heat and about 90% humidity. I do understand there is a big difference in running it around a race track for miles and miles at a time.
12-26-2018, 04:51 PM | #20 | |
Rep 2,352
That is about 3 minutes of wide open throttle in an hour so it isn't too much, but on the other hand, Chad was doing ~6 minutes worth of hard driving or so and seeing the water get up pretty high. Here is the track fwiw. Like most tracks you're only on the throttle for about 50-60% of the time.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
12-29-2018, 04:08 PM | #21 |
Rep 222
I have in istagram video 260kmh-325km and water temps allway under 95°c and oiltemp 100°c-106°c and outside temperature about 15°c
Istagram veliniemi81 |
