03-11-2019, 03:45 PM | #1 |
Rep 541
How to charge while out of town
The manual isn't clear on this but i have a BMW trickle charger, i will be out of town for a month.
Where/how do i properly hook the charger up? |
03-11-2019, 06:08 PM | #2 |
Rep 1,107
Under the hood you will see the positive terminal and the grounding post. If your trickle charger has the pigtail you can bolt it that makes it much easier for future charging. GL
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
BeachM5nster273.50 |
03-19-2019, 09:34 PM | #3 | |
Rep 7,580
There are dedicated terminals in the engine bay for jump starting...these are the same points you should hook up a battery charger/tender/maintainer. Hooking directly to the battery or using one of the 12 volt charging sockets (cig lighters) can create issues. See the locations circled in white in the 1st pic below...and the 2nd NOTE in the 2nd pic for text from the BMW TIS on where to hook up a charger.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-19-2019 at 09:48 PM.. |
BeachM5nster273.50 Jasoneo539.00 |
