BMW 1 Series Coupe Forum / 1 Series Convertible Forum (1M / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i)
      04-23-2019, 05:12 AM   #1
NicR
Drives: 2005 BMW 120i
Sp Daten for 2005 120i E87 with N46 motor
Good Morning,
I hope someone on here can help with the issue I'm experiencing at the moment. I bought a 120i to rebuild and I've noticed recently that the Differential Intake Actuator valve doesn't function nor does it generate a fault code when I unplug it. Same with the MAF sensor.
After a bit of research I figured out that later models and especially the Low end power ones don't have this intake valve and also don't use the MAF sensor. So I suspect that my DME has had the wrong firmware upgraded to it.
I would like to try go back the the original or as close to it as possible. The Dme also has a fault code for "Coding Fault"
Would someone be able to assit me with old sp daten files so that I can attempt to correct this. I'm looking for the 2004 to 2005 files. I'm not sure what version this would be?
Thanks
Nic
coding, dme, sp daten, winkfp
1addicts
