10-14-2019, 04:16 PM | #1 |
Driver
200
Rep 516
Courtesy of btwillia's garage
N52 exhaust cam yields some solid gains for the n55..! |
10-14-2019, 07:59 PM | #5 |
Rep 969
Great stuff. +1 on video, before and after dyno and details. Very well done
10-14-2019, 09:18 PM | #7 |
Rep 358
Very well made video. Love that is just gives the useful information, cuts straight to the point, without a bunch of useless talking.
awesome job with the before and after information and numbers backing up the improvements
10-15-2019, 01:54 AM | #9 |
Dream crusher
984
Rep 2,421
Oh shit nice find! Looking into this more
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
10-15-2019, 03:23 AM | #10 |
Rep 2,357
Has this been shared on the forum or just in his Youtube channel?
(A Dane in China) |
10-15-2019, 04:29 AM | #11 |
Rep 373
this is a crazy mod and im going to look into this i need this haha, Gents i have some concerns here.
the car made 10whp on the second run after probably being let to cool down as im sure the cam swap didnt take 2mins so in theory it could have made that 10whp from just letting the car cool down alone? secondly shouldnt a n55 with those mods be making that power with out the cam in the first place?
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
10-15-2019, 07:51 AM | #12 |
Rep 1,348
Can you please post the specs of the N52 exh cam vs the N55 exhaust cam.
2k15 335i Msport xdrive 6spd
10-15-2019, 12:08 PM | #13 | |
Rep 1,105
Made an additional 40-50 whp after re-visioning the tune. So you will need to have a custom tune to extract the potential power after install.
10-15-2019, 12:09 PM | #14 |
Rep 5,372
Those rod bearings were hammered by detonation. This should be a warning to those that want to push a lot of low rpm boost/torque and/or go full throttle at a low rpm while in a low tall gear creating a high boost and high load situation. This is where you can generate a lot of detonation and Low Speed Preignition (LSPI).
FYI the rod bearings used in the 2014+ N55s are the same ones used in the S55. They are strong but tuning and safeguard are key. Nothing lasts long behind a lot of hammering. |
10-15-2019, 03:02 PM | #16 |
Rep 5,372
His videos say 2015 335i so it's EWG. He's also pushing a lot of torque through that N55. Before the cam it was making way more power than a stock S55.
10-15-2019, 04:31 PM | #17 | |
Rep 4,146
Either way, I know the tuner who came up with the idea, and a few people looking at cam regrinding and modifications |
10-16-2019, 02:19 AM | #18 |
Rep 2,357
BMW part # is 11317563665?
(A Dane in China) |
10-16-2019, 12:54 PM | #21 |
Rep 75
Its going to depend on your age or mileage on the motor as to what else you would look at .. you could just replace the exhaust cam,, but that's a lot of labor to not look at other items too.. unless your doing yourself.. in addition Id take a hard look at BPCs custom MILV solution.. for the intake side.. +1mm in intake valve opening. together could be a real solution without pulling the head and porting etc.. cool stuff coming together out there...
2014 F30 N55 EWG - BigBoost 3.3 Turbo Kit - N52 Exhaust Cam - BPC MILV - ER FBO - AFE Momentum CAI - XDI-35 - MPE w Carbon tips - MHD Custom Tune by efi_bob at Stage Fabrication - 19" Apex Arc 8 w 255/35 square - Bilstien B14 Coil-overs - GC Camber plates - Solid Sub-frame bushings - Powerflex Diff Bushings - BMW L/S Diff - XHP Trans tune -600whp 511wtq on pump 93 with Meth PI
10-16-2019, 03:51 PM | #22 | |
Rep 221
