01-20-2020, 03:51 AM | #1 |
Rep 13
F30 NBT FBAS video input (Apple Carplay / Android Auto possibility?)
Hi all,
I apologise if this has been covered before, but I've searched here and on google but haven't found anything conclusive. When looking on obdii365.com, I found the following pinput for NBT headunit: The additional FBAS inputs 3 + 4, on the seperate connector are marked as DVD and TV. So in total there are 4 FBAS inputs: TRSVC (for rearview camera), Baseplate, DVD, and TV. I presume TV is for when a TV tuner is installed, but the others, I have no idea! Is it possible to pin these connectors, and then code them to enable video input to the head unit? If this is possible, I imagine an inexpensive android box or a CarPC could be added to enable a makeshift Android Auto or Apple Carplay system. Anyone know if these FBAS inputs can be used? Thanks |
01-20-2020, 03:53 AM | #2 |
Rep 93
01-20-2020, 04:03 AM | #3 | |
Rep 13
I personally don't like these solutions as they're just a 'hijacker' inbetween the LVDS connection from headunit to display... If possible, coding the FBAS video input would be cheaper and more elegant. |
01-20-2020, 08:50 AM | #4 | ||
Rep 10,473
01-20-2020, 10:54 AM | #5 |
Rep 13
01-20-2020, 10:57 AM | #6 | |
Rep 10,473
Most HU do not have TV option and input for example. Many of the connections shown on your example might not exist on your actual HU. |
01-20-2020, 11:20 AM | #7 | |
Rep 13
Mine does have the socket for the 12pin locking connector on the back of the head unit, but I can't remember which pins (if any) are present. So if I got lucky and mine did have DVD and/or TV FBAS connections: what's next? can they be used as generic video inputs? Thanks again. |
11-02-2020, 02:50 AM | #8 | |
Rep 5
I found this AV-IN socket from a Mini Cooper, which I want to install in my 435 armrest. https://www.realoem.com/bmw/enUS/sho...66#84109264966 Next step would be to connect this AV-IN socket to my NBT. Did you find out which FBAS to use? Btw, I have 6NR VO option already, factory default. Thanks |
WallaceK9.00 |
08-17-2024, 10:40 PM | #9 | |
Rep 29
