04-04-2022, 04:27 PM | #1 |
Rep 10,891
IND | Install Guide: Future Classic E9X M3 (S65) Oil Filter Housing Cap
Tools Required:
STEP 1: Open the hood and ensure your vehicle's engine bay is cool to the touch before beginning the installation process. STEP 2: Using a 36mm oil filter socket, remove the OE oil filter housing cap. STEP 2a: [If performing an oil change], follow the dealer recommended procedure and drain the existing fluid from your vehicle and remove the filter unit. STEP 2b: [If performing an oil change], once all the old oil has been drained, dispose of the fluid safely and carefully reinstate the OEM drain plug. STEP 2c: [If performing an oil change], fill your vehicle with the recommended oil type and quantity. STEP 3: Install a new OEM oil filter housing o-ring onto the FC cap and pre-lubricate with fresh oil. STEP 4: Place new OEM filter unit into the oil filter housing base. STEP 5: Remove the filter stock from the OE oil filter cap and snap it into the FC cap. Install the assembly onto the housing base. STEP 6: Finish by torquing the Future Classic oil filter cap to 25Nm.
11-05-2022, 03:12 PM | #2 |
Alex - IG @screamer
613
Rep 475
Do you guys have a picture showing the difference between the Hard Coat Clear vs. Hard Coat Black?
Instagram: @screamer
- 2013 Subaru STi Hatch - White - Racecar - 2011 BMW E92 M3 - Moonstone - Collector Car - 2008 BMW E90 M3 - Silverstone - Racecar |
11-06-2022, 10:22 PM | #3 | |
Rep 10,891
reidetailing612.50 |
11-20-2022, 06:39 PM | #4 |
Alex - IG @screamer
613
Rep 475
Is the hard-coat Black available and in stock? Or still in production?
11-21-2022, 10:09 AM | #5 | |
Rep 10,891
