BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
European Auto Source (EAS)
      01-20-2009, 06:06 PM   #1
808MGuy
808MGuy's Avatar
221
Drives: 2009 E90 M3
For those that replaced their front door speakers
Did you cut the moisture barrier to allow the speaker to utilize the airspace in the door cavity or did you leave it sealed? It seems that the available airspace between the barrier and the door panel would not allow for optimal bass performance. Increasing the amount of airspace behind the speaker would help. I know there might be some risks to cutting the barrier which is why I'm asking if anyone has done it without having problems.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
      01-20-2009, 10:31 PM   #2
kmax1980
Drives: 08 E93 M3 Jerez Black/Fox Red
depends on what you consider "optimal bass performance"....using the airspace would most likely increase in midbass volume, but would most certainly sacrifice sound quality..... many woofers are designed for a moderate-to-limited sized airspace, which helps control the travel of the cone and creates tightness in the sound... opening things up into an "infinite baffle (IB)" type of setup will create distortion at loud volumes in many loudspeakers, unless they are deigned for IB application (those that are, are usually advertised as such).
Just something to consider, although most car manufacturers (actually not sure about our bmws, and i do doubt they intended to create a sealed enclosure using weatherproofing) don't take this into consideration and most often mount door speakers without a sealed or properly ported enclosure. People who install high end audio aftermarket in their cars, usually opt for a sealed or ported custom fiberglass enclosure even for their front mid-bass woofers...
      01-21-2009, 12:11 AM   #3
808MGuy
808MGuy's Avatar
221
Drives: 2009 E90 M3
Actually most car audio marketed midbasses and midrange drivers are made for IB applications because that would be the most common application when you're dropping it in a stock location. I've had a lot of high end gear in the past and most were optimized for IB applications. BTW, most sealed door cavities would still be considered IB for a small midrange/midbass driver because the volume of air in that cavity is typically more than 10x VAS which is about the range for an IB application. The reason many seal off all the holes in the door panel is so that the front wave and the back wave coming from the speaker cannot interact with each other and cause cancellation or destructive interference.
      01-21-2009, 09:45 AM   #4
kmac1980
Drives: '19 540xi
true, i guess im thinking more of IB subwoofers, which are rarer....
I did however have an audi with a bose system in the past where the doors had properly ported enclosures for the midbass that werent IB, i completely replaced the system, and found MB Quart speakers sounded phenomenal in the factory enclosures...
another thing is, do you know what the crossover point is from the midbass drivers to your floor mounted subwoofers? my guess is its pretty high (over 100hz) and those floor woofers are almost pushing into midbass (they distort because of that at high volumes i find).... i dont know how much you could improve the midbass out of the door speakers without changing amplifiers/crossovers
do you have the upgraded factory system? this is an interesting topic to me as im definitely looking for weak points in the system that small mods will help...
      01-21-2009, 10:52 AM   #5
808MGuy
808MGuy's Avatar
221
Drives: 2009 E90 M3
I have the base system. I'm not planning to just replace the speaker. It would be a total upgrade sans the head unit. I'm not sure what the exact crossover frequency of the mid/sub transition is but it has been estimated to be somewhere around 200-250 Hz. I have never experienced audible distortion from the subs at any sane listening level. The base system is actually pretty good and sometimes I feel like doing a total upgrade might not be worth it because there is not a lot of room for improvement.
      01-21-2009, 11:37 AM   #6
kmac1980
Drives: '19 540xi
yeah, i have the upgraded system and defintely debate the value of upgrading.... but 200-250hz is way too high for subs.... I notice it in songs with heavy 100-200hz bass with the volume up, the subs get muddy, not full on distortion, but it sounds bad.... proabably because theyre trying to do too much
      01-21-2009, 11:57 AM   #7
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
I did not cut it. I put in Diamond Audio S400 speakers in there and the midbass is great. I moved the high-pass down to about 80 Hz and it was surprisingly powerful. But moving the crossover frequency to 125 allowed them to play louder and cleaner. Subs sound good up to 150 hz. Since they are near the front, it's not so easily localized.
      01-21-2009, 11:59 AM   #8
Technic
Technic's Avatar
2307
Drives: 2021 i3S, 2024 i4 M50
The sweet spot in the OEM Premium system 4" components is around 150Hz. I tried 250Hz first, then 200Hz and finally 150Hz ended up being the best sounding crossover point between the SWS-8 and the OEM 4" drivers.
About that OEM moisture barrier in the door, I would not mess with it unless you create another moisture barrier on whatever hole you make. Water and moisture always find ways of messing things up. I would say, replace the underseat woofers first with the SWS-8 or with a custom shallow 10", tune it to 250Hz/200Hz/150Hz and listen to each case. Then decide if you will need extra mid bass from the 4" in the doors.
I think that there is a general misunderstanding on the capabilities of this central bass location and the reason of why BMW combined this bass setup with multiple 4" mids all around. The SWS-8 has to be tuned with an EQ to really get deep -not quite sub deep but it can fool it- and solid mid bass all the way to 250Hz without any sound issues. And some aftermarket 4" drivers -including the Premium OEM- can go down to 150Hz and still provide tight sounding mid bass that can blend nicely with the bass under the seat.
      01-21-2009, 12:09 PM   #9
808MGuy
808MGuy's Avatar
221
Drives: 2009 E90 M3
Thanks! I saw those S400s but never heard them. How do you like them? What other aftermarket sets have you compared them to?
      01-21-2009, 12:21 PM   #10
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
I used to work in the car audio business, installed and also competed. The S400s are pretty good. Definitely several steps up from stock. The reason I chose them was because of the price and ease of installation. There are not a lot of choices for 4" components because 4" components are not a good idea in general. Some of the 4" speakers would not fit depth-wise. Some had huge crossovers that would not fit in the doors. Some had large tweeters that would not fit in the original location. I saw the S400 specs and I thought the install wouldn't be too difficult. The only challenge was the crossover. I had to take it apart and got a little creative to mount it in the door panel cavity. It wasn't easy.
If I was the same installer years ago, I would have gone for the best and made it fit no matter what. Now I just want something better that won't compromise the car too much. I used to always run a big sub boxes that would weigh over 100 pounds. These days I spend more money trying to reduce the weight on my car. It's an M so I need to stick with the purpose. These speakers are more than good enough and what they don't do well I can fix with equalization.
      01-21-2009, 12:24 PM   #11
Technic
Technic's Avatar
2307
I used to have those in my old MKV GTI and they sound great... and only cost me some $160 brand new with silk tweeters at eBay; sets with aluminum tweeters are also available. Retail was supposed to be $400. The 4" drivers in the MKV GTI are the same depth as the E9x 4" drivers, as badfish confirmed.
One thing though: forget about installing its crossovers inside the doors: the suckers are as big as a Cracker Jack box. In my case I used instead CDT Audio compact crossovers...
      01-21-2009, 12:34 PM   #12
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
Here's how you do it. You remove the circuit board from the crossover. Slice the plastic ribs on the door panel in the position below (you don't have to remove the ribs, I actually use them to kind of hold the crossover in place). Put a bunch of hot melt glue on the panel where the crossover will go. Then put more hot melt glue to hold it in place after you set it. If it is in the proper position with the depth minimized, the door panel will just snap right back in no problems. If it is not, then the coil will hit the door and not allow you to snap the panel back in properly. Position is key...
      01-21-2009, 12:37 PM   #13
Technic
Technic's Avatar
2307
Thanks... in the Sedan that circuit would be placed much better in the lower right hand corner of the door panel in that photo. The Sedan door panel doesn't have that lower right storage bulge shown in the photo.
      01-21-2009, 12:52 PM   #14
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
Yeah the coupe door panel leaves almost no room to work with. I believe that is the only place the crossover could possibly fit. For a while, my door panel had this gap in it that I didn't see and that was because of the coils hitting the metal on the door. When I spotted it, I had to take the door panel off and adjust the position of the crossover. That's the great thing about good hot melt glue. With enough surface area, it holds very well. When used against plastic, you can cleanly remove it and start over again.
One other thing to be wary of when installing the speakers on the coupe. You will probably end up using the grill that the speaker comes with. If it is too far forward with respect to the car, it will hit the dash. So be very careful when closing the door after you install your speakers. Make sure there is adequate clearance between the grill and the dash. There is more than enough room for adjustment. At first, mine was just barely touching the dash. I adjusted it to where I probably have 1/4" clearance which is plenty.
      01-21-2009, 02:46 PM   #15
808MGuy
808MGuy's Avatar
221
Drives: 2009 E90 M3
Luckily I don't plan on using any passive crossover networks so I won't have to worry about that
Crap. I was hoping to use the stock grill to keep everything stock looking. Did you have to use the Diamond grill because you had to mount the mids from the front for depth clearance?
      01-21-2009, 03:14 PM   #16
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
I think it was because the Diamond didn't fit well from behind the grill. No mounting points and I think the surround would have hit the panel.
Stock vs Diamond
Stock mounted in door panel
Diamond mounted in door panel
      01-21-2009, 07:49 PM   #17
eagletangogreen
Got Track!!!!!!
eagletangogreen's Avatar
Drives: 08 M3 coupe
Anyone wanna do my stereo?? Id rather pay you guys thats done this than some shop that has not!
      01-29-2009, 09:21 PM   #18
aus
Drives: Odysse
Nice pics!!!
Any reason you couldn't use the stock wiring and place the cross-over's in the trunk? That's how we did it in the X5 i had.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      01-29-2009, 09:27 PM   #19
Speedtrap
Drives: A very fast car :)
Thanks for sharing...always wanted to do this upgrade. what amps are you guys using?
      01-30-2009, 03:24 PM   #20
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
Originally Posted by aus View Post
Nice pics!!!
The tweeter and driver are powered off of the crossover. The OEM speakers had a single speaker wire run to each door and the tweeter has a coil on it. I would have to run extra wiring if I were to place the crossovers in the trunk.
      01-30-2009, 11:00 PM   #21
aus
Drives: Odysse
I see. Do you have the standard stereo or the upgrade?
My old X5 hae speaker wire from the DSP amp to the mids and separate cables to the tweets. It seems like BMW changed the way they run their speakers. Thanks for the info.
      01-31-2009, 11:31 PM   #22
badfish
badfish's Avatar
102
Drives: E92 AW M3
2008 M3  [0.00]
Standard audio.... it makes it a lot easier to upgrade.
m3post
