BMW 1 Series Coupe Forum / 1 Series Convertible Forum (1M / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i)
      02-21-2008, 11:44 PM   #1
ktdw
BMWCCA #401908
ktdw's Avatar
54
Drives: 135i
Coilovers or Springs...what about Wheels?
I'm ichy to purchase all of my first mods before my 135 gets here, and probably the first performance mod is wheels and suspension. However, I have no idea of the what/when.
1. So, should I get coilovers or springs? I thought recall reading that you shouldn't just change the springs...what do you guys think? Now, this car will (here's hoping) see some track days, but it most likely see spirited street driving.
2. What about anti-roll bars? I see that the tirerack has them for the 135, but I'm not sure if it the "right" one.
3. Also, I will also replace the OEM wheels and tires, but shouldn't this be done at the same time as the above? I thought that getting more rubber up front would reduce the understeer, and perhaps change the suspention setup. Of course, we also need to know what size wheels will fit.....
Thanks.
      02-21-2008, 11:52 PM   #2
infinitekidM2C
infinitekidM2C's Avatar
Drives: 2019 M2 Competition
since ur from Cali i'll respond..
1. defintely get coilovers..im waiting to see if Bilsteins RideControl will work for our cars..but no telling so we have to wait..sucks
2. if they are eibach..they should be good stuff
3. wheel situation is up in the air..not even tirerack knows what will fit yet..i am bad at waiting but i suggest a little patience..wait until we get some confirmation regarding what will fit..don't go on what many think will fit
my response will not make u happy now but in long run..it will be best thing..
      02-22-2008, 08:27 AM   #3
BMWeber
Drives: 08 135i
1. coil overs are over kill unless you are a real track junkie or want to be able to say I have coil overs(bilstein PSS9 isn't even a true full coil over setup). coil overs are also more complicated. but when you change springs you should do shocks also. a nice set of H&R springs and bilstein sport shocks would work awesome.
2. if they sell them for the 135i they'll work just remember the difficulty/expense of the rear bar installation.
3 does not need to be done at the same time as suspension
      02-22-2008, 08:58 AM   #4
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Drives: 997S, MV Agusta F4, E46 M3
What's the issue with the rear ARB installation???
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU
      02-22-2008, 09:04 AM   #5
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
You have to drop the rear subframe to get access to remove the old bar, and install a new one. The sway bar routes on top of the subframe, just as it does on the current 3 series cars.
      02-22-2008, 09:22 AM   #6
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Any idea the labor cost (hours involved)? Seems a very fitting mod to help reduce the dramatic understeer I experienced in the car on a dry but cold/windy day.
      02-22-2008, 09:31 AM   #7
larryn
Unfortunately not. For the 3er, I think it takes 3 hours to do. For the 1er, who knows yet. :iono:
      02-22-2008, 09:50 AM   #8
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
^^ It's worth it. Those tweaks make all the difference in the world (if you're like me and can be easily annoyed by things like understeer, tire noise, poor damping, body roll, etc.).
      02-22-2008, 10:21 AM   #9
BMWeber
Drives: 08 135i
do you go to track events much or autocross? if yes then the understeer would be noticeable. on the street you'll never be able or should push the car hard enough to be an issue. also springs shocks and proper front camber should be enough to solve any understeer problems. also I run a stock 325i rear sway bar in my E36 M3 race car.
      02-22-2008, 10:26 AM   #10
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
^^ With my TT, I did coilovers (KW V3) first and afterwards didn't see the need for different ARBs. However, I've driven the 135i aggressively on familar (very curvy) roads here in Germany and the car plows far more than I'm used to and I don't like that. Steering seems good and quick, but the front end lacks grip. I'll probably do the same as the TT, mount KW V3s (or maybe V2s this time) and evaluate. I also hit Nurburgring every now and then and that place really shows if you have a bad suspension setup. I like a very neutral cornering car with minimal body roll and lots and lots of grip!
      02-22-2008, 10:56 AM   #11
BMWeber
Drives: 08 135i
didn't relize you had first hand experiance with the 135i, very cool. have you read any of Advevo post. he has already moded his 135 with springs bigger front tires and more -camber and says the understeer is gone. so all depending on how you like your car set up sway bars are more of a personal preference. I personally don't recommend large rear sway bars on higher powered RWD cars. it makes it harder to put the power down coming out of a corner.
      02-22-2008, 10:58 AM   #12
1ForAll
1ForAll's Avatar
141
Drives: E92
3. As far as wheel size is concerned, I think with F19 X 8 and R19 X 9 with the OEM offset you should be fine. Anything larger and you will have to roll your fenders.
"Go with Ray's. His e92 is God." - mashimarho
      02-22-2008, 11:01 AM   #13
BMWeber
Drives: 08 135i
you people that live in places with warm weather and your 19" rims
      02-22-2008, 11:10 AM   #14
1ForAll
1ForAll's Avatar
141
Drives: E92
LOL I have 18's on my car now. It rains a mess load down here, and we have hurricanes
      02-22-2008, 01:39 PM   #15
groovyjay
Individual1
groovyjay's Avatar
Drives:
Coil overs are not an over-kill. There's a difference betweem how you tune/adjust and what spring rate you use on the street. I have coil overs on all my cars, Koni, QA1 and KW stuff. On my track car I have 6 different spring sets so I can choose the right spring for the each individual track. the coil overs for the street however only need one set, that gives you the best handling and ride with properly set up rebound and compression, once you have the right combination you are happy to cruise around for million miles. :biggrin: The coil over kits offered for street car by the big manufacturers are usually set up for street use already...:headbang:
      02-22-2008, 02:17 PM   #16
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
Going with H&R springs for dd use. If I were tracking her I'd def. go with a coilover setup.
A bit off topic, is there any real difference between H&R & Eibach besides the lowering rates?
      02-22-2008, 02:51 PM   #17
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
I've had both...
I'll take H&R any day.
I found Eibach too soft in the 1st stage progression.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      02-22-2008, 03:02 PM   #18
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
^ Good to know, thanks.
      02-22-2008, 03:27 PM   #19
BMWeber
Drives: 08 135i
I fully understand what your saying. but ktdw seems like he is pretty new to the suspension mods and the easiest and best all around for street use is using the standard spring mounting positions witch also the best for your warranty. and a lot of these coil over kits for the street give you no measurable performance gain but cost more.
      02-22-2008, 04:21 PM   #20
NJKSC27
automobile aficionado
111
Drives:
i have experience with Eibach springs only and they seem alittle too soft for me. i have driven a car with H&R's and i think they seemed alittle more firm.
      02-23-2008, 12:18 PM   #21
ktdw
BMWCCA #401908
ktdw's Avatar
54
Drives: 135i
Thanks for the responses. Why is it recommended to change the shocks if you change the springs?
Also, can you explain a little why coilovers are more complicated? It seems that coilovers are bought in a kit, and that all is necessary is the install. But for springs and shocks, you need to do a lot more thinking about which springs go with what shocks, etc.
      02-23-2008, 12:21 PM   #22
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Amen!
1addicts
