05-10-2008, 09:23 AM | #1 |
Rep 243
Slotted & drilled rotors don’t improve braking performance!
Did anyone read the Grassroots article on brake upgrades this month? It highlights slotted rotors, big break kits and SS lines only improve the looks of a car not performance. Note some cars are in exception to the rule, 135 is not.
In fact most big brake kits and aftermarket calipers introduce knockback and improper balance. |
05-10-2008, 09:32 AM | #2 |
Rep 10,176
I've always said that the decrease in surface area by drilling/slotting makes the brakes work harder, and negates any cooling benefits.
05-10-2008, 12:04 PM | #4 | |
Rep 282
Thanks Good info!! |
05-10-2008, 02:44 PM | #6 | |
Rep 243
Most passing in road racing is done under braking, if you cant stop you lose. In addition slotted rotors crack more often that solid rotors forcing frequent expensive replacements. |
05-10-2008, 04:42 PM | #7 | |
Rep 72
No one has said that it reduces braking performance, merely that it doesn't improve it. 3 LBS of unsprung rotating mass on each wheel is a LARGE difference if your getting down to details and for 4 years you can get those expensive rotors replaced for free under the maint program as long as you buy the first pair. |
05-10-2008, 08:01 PM | #8 |
Rep 10,176
3lbs that close to the hubs doesn't make than much difference, a little, not a lot. If you're talking about lighter tires, or wheels.. that's way more bang for the buck in better acceleration, throttle feel.
05-10-2008, 08:12 PM | #9 |
Rep 243
05-10-2008, 10:44 PM | #10 | |
Rep 77
Here's a related article on this aptly named "The Truth About Brakes". |
05-11-2008, 08:48 AM | #12 |
Rep 7,594
Drives: '19 M2C
Don't slot/cross drilled rotors help in rain...the ability to vent the water from between the pad and rotor?
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
05-11-2008, 01:16 PM | #14 |
Rep 7,594
Drives: '19 M2C
Maybe an opinion. :iono:
05-11-2008, 01:45 PM | #15 |
Rep 932
05-11-2008, 03:28 PM | #16 |
Rep 2,012
I think weight is pretty important, and drilled are more heat resistant, so that does make up for some of the braking surface lost. If it is slotted, it will eat the pad more evenly which gives better braking, less vibration. And as for drill/slotted rotors cracking, it depends on how the rotor is made. If it is casted with holes, then it's fine, but if drilled it will lose it's integrity.
05-11-2008, 04:07 PM | #17 | |
Rep 777
Also, the weight of a rotor represents thermal capacity, which is a good thing on the track. Mass rotating at the rolling radius of a wheel appears twice as great with respect to acceleration as weight fixed on the vehicle because it has to be accelerated to both the translational speed of the vehicle and to a circumferential speed equal to the translational speed. This means that rotating mass attached to the wheel can never be credited with an effect greater than twice its actual mass. The average radius of the rotor disc is about 5", the rolling radius is about 13", meaning the circumferential velocity of the mass lost by drilling is about 38% of the vehicle velocity, producing an effective mass loss of about 115% of the actual loss. If 3 lbs could actually be lost from the rotor this would be equivalent to about 3.4 lbs in performance terms. As Larry points out lighter wheels or tires would have much more effect, because the weight lost would be at a larger effective radius. Many of us that actually track our cars have learned that plain rotors are not only cheaper, they work as well or better than drilled or slotted rotors. |
05-11-2008, 04:22 PM | #18 |
Rep 7,594
Drives: '19 M2C
I'm not referring to BMW's, I mean in general.
05-11-2008, 04:28 PM | #19 |
Rep 7,594
Drives: '19 M2C
LOL The Cross Drilled Rotors vs. Normal rotors is like an oil thread. Nevertheless, I really like the BMW rotors and may install them regardless.
05-11-2008, 04:33 PM | #20 |
Rep 932
05-11-2008, 05:00 PM | #21 | |
Rep 243
