07-14-2008, 02:51 PM | #1 |
Rep 1,609
Best suspension mod?
What is the best bang for the bucks? Just spring first then sway bars later, or sway first then spring, or both at the same time? Will most of the sport spring lower the 135's M suspension by another 1 inch drop? Thanks for the help.
07-14-2008, 03:06 PM | #2 |
I no longer work for United BMW!
308
Rep 3,330
Drives: E46 M3, E46 330i ZHP, E36 325i
It all depends on your taste. There is no "best." Best is determined by the driver. I prefer a 1.4 drop in the front and .75 in the rear
BMW CCA, PCA, & CHIN Motorsports Instructor.
07-14-2008, 05:37 PM | #3 | |
Rep 13,583
Drives: JB E92 335i
How great is the KW Coilover? Well like I'm sure you've read around, the M3 CSL that had the Nürburgring time record has been using the Bilstein coilovers for 2 years...Last year, they switched over to the KW coilovers, and they finished "The Ring" ~30 seconds faster than with the Bilsteins...what does that mean? The Bilstein Coilover that they had record time on was beaten by a whopping 30 seconds just by switching over to the KWs. Sure, KWs aren't as expensive as other coilovers, but who says that more expensive means better performing?? :biggrin: Plus, with coilovers you get all sort of adjustabilities, including height, so you can your own individual look that you're going for. As for sway bars, I would probably get that second after the Coilovers, unless you have the ability to get both at the same time--then you can expect an ultimate setup in suspension! |
07-15-2008, 10:55 AM | #4 | |
Rep 6,759
But I'm open-minded enough to get educated about it - and if true, a set of KW would be my first mod. So where did you get this info?
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
07-25-2008, 02:02 AM | #6 | |
Rep 1,565
1. tires 2. rear sway 3. front camber plates 4. KW Coilovers (I highly reccommend the V3's) |
07-25-2008, 05:45 AM | #7 |
Rep 863
07-25-2008, 09:58 AM | #8 |
Rep 1,609
You mean just thicker rear sway and leave the front sway remains stock? So, you think spring will do nothing other enhance the look? I heard the rear sway is pain in the butt to install. Can I just do the KW coil over and how difficult to install? Would it be the same effort as replacing the springs? Thanks in advance for your help.
07-25-2008, 12:28 PM | #9 |
Rep 4,822
07-25-2008, 01:21 PM | #11 |
Rep 304
07-25-2008, 09:13 PM | #12 |
Rep 1,201
Love the mind of professionals!! When will the seminar of "Cars 101" start? Very interested! :biggrin:
07-25-2008, 10:09 PM | #13 |
Rep 4,311
Drives: Supercharged E90 M3
why not just some H&R Sport springs?
07-27-2008, 05:22 PM | #16 |
Rep 1,804
If you're looking for the most noticeable difference in handling I'd go with a set a swaybars. I just got some for my 325Ci and the handling is greatly improved.
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
07-31-2008, 04:46 AM | #17 | |
Rep 1,565
Stiffer springs (lowering springs) will also improve handling as well (lower CG, less body roll, etc) but most of you guys will do it for the looks, the improved handling is a bonus. Yes, you can install just the KW coilovers only. It's a virtually identical install for springs only vs. coilvers (V1, V2, or V3). |
08-02-2008, 05:03 PM | #19 | |
Good life
130
Rep 1,937
I did a bigger rear sway and stiffer endlinks on my old Subaru STI and the handling was night and day. Since this is a rear wheel drive car, would going with too thick of a bar bring the tail end out more since you making it stiffer? What size bar would be perfect for the rear? And would you also recommend endlinks? Just seems like it would help even more.
Current: 08 E90 M3 Alpine White Former: 11 135i Msport Space Gray -Former: 07 335i Titanium Silver E92- Former: 08 135i Alpine White E82- Past: 06 Subaru STI WRB- Past: 04 Audi S4 Imola yellow- Past:97 Honda prelude Ice blue
