BMW 1 Series Coupe Forum / 1 Series Convertible Forum (1M / tii / 135i / 128i / Coupe / Cabrio / Hatchback) (BMW E82 E88 128i 130i 135i)
      08-28-2008, 10:13 AM   #1
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
Rear Shock Mounts
Does anyone have recommendations for good rear shock mount for our cars? Are E9x RSMs the same fitment? I'm looking to upgrade from OE when I do a Koni install.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      09-07-2008, 04:41 PM   #2
Charles1
Drives: 135i
Mikeo I sent an email to TC Kline I will let you know what he says.
      09-07-2008, 04:58 PM   #3
Terp1
Terp1's Avatar
Drives: '01 BMW 325Ci
Here are some from AST. http://www.vorshlag.com/product_info...products_id=89
      09-08-2008, 06:42 PM   #4
mikeo
Santa Fe Concorso
mikeo's Avatar
Thanks for the suggestions, I'll check them out.
      09-08-2008, 08:28 PM   #5
Terp1
Terp1's Avatar
I don't recall reading about anyone changing out the rear shock mounts, so I'll be interested in your experience if you go this route. Also, I'm going with the TC Kline DA setup. Is this something to consider?
      09-08-2008, 11:10 PM   #6
mikeo
Santa Fe Concorso
mikeo's Avatar
The Bimmerworld OLOA car's OE RSMs failed and they had to be replaced during the event, IIRC.
      09-09-2008, 02:09 AM   #7
Charles1
Drives: 135i
Don't know if this helps...
The D/A shocks that we put in your car come with a new steel sleeve that
fits into the stock rubber. We then sandwich the rubber with steel
washers of the same diameter. The upper mount on this car is totally
different than the E36-E46 and there is not a monoball option.
      09-09-2008, 08:33 AM   #8
mikeo
Santa Fe Concorso
mikeo's Avatar
Thanks for checking it out for me! I may just go with the OE RSMs for now. The D/A rear Konis have a larger diameter shaft than the S/A Koni I plan on using. It will be a couple months before the upgrade, so I still have some time to research it.
      09-09-2008, 04:39 PM   #9
Terp1
Terp1's Avatar
Charles1,
In talking to TC Kline, do they suggest the AST RSM's?
      09-09-2008, 04:51 PM   #10
Charles1
Drives: 135i
Charles1,
NO recommendation from them but said AST was nice stuff..
1addicts
